[mpich-discuss] Funky MPI_File_write_at Parameters
William Gropp wgropp at illinois.edu
Tue Apr 12 08:54:44 CDT 2011
The offset is likely 8 bytes, not 4 (it depends on the MPI
implementation and file system environment), and the write buffer must
be non-null unless a datatype with an absolute address is used.  My
guess is that the offset is 8 bytes, and that is throwing off the
interpretation of the traceback.
Bill
On Apr 11, 2011, at 7:45 PM, Ellis H. Wilson III wrote:
> Hi all,
> Back with another odd-ball tracing question.  When I trace IOR using
> the
> following parameters:
> IOR -a MPIIO -b 4m -t 2m -i 1 -o pvfs2:/tmp/pvfs2client/test.dat
> I get what I feel are very odd tracing parameters shown below for the
> MPI_File_write_at function:
> MPI_File_write_at(0x9ae9ab0, 4194304, NULL, -1211088896, 0x200000,
> 0x4c00010d
> Now there are 6 parameters, which I expected from the specification,
> but
> it seems to me like they might be out of order.  P1 seems to be the
> file
> handle, P2 seems to be the offset, P3 indicates my lack of a buffer,
> which I believe to be fine, but P4 is the real oddity as the count
> argument should be nonnegative and here we have -1211088896.  0x200000
> corresponds to 2097152 decimal so I would think that makes more
> sense as
> a count (-t means transfers of 2megs, which is dead on for that) and I
> know the last parameter shown should have been my datatype and sitting
> in position 5, but it is in 6.  Status object is nowhere to be found
> as
> it ends there (unless status object somehow got switched to position
> 4,
> which is my guess currently).  These parameters are similarly weird
> for
> MPI_File_read_at.
> I am tracing MPI calls using LANL-Trace and I've looked through the
> code
> for LANL-Trace and IOR and everything seems to check out except the
> difference between how IOR internally handles offset and count (both
> long long int) and how mpich handles offset and count (int).  I don't
> think this is the issue however as I've added some quick casts to IOR
> and the problem persists.  I am truly lost on why this is happening,
> but
> then again perhaps I am misunderstanding something fundamental about
> this.
> If anyone can confirm that at the very least, I am right in thinking
> this looks weird it would be very helpful.
> Thanks,
> ellis
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
William Gropp
Director, Parallel Computing Institute
Deputy Director for Research
Institute for Advanced Computing Applications and Technologies
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
