[mpich-discuss] Windows Vista 32 bit, cant get mpiexec -validate to work..
John Snyder john.p.snyder at gmail.com
Tue Apr 5 13:31:17 CDT 2011
Eureka! Thats it! All works well now. Many thanks!
John S
On Tue, Apr 5, 2011 at 9:00 AM, Chris George <cgeorge at mcmaster.ca> wrote:
> I suspect you did what I first did.  You have to supply the login password
> of the user when you register mpiexec, not the passphrase you used in
> installation.
> Chris
> On 2011-04-04, at 11:07 PM, John Snyder wrote:
>> Hello,
>> I installed MPICH2 version 1.3.3rc1 on my laptop that has a pentium dual
>> core T2080. The OS is 32 bit Vista Home Premium. Install went well as far as
>> I could tell. I left the passphrase at 'behappy' and chose 'all users', not
>> 'just me' during install. I made sure smpd was running with smpd -status. I
>> then did the following:
>> C:\Test for MPI on Windows>C:\MPICH2_1d3d3rc1\bin\mpiexec -remove
>> Account and password removed from the Registry.
>> C:\Test for MPI on Windows>C:\MPICH2_1d3d3rc1\bin\mpiexec -register
>> account (domain\user) [JOHNSLAPTOP\test]:
>> password:
>> confirm password:
>> Password encrypted into the Registry.
>> C:\Test for MPI on Windows>C:\MPICH2_1d3d3rc1\bin\mpiexec -validate
>> FAIL
>> The password I use above was 'behappy'. I cant get the validate command to
>> work. I've read many of the relevant threads in this forum. I've shut off
>> UAC and while that helped smpd to run, it did not help with the validate
>> problem. I've tried creating another administrator account and got the same
>> result. I've tried stopping and installing smpd - no luck.
>> I went ahead and tried running mpiexec just to see what would happen:
>> C:\Test for MPI on Windows>C:\MPICH2_1d3d3rc1\bin\mpiexec -n 2 icpi.exe
>> Credentials for JOHNSLAPTOP\test rejected connecting to JohnSlaptop
>> Aborting: Unable to connect to JohnSlaptop
>> Any suggestions would be greatly appreciated.
>> Thanks
>> John S
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110405/0684420a/attachment.htm>
