[mpich-discuss] Using an Alternative Debugger for MPICH
Ellis H. Wilson III ellis at runnersroll.com
Fri Apr 1 13:56:41 CDT 2011
On 04/01/11 14:40, Yauheni Zelenko wrote:
> Hi, Ellis!
> If you open to proprietary alternatives, I could recommend DDT by Allinea. I use it too.
Eugene and Ashley,
Thanks for your suggestions.  Surprisingly, I'm not really interested in
doing "actual" debugging, I'm using the debugger as a tracing mechanism.
 Allow me to elaborate to make sense of this: I'm using LANL-Trace and
an instrumented MPICH to grab MPI-IO accesses as they go out to PVFS and
LANL-Trace by requires the use of -dbg to specify it's custom debugger
mpirun_dbg.ltrace.  I plan to move away from LANL-Trace this summer, but
would like to continue working with it until then as I don't have enough
time to totally revamp my code base right now.
Seeing that John Bent is on this list, perhaps I can bother him to offer
some insight into my problem since he's listed in the LANL-Trace README.
ellis
