[mpich-discuss] cryptic (to me) error
Dave Goodell goodell at mcs.anl.gov
Fri Sep 3 09:35:37 CDT 2010
I was unclear.  I meant to use HYDRA_HOST_FILE when running the MPICH2 test suite in order to make it run across the same set of machines that your MCNP code runs on.
-Dave
On Sep 3, 2010, at 9:25 AM CDT, SULLIVAN David (AREVA) wrote:
> Same result, mpi doesn't even get to call mcnp5.mpi. It just returns the
> Fatal error in PMPI_Comm_dup: Other MPI error, error stack: error.
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Friday, September 03, 2010 10:21 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] cryptic (to me) error
> Try setting HYDRA_HOST_FILE=your_machine_file_here
> This will make hydra act as though you passed "-f your
> machine_file_here" to every mpiexec.
> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
> #Environment_Settings
> -Dave
> On Sep 3, 2010, at 5:00 AM CDT, SULLIVAN David (AREVA) wrote:
>> I was wondering about that. Is there a configuration file that sets up
> the cluster and defines which node to run on? Would that make the issue
> any clearer?
>> Thanks,
>> Dave
>> From: mpich-discuss-bounces at mcs.anl.gov on behalf of Rajeev Thakur
>> Sent: Thu 9/2/2010 10:22 PM
>> There might be some connection issues between the two machines. The
> MPICH2 test suite that you ran with "make testing" probably ran on a
> single machine.
>> On Sep 2, 2010, at 6:27 PM, SULLIVAN David (AREVA) wrote:
>>> The error occurs immediately- I don't think it even starts the
> executable. It does work on the single machine with 4 processes.
>>> Sent: Thu 9/2/2010 4:34 PM
>>> Does it run with 2 processes on a single machine?
>>> On Sep 2, 2010, at 2:38 PM, SULLIVAN David (AREVA) wrote:
>>>> That fixed the compile. Thanks!
>>>> The latest release does not fix the issues I am having though. Cpi
>>>> works fine, the test suit is certainly improved (see summary.xml
>>>> output) though when I try to use mcnp it still crashes in the same
>>>> way (see
>>>> error.txt)
>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony Chan
>>>> Sent: Thursday, September 02, 2010 1:38 PM
>>>> There is a bug in 1.3b1 about the option --enable-fc.  Since Fortran
>>>> 90 is enabled by default, so remove the --enable-fc from your
>>>> configure command and try again.  If there is error again, send us
>>>> the configure output as you seen on your screen (See README) instead
> of config.log.
>>>> A.Chan
>>>> ----- "SULLIVAN David (AREVA)" <David.Sullivan at areva.com> wrote:
>>>>> Failure again.
>>>>> The 1.3 beta version will not compile with Intel 10.1. It bombs at
>>>>> the
>>>>> configuration script:
>>>>> checking for Fortran flag needed to allow free-form source...
>>>>> unknown
>>>>> configure: WARNING: Fortran 90 test being disabled because the
>>>>> /home/dfs/mpich2-1.3b1/bin/mpif90 compiler does not accept a .f90
>>>>> extension
>>>>> configure: error: Fortran does not accept free-form source
>>>>> configure: error: ./configure failed for test/mpi
>>>>> I have attached to config.log
>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev
>>>>> Thakur
>>>>> Sent: Thursday, September 02, 2010 12:11 PM
>>>>> Just try relinking with the new library at first.
>>>>> Rajeev
>>>>> On Sep 2, 2010, at 9:32 AM, SULLIVAN David (AREVA) wrote:
>>>>>> I saw that there was a newer beta. I was really hoping to find I
>>>>> just
>>>>>> configured something incorrectly. Will this not require me to
>>>>> re-build
>>>>>> mcnp (the only program I run that uses mpi for parallel) if I
>>>>>> change
>>>>>> the mpi version? If so, this is a bit of a hardship, requiring
>>>>>> codes
>>>>>> to be revalidated. If not- I will try it in a second.
>>>>>> Thanks,
>>>>>> Dave
>>>>> Goodell
>>>>>> Sent: Thursday, September 02, 2010 10:27 AM
>>>>>> Can you try the latest release (1.3b1) to see if that fixes the
>>>>>> problems you are seeing with your application?
>>>>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php
>>>>> ?s=
>>>>>> do
>>>>>> wnloads
>>>>>> -Dave
>>>>>> On Sep 2, 2010, at 9:15 AM CDT, SULLIVAN David (AREVA) wrote:
>>>>>>> Another output file, hopefully of use.
>>>>>>> Thanks again
>>>>>>> Dave
>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN
>>>>>>> David
>>>>>>> (AREVA)
>>>>>>> Sent: Thursday, September 02, 2010 8:20 AM
>>>>>>> First my apologies for the delay in continuing this thread.
>>>>>>> Unfortunately I have not resolved it so if I can indulge the
>>>>>>> gurus
>>>>>>> and
>>>>>>> developers once again...
>>>>>>> As suggested by Rajeev I ran the testing suit in the source
>>>>> directory.
>>>>>>> The output of errors, which are similar to what I was seeing when
>>>>>>> I
>>>>>>> ran
>>>>>>> mcnp5 (v. 1.40 and 1.51), is attached.
>>>>>>> Any insights would be greatly appreciated,
>>>>>>> Dave
>>>>> Thakur
>>>>>>> Sent: Wednesday, August 04, 2010 3:06 PM
>>>>>>> Then one level above that directory (in the main MPICH2 source
>>>>>>> directory), type make testing, which will run through the entire
>>>>>>> MPICH2 test suite.
>>>>>>> Rajeev
>>>>>>> On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
>>>>>>>> Oh. That's  embarrassing. Yea. I have those examples. It runs
>>>>> with
>>>>>>>> no
>>>>>>>> problems:
>>>>>>>> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi Process 2
>>>>> of
>>>>>>>> 4
>>>>>>>> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is on
>>>>> aramis
>>>>>>>> Process 1 of 4 is on aramis pi is approximately
>>>>> 3.1415926544231239,
>>>>>>>> Error is 0.0000000008333307 wall clock time = 0.000652
>>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus
>>>>> Correa
>>>>>>>> Sent: Wednesday, August 04, 2010 1:13 PM
>>>>>>>> To: Mpich Discuss
>>>>>>>> Hi David
>>>>>>>> I think the "examples" dir is not copied to the installation
>>>>>>> directory.
>>>>>>>> You may find it where you decompressed the MPICH2 tarball, in
>>>>>>>> case
>>>>>>>> you
>>>>>>>> installed it from source.
>>>>>>>> At least, this is what I have here.
>>>>>>>> Gus Correa
>>>>>>>>> Yea, that always bothered me.  There is no such folder.
>>>>>>>>> There are :
>>>>>>>>> bin
>>>>>>>>> etc
>>>>>>>>> include
>>>>>>>>> lib
>>>>>>>>> sbin
>>>>>>>>> share
>>>>>>>>> The  only examples I found were in the  share folder,  where
>>>>> there
>>>>>>>> are
>>>>>>>>> examples for collchk,  graphics and  logging.
>>>>>>>>> Thakur
>>>>>>>>> Sent: Wednesday, August 04, 2010 12:45 PM
>>>>>>>>> Not cpilog. Can you run just cpi from the mpich2/examples
>>>>> directory.
>>>>>>>>> Rajeev
>>>>>>>>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>> Rajeev,  Darius,
>>>>>>>>>> Thanks for your response.
>>>>>>>>>> cpi yields  the  following-
>>>>>>>>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12
>>>>> ./cpilog
>>>>>>>>>> Process 0 running on aramis Process 2 running on aramis
>>>>>>>>>> Process
>>>>> 3
>>>>>>>>>> running on aramis Process 1 running on aramis Process 6
>>>>>>>>>> running
>>>>> on
>>>>>>>>>> aramis Process 7 running on aramis Process 8 running on aramis
>>>>>>>>>> Process
>>>>>>>>>> 4 running on aramis Process 5 running on aramis Process 9
>>>>> running
>>>>>>>>>> on
>>>>>>>>>> aramis Process 10 running on aramis Process 11 running on
>>>>>>>>>> aramis
>>>>>>>>>> pi
>>>>>>>>>> is
>>>>>>>>>> approximately 3.1415926535898762, Error is 0.0000000000000830
>>>>> wall
>>>>>>>>>> clock time = 0.058131 Writing logfile....
>>>>>>>>>> Enabling the Default clock synchronization...
>>>>>>>>>> clog_merger.c:CLOG_Merger_init() -  Could not open file
>>>>>>>>>> ./cpilog.clog2 for merging!
>>>>>>>>>> Backtrace of the callstack at rank 0:
>>>>>>>>>> At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>>>>>>>> At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>>>>>>>> At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>>>>>>>> At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>>>>>>>> At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>>>>>>>> At [5]: ./cpilog(main+0x428)[0x415963]  At [6]:
>>>>> /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>>>>>>>> At [7]: ./cpilog[0x415449]
>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>>>>>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated
>>>>>>>>>> (signal
>>>>>>>>>> 15)
>>>>>>>>>> So  it looks like it works  with some issues.
>>>>>>>>>> When does  it fail? Immediately
>>>>>>>>>> Is there  a  bug? Many sucessfully use the aplication (MCNP5,
>>>>>>>>>> from
>>>>>>>>>> LANL) with  mpi,  so  think that  a  bug there is  unlikely.
>>>>>>>>>> Core files, unfortunately reveals some ignorance on my part.
>>>>> Were
>>>>>>>>>> exactly should I be looking for them?
>>>>>>>>>> Thanks again,
>>>>>>>>>> Dave
>>>>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>>>>>>>>>> Buntinas
>>>>>>>>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>>>>>>>>> This error message says that two processes terminated because
>>>>> they
>>>>>>>>>> were unable to communicate with another (or two other)
> process.
>>>>>>> It's
>>>>>>>>>> possible that another process died, so the others got errors
>>>>>>>>>> trying
>>>>>>>>>> to
>>>>>>>>>> communicate with them.  It's also possible that there is
>>>>> something
>>>>>>>>>> preventing some processes from communicating with each other.
>>>>>>>>>> Are you able to run cpi from the examples directory with 12
>>>>>>>> processes?
>>>>>>>>>> At what point in your code does this fail?  Are there any
>>>>>>>>>> other
>>>>>>>>>> communication operations before the MPI_Comm_dup?
>>>>>>>>>> Enable core files (add "ulimit -c unlimited" to your .bashrc
>>>>>>>>>> or
>>>>>>>>>> .tcshrc) then run your app and look for core files.  If there
>>>>>>>>>> is
>>>>> a
>>>>>>>>>> bug
>>>>>>>>>> in your application that causes a process to die this might
>>>>>>>>>> tell
>>>>>>>>>> you
>>>>>>>>>> which one and why.
>>>>>>>>>> Let us know how this goes.
>>>>>>>>>> -d
>>>>>>>>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>>> Since I have  had  no responses, is  there any other
>>>>> additional
>>>>>>>>>> information could I provide to solicit some direction for
>>>>>>>>>> overcoming
>>>>>>>>>> these latest string of mpi errors?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Dave
>>>>> SULLIVAN
>>>>>>>>>>> David F (AREVA NP INC)
>>>>>>>>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>>>>>>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>>>>>>>>> With my firewall issues firmly behind me, I have a new
>>>>>>>>>>> problem
>>>>>>>>>>> for
>>>>>>>>>>> the
>>>>>>>>>> collective wisdom. I am attempting to run a program to which
>>>>>>>>>> the
>>>>>>>>>> response is as follows:
>>>>>>>>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi i=TN04
>>>>>>>>>>> o=TN04.o
>>>>>>>>>>> Fatal error in MPI_Comm_dup: Other MPI error, error stack:
>>>>>>>>>>> MPI_Comm_dup(168).................:
>>>>> MPI_Comm_dup(MPI_COMM_WORLD,
>>>>>>>>>>> new_comm=0x7fff58edb450) failed
>>>>>>>>>>> MPIR_Comm_copy(923)...............:
>>>>>>>>>>> MPIR_Get_contextid(639)...........:
>>>>>>>>>>> MPI_Allreduce(773)................:
>>>>>>> MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>>>>>>>>> rbuf=0x7fff
>>>>>>>>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>>>>>>> MPIR_Allreduce(228)...............:
>>>>>>>>>>> MPIC_Send(41).....................:
>>>>>>>>>>> MPIC_Wait(513)....................:
>>>>>>>>>>> MPIDI_CH3I_Progress(150)..........:
>>>>>>>>>>> MPID_nem_mpich2_blocking_recv(933):
>>>>>>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Fatal
>>>>>>>>>>> error
>>>>>>>>>>> in
>>>>>>>>>> new_comm=0x7fff
>>>>>>>>>> 97dca620) failed
>>>>>>>>>> rbuf=0x7fff
>>>>>>>>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>>>>>>> MPIR_Allreduce(289)...............:
>>>>>>>>>>> MPIC_Sendrecv(161)................:
>>>>>>>>>>> MPID_nem_mpich2_blocking_recv(948):
>>>>>>>>>>> Killed
>>>>> by
>>>>>>>>>>> signal 2.
>>>>>>>>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>>>>>>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could not
>>>>>>>>>>> find
>>>>>>>>>>> fd
>>>>>>>>>>> to deregister: -2 [mpiexec at athos] HYD_pmcd_pmiserv_cleanup
>>>>>>>>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd
>>>>>>>>>>> [press
>>>>>>>>>>> Ctrl-C
>>>>>>>>>>> again to force abort] APPLICATION TERMINATED WITH THE EXIT
>>>>> STRING:
>>>>>>>>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>>>>>>>>> Thanks in advance,
>>>>>>>>>>> David Sullivan
>>>>>>>>>>> AREVA NP INC
>>>>>>>>>>> 400 Donald Lynch Boulevard
>>>>>>>>>>> Marlborough, MA, 01752
>>>>>>>>>>> Phone: (508) 573-6721
>>>>>>>>>>> Fax: (434) 382-5597
>>>>>>>>>>> David.Sullivan at AREVA.com
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> mpich-discuss mailing list
>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>>>> <summary.xml>_______________________________________________
>>>> <summary.xml><error.txt>____________________________________________
>>>> ___
>>> <winmail.dat>_______________________________________________
