[mpich-discuss] Problem with Intel Fortran Compiler and MPICH2 on Mac OS X
chan at mcs.anl.gov chan at mcs.anl.gov
Tue Oct 26 16:32:04 CDT 2010
gcc 4.6 is new, I don't think any of us has tested it before, so it is
likely there is compatibility issue between gcc-4.6 and ifort 11.1.
MPICH2's fortran binding assumes C symbols without any leading underscore
which is however what your error message shows.  Could you reconfigure your
mpich2 installation with CFLAGS=-fno-leading-underscore and then make to
see if things improved (if you do inpath build, be sure to a make distclean) ?
In any case, can you send us the configure and make outputs as seen on your
terminal (the details of how to get the outputs is stated in the README) ?
A.Chan
----- "Omer Acikgoz" <oacikgoz at hotmail.com> wrote:
> I have a problem using Intel Fortran Compiler 11.1 with MPICH2 version
> 1.3 on Mac OS X.
> I do not have Intel C/C++ compiler, therefore when I compiled MPICH2,
> the C libraries were compiled using GCC 4.6 and I used ifort as the
> default fortran compiler. The compilation had no errors or problems,
> however, when I compiled my first code using mpif90, this is what I
> got
> Undefined symbols:
>   "___emutls_get_address", referenced from:
>       _MPIR_Allreduce_intra in libmpich.a(allreduce.o)
>       _MPIR_MINF in libmpich.a(opmin.o)
>       _MPIR_BAND in libmpich.a(opband.o)
>       _MPIR_MAXLOC in libmpich.a(opmaxloc.o)
>       _MPIR_PROD in libmpich.a(opprod.o)
>       _MPIR_BXOR in libmpich.a(opbxor.o)
>       _MPIR_MINLOC in libmpich.a(opminloc.o)
>       _MPIR_BOR in libmpich.a(opbor.o)
>       _MPIR_LXOR in libmpich.a(oplxor.o)
>       _MPIR_Reduce_intra in libmpich.a(reduce.o)
>       _MPIR_LAND in libmpich.a(opland.o)
>       _MPIR_LOR in libmpich.a(oplor.o)
>       _MPIR_MAXF in libmpich.a(opmax.o)
>       _MPIR_SUM in libmpich.a(opsum.o)
>       _MPIU_Strerror in libmpich.a(strerror.o)
>       _MPIR_Reduce_scatter_block_intra in
> libmpich.a(red_scat_block.o)
> ld: symbol(s) not found
> When I change the default Fortran compiler to GNU gfortran, the code
> compiles with no problems. I suspect this is related to an
> incompatibility between GCC and Intel Fortran Compiler. What do you
> think?
> Thanks a lot!
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
