[mpich-discuss] mpich runs
Luis Del Castillo luis.delcastillo at cathalac.org
Wed Oct 20 09:16:26 CDT 2010
Everytime I run mpirun -np 5 or -np 8 the results for PI are the same but the wall clock time is different.
-----Original Message-----
Sent: miércoles, 20 de octubre de 2010 08:31 a.m.
Subject: Re: [mpich-discuss] mpich runs
Am 20.10.2010 um 00:30 schrieb Luis Del Castillo:
> Hi fellows my name is Luis Alejandro Del Castillo and am  having issues to figure it out why if run  mpirun twice with the same configuration give me 2 different answers.
> wrf at cl2master-> ./mpirun -np 5 ../examples/cpi
> Process 0 on cl2master
> Process 1 on node1
> Process 3 on node3
> Process 4 on node4
> Process 2 on node2
> pi is approximately 3.1416009869231245, Error is 0.0000083333333314
> wall clock time = 0.007812
> Process 3 on node3
> Process 1 on node1
> Process 2 on node2
> Process 4 on node4
Do you mean the different order in stdout? AFAIK this cannot be predicted.
-- Reuti
> wall clock time = 0.000000
> wrf at cl2master->
> I have a Quad Core Beowulf cluster with 11 nodes (1 master , 10 slaves) all the same configuration.
> I want to do this because I am trying to explain the performance doing some graph.
> Thanks
> Luis Alejandro Del Castillo Riley
> Soporte de Tecnología / IT Support
> CATHALAC
> www.cathalac.org
> Tel: (507)317-3235 (directo)
> Tel: (507)317-3200 (Central Telefónica)
> Fax: (507)317-3299
> 111 Ciudad del Saber, Clayton, Panamá
> Apartado 0843-03102, Panamá
> mpich-discuss mailing list
