[mpich-discuss] cli.h file not found error
Darius Buntinas buntinas at mcs.anl.gov
Fri Oct 8 15:54:52 CDT 2010
Did you recompile mpiexample with BLCR-enabled MPICH2?  The error you're getting is from blcr that typically means that you're trying to checkpoint a process that doesn't support checkpointing.
-d
On Oct 8, 2010, at 3:00 PM, kishor kharbas wrote:
> Thank you Darius for your response.
> I have now built mpich2-1.3rc2 and hydra.
> So I use mpiexec.hydra in Hydra installation, this is the command I run
> mpiexec.hydra -ckpointlib blcr -ckpoint-prefix=/home/kkharba/chkpnts -n 2 ./mpiexample
> But when I send SIGUSR1 to the mpiexec process, I get following error.
> [proxy:0:0 at opt09] requesting checkpoint
> [proxy:0:0 at opt09] HYDT_ckpoint_blcr_suspend (./tools/ckpoint/blcr/ckpoint_blcr.c:164): cr_request_checkpoint failed, Unknown error 2356
> [proxy:0:0 at opt09] HYDT_ckpoint_suspend (./tools/ckpoint/ckpoint.c:78): blcr checkpoint returned error
> [proxy:0:0 at opt09] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:901): checkpoint suspend failed
> [proxy:0:0 at opt09] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:76): callback returned error status
> [proxy:0:0 at opt09] main (./pm/pmiserv/pmip.c:221): demux engine error waiting for event
> [mpiexec at opt09] connection to proxy terminated unexpectedly
> Is there anything wrong that I might be doing ?
> Thank you.
> On Fri, Oct 8, 2010 at 12:33 PM, Darius Buntinas <buntinas at mcs.anl.gov> wrote:
> BLCR checkpointing is not supported in 1.2.1 (hydra supports it, but the mpich2 library doesn't).  Try 1.3rc2.  You can find documentation in the user manual and the README:
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> -d
> On Oct 8, 2010, at 8:41 AM, kishor kharbas wrote:
> > Hi all,
> > I am trying to install mpich2-1.2.1p1 with BLCR support.
> > The configure script which I run is:
> > ./configure --prefix=/home/kkharba/mpich2-1.2.1p1-install --enable-checkpointing --with-hydra-ckpointlib=blcr --with-blcr=/home/kkharba/blcr-install
> > the configure script does not complete but gives this error:
> > configure: error: 'cli.h not found.  Did you specify --with-cli-dir=?'
> > configure: error: ./configure failed for channels/nemesis
> > configure: error: Configure of src/mpid/ch3 failed!
> > I searched all the file systems but could not find this file.
> > Can you help me out in this issue !!
> > Thank you.
> > Kishor Kharbas
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Kishor Kharbas
> MS Student
> Department of Computer Science
> NC State University
> Raleigh, NC 27606
