[mpich-discuss] cli.h file not found error
Darius Buntinas buntinas at mcs.anl.gov
Fri Oct 8 11:33:30 CDT 2010
BLCR checkpointing is not supported in 1.2.1 (hydra supports it, but the mpich2 library doesn't).  Try 1.3rc2.  You can find documentation in the user manual and the README:
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
-d
On Oct 8, 2010, at 8:41 AM, kishor kharbas wrote:
> Hi all,
> I am trying to install mpich2-1.2.1p1 with BLCR support.
> The configure script which I run is:
> ./configure --prefix=/home/kkharba/mpich2-1.2.1p1-install --enable-checkpointing --with-hydra-ckpointlib=blcr --with-blcr=/home/kkharba/blcr-install
> the configure script does not complete but gives this error:
> configure: error: 'cli.h not found.  Did you specify --with-cli-dir=?'
> configure: error: ./configure failed for channels/nemesis
> configure: error: Configure of src/mpid/ch3 failed!
> I searched all the file systems but could not find this file.
> Can you help me out in this issue !!
> Thank you.
> Kishor Kharbas
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
