[mpich-discuss] mpi.mod is not a gfortran module file
Jayesh Krishna jayesh at mcs.anl.gov
Thu Oct 7 11:06:02 CDT 2010
 The default fortran 90 module available with MPICH2 is compiled using Intel Fortran compiler (not compatible with gfortran).
 If your program is a fortran 90 program (not just using "use mpi") then I would recommend that you compile MPICH2 on Cygwin (configure/make/make install).
Jayesh
----- Original Message -----
Sent: Thursday, October 7, 2010 3:06:07 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] mpi.mod is not a gfortran module file
Hello, I have installed GCC & MPICH2-1.2.1p1 for windows, it works well with c/C++
but I can't compile my fortran file with mpi. and I use this command:
gfortran -I D:\MPICH2\include -L D:\MPICH2\lib $(FileName) -o $(FileNameNoExt) -lmpi
and in the folder " D:\MPICH2\include", it contains mpi.mod file.
but I got the following error:
hello.F90:2.36:
use mpi
1
Fatal Error: File 'mpi.mod' opened at (1) is not a GFORTRAN module file
gfortran.exe: Internal error: Aborted (program f951)
Please submit a full bug report.
See < http://gcc.gnu.org/bugs.html > for instructions.
请按任意键继续. . .
my gfortran version is :
D:\GCC\bin>gfortran -v
Built by Equation Solution < http://www.Equation.com >.
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=d:/gcc/bin/../libexec/gcc/i686-pc-mingw32/4.5.1/lto-wrapper.
exe
Target: i686-pc-mingw32
Thread model: win32
gcc version 4.5.1 (GCC)
D:\GCC\bin>
what's the matter? who can help me? somebody says it may be caused by different versions of gfortran? and who can send me a copy of mpi.mod created by my version?
孔涛 山东大学数学学院
Mobile: 13688635846 Phone: 0531-88369020 QQ:584219201
mpich-discuss mailing list
