[mpich-discuss] How to build libfmpich libraries
Pavan Balaji balaji at mcs.anl.gov
Wed Oct 6 18:15:22 CDT 2010
Note that the MPICH2 process managers support a -configfile option which
might achieve the same behavior for you.
  -- Pavan
On 10/06/2010 04:15 PM, Darius Buntinas wrote:
> Why do you need mpirun.arg?  How is the package using it?
> -d
> On Oct 6, 2010, at 12:54 AM, Lokendra S wrote:
>> Hi.
>> Is it not possible to build libfmpich libs with older MPICH (v1.2.5.2)
>> I have built it with MPICH2 without problems.
>> Actually, there are some compatibilty problems with a specific package I am dealing with, which supports requires 'mpirun.args' executable.
>> And 'mpirun.args' exec is built with MPICH1. Hence, I am forced to use MPICH1.
>> Regards
>> Lokendra
>> From: Darius Buntinas<buntinas at mcs.anl.gov>
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Tue, 5 October, 2010 9:40:11 PM
>> Subject: Re: [mpich-discuss] How to build libfmpich libraries
>> MPICH-1.2.5.2 is very old.  Can you try MPICH2?  You can download the latest version here:
>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
>> Let us know if you have any trouble with this.
>> -d
>> On Oct 5, 2010, at 8:33 AM, Lokendra S wrote:
>>> Hi Everyone,
>>> I am building MPICH-1.2.5.2 with the following command. I want to build libfmpi libraries.
>>> I have set some fortran related variables and options (as shown below), but it is not building libfmpich.
>>> Can you please help me with what am I missing.
>>> $ export FC=gfortran
>>> $ export F77=gfortran
>>> $ ./configure --with-arch=LINUX --enable-f77  --enable-sharedlib=/root/mpich-install/lib/ --with-romio --prefix=/root/mpich-install/
>>> Regards
>>> Lokendra
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
