[mpich-discuss] How to build libfmpich libraries
chan at mcs.anl.gov chan at mcs.anl.gov
Wed Oct 6 00:28:00 CDT 2010
If you have to use mpich-1, use the last version which should be
1.2.7p1.  It should build libfmpich.a if Fortran binding can be
configured.  With newer fortran compiler, like gfortran, you may
have trouble to get any mpich-1 to build the Fortran binding.
Since we don't support/develop mpich-1 anymore, you should consider
migrating to mpich2 in any case.
A.Chan
----- "Lokendra S" <lucky2006_89 at yahoo.co.in> wrote:
> Hi.
> Is it not possible to build libfmpich libs with older MPICH (v1.2.5.2)
> I have built it with MPICH2 without problems.
> Actually, there are some compatibilty problems with a specific package
> I am
> dealing with, which supports requires 'mpirun.args' executable.
> And 'mpirun.args' exec is built with MPICH1. Hence, I am forced to use
> MPICH1.
> Regards
> Lokendra
> ________________________________
> From: Darius Buntinas <buntinas at mcs.anl.gov>
> To: mpich-discuss at mcs.anl.gov
> Sent: Tue, 5 October, 2010 9:40:11 PM
> Subject: Re: [mpich-discuss] How to build libfmpich libraries
> MPICH-1.2.5.2 is very old.  Can you try MPICH2?  You can download the
> latest
> version here:
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> Let us know if you have any trouble with this.
> -d
> On Oct 5, 2010, at 8:33 AM, Lokendra S wrote:
> > Hi Everyone,
> > I am building MPICH-1.2.5.2 with the following command. I want to
> build libfmpi
> >libraries.
> > I have set some fortran related variables and options (as shown
> below), but it
> >is not building libfmpich.
> > Can you please help me with what am I missing.
> > $ export FC=gfortran
> > $ export F77=gfortran
> > $ ./configure --with-arch=LINUX --enable-f77
> >--enable-sharedlib=/root/mpich-install/lib/ --with-romio
> >--prefix=/root/mpich-install/
> > Regards
> > Lokendra
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
