[mpich-discuss] can't boot all once
Pavan Balaji balaji at mcs.anl.gov
Sat Oct 2 21:19:24 CDT 2010
Hello,
There might be a network setup issue on your system. You can use the
mpdcheck utility to debug it.
Alternatively, assuming you are using a new enough version of MPICH2,
you can use mpiexec.hydra instead. Usage instructions for mpiexec.hydra
are available here:
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
  -- Pavan
On 10/02/2010 08:09 PM, 雷 周 wrote:
> Hi,everyone,
> I installed lammps at my cluster(using Rocks Cluster).And I also
> intalled MPICH2,I use NFS to share the files of lammps and MPICH2 at
> /share/apps.
> I can't use "mpdboot -n X -f mpd.hosts" to boot MPI;the error is:
> [lammps at lammps ~]$ mpdboot -n X -f mpd.hosts
> mpdboot_lammps.hpc.org (handle_mpd_output 415): failed to connect to mpd
> on lammps
> but I can use:
> mpd &
> mpdtrace -l(at the frontend)
> mpd -h lammps.hpc.org -p XXXX & (at the compute nodes)
> to boot MPI,why?How can I solve this problem?
> Thank you!
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
