[mpich-discuss] How to run MPI code on a single machin with four cores when using MPICH2
Horacio Pedro Burbridge hpbridge at yahoo.com.ar
Tue Nov 30 09:37:19 CST 2010
Hi Jayesh,
Thanks for your answer.
I followed your suggestion by creating a bat file that executes the command you
sent to me.
The content of the bat file is:
 D:
cd \HORACIO\DOCTORADO\2-Corridas\MPI\Cluster
mpiexec -n 1 D:\HORACIO\DOCTORADO\2-Corridas\MPI\Cluster\Prueba32-01 : -n 1
D:\HORACIO\DOCTORADO\2-Corridas\MPI\Cluster1\Prueba32-01 : -n 1
D:\HORACIO\DOCTORADO\2-Corridas\MPI\Cluster2\Prueba32-01 : -n 1
D:\HORACIO\DOCTORADO\2-Corridas\MPI\Cluster3\Prueba32-01
The answer is:
Aborting, unable to connect to Usuario-PC, smpd version mismatch
¿How can be problems with smpd version if this is only one machine with four
cores? There is no way to have different versions of MPICH2 installed.
Note: In addition to have MPICH2 installed I also have MPICH installed into the
same computer.
Thank you.
 Horacio.
De: Jayesh Krishna <jayesh at mcs.anl.gov>
Para: mpich-discuss at mcs.anl.gov
CC: hpbridge at yahoo.com.ar
Enviado: domingo, 21 de noviembre, 2010 2:42:37
Asunto: Re: [mpich-discuss] How to run MPI code on a single machin with four
You should be able to launch different executables as part of the same job by
separating the executables (and the executable specific args) by a colon (:).
Try the following command and let us know if it works for you.
Jayesh
----- Original Message -----
From: Horacio Pedro Burbridge <hpbridge at yahoo.com.ar>
Sent: Sat, 20 Nov 2010 16:35:40 -0600 (CST)
Subject: [mpich-discuss] How to run MPI code on a single machin with four
Hello,
I got this e-mail from the mpich_discuss forum. I have already suscribed to it.
I have a code paralellized that is runnig OK when I compile it using Win32 Intel
Fortran compiler and MPICH1 libraries.
When I compile it using EMT64 Intel Fortran compiler and MPICH2 libraries it is
compiled OK but I can´t make it run.
I need to run this on a single Windows 7 machine using its four cores (Intel
i7). Once the core is finished I will run it on a 20 node cluster. Now my
problem is to run on a single machine.
When running the win32 MPICH1 compiled executable there is no problem at all.
I´m using four different folders and executing four executables. The executables
are the same, but the information they use is readed from different folders. For
this, I´m setting the enviromental varibles manually, and runing the executable
"Prueba32-01.exe" on four cores as follows:
file "mpi.bat" on folder \HORACIO\DOCTORADO\2-Corridas\MPI\Cluster:
 D:
 cd
 set MPICH_JOBID=ns.123
 set MPICH_IPROC= 0
 set MPICH_NPROC= 4
 set MPICH_ROOT=Usuario-PC:1
 Prueba32-01
file "mpi.bat" on folder \HORACIO\DOCTORADO\2-Corridas\MPI\Cluster1:
 D:
 cd
 set MPICH_IPROC= 1
 set MPICH_NPROC= 4
 Prueba32-01
file "mpi.bat" on folder \HORACIO\DOCTORADO\2-Corridas\MPI\Cluster2:
 D:
 cd
 set MPICH_IPROC= 2
 set MPICH_NPROC= 4
 Prueba32-01
file "mpi.bat" on folder \HORACIO\DOCTORADO\2-Corridas\MPI\Cluster3:
 D:
 cd
 set MPICH_IPROC= 3
 set MPICH_NPROC= 4
 Prueba32-01
This works fine with MPICH1. I couldn´t find a way to launch this executable on
four different folders using mpiexec or even manually by setting the
environmental variables "PMI_RANK" and "PMI_SIZE"
Could you please help me?
Thank you in advance.
 Horacio.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101130/5b47f5a8/attachment-0001.htm>
