[mpich-discuss] Parallel jobs
Gus Correa gus at ldeo.columbia.edu
Mon Nov 29 10:34:35 CST 2010
Hi Talla
It sounds like all processes are trying to read from stdin, right?
Stdin/stdout are not guaranteed to be available to all processes.
Have you tried to add these flags in your mpiexec/mpirun
command line:  "-s all" ?
Check the meaning with "man mpiexec".
My two cents,
Gus Correa
Talla wrote:
> Hello,
>  this issue is consuming all my time with no luck.  I can submit any job
> without any error message *BUT ONLY* when I am using *one* CPU, when I
> am using more than one CPU, I got the error message : " *forrtl: severe
> (24): end-of-file during read, unit 5, file stdin* ". I got this error
> line repeated as many as the number of CPU's I am using.
> Which mean that the other nodes are not doing any job here. So if you
> can help me to link the other nodes so I can take advantage of all the
> nodes.
> I have 8 PC and each one has 2 CPU (in total I have 16 CPU).
> I tested the cluster using the following command:
> /opt/openmpi/bin/mpirun -nolocal np 16 -machinefile machines
> /opt/mpi-test/bin/mpi-ring
> and all the nodes can send and receive data like a charm.
> Just to mention that I have Rocks Clustering software with open centOS.
> The code I am using is called ABINIT and it is impeded as a plugin in a
> visual software called MAPS.
> Your help is really appreciated.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
