[mpich-discuss] seek help on mpi- mpich
Jayesh Krishna jayesh at mcs.anl.gov
Thu Nov 25 08:37:12 CST 2010
 Can you try running the example MPI program (cpi.exe) provided with MPICH2 using the following command ?
 mpiexec -machinefile mf0.txt -n 2 C:\Progra~1\MPICH2\examples\cpi.exe
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Wed, 24 Nov 2010 23:05:44 -0600 (CST)
Subject: Re: seek help on mpi- mpich
Hi, thanks.
I get what you said. but why my pc worker does'nt show anything that shows
something the worker's pc is printing/doing what master says to get work
done.
until this time...my pc cannot validate (mpiexec -validate)..
one more thing I configued using wmpiconfig, then i can see this 2
processors (from master)
C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec
-machinefile mf0.txt -np 2 hostname
hpxp
ummuRifqi
~really messed..
On Mon, Nov 22, 2010 at 11:18 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
> >> mpiexec -machinefile mf.txt hellocluster.exe ...the output on master is
> printing master part only
>  The machinefile only lists the nodes that mpiexec can use to launch an MPI
> job. mpiexec does not necessarily use all the nodes listed in the
> machinefile for launching an MPI job. For example you can have 100 nodes
> listed in the machinefile, but mpiexec only uses the nodes that it needs for
> the job depending on the "-n" argument (eg: -n 3 ; will result in mpiexec
> launching 3 MPI processes) which provides information on the number of
> actual processes to launch.
> # For the example above with 100 nodes listed in the machinefile, mf.txt
> (Consider the simplest case where only the node ipaddresses of the 100 hosts
> are listed in the machinefile),
> 1) mpiexec -machinefile mf.txt mympipgm.exe ; Results in 1 MPI process -
> the default since -n argument is not present - being launched on the 1st
> node listed in the machinefile
> 2) mpiexec -n 2 -machinefile mf.txt mympipgm.exe ; Results in 2 MPI
> processes being launched, 1 each on the first 2 nodes/machines listed in the
> machinefile
> 3) mpiexec -n 100 -machinefile mf.txt mympipgm.exe ; Results in an MPI
> process launched on all the 100 nodes listed in the machinefile
> 4) mpiexec -n 101 -machinefile mf.txt mympipgm.exe ; Results in 2 MPI
> processes launched on the 1st node (The nodes are considered in a round
> robin fashion) and an MPI process launched on all the other 99 nodes listed
> in the machinefile
>  You should launch your MPI job as you ran the hostname command (mpiexec -n
> 2 -machinefile mf.txt helloCluster.exe).
>  Let us know if you have any further questions.
> Regards,
> Jayesh
> From: UmmuRifqi <ummurifqi09 at gmail.com>
> Sent: Sun, 21 Nov 2010 23:32:11 -0600 (CST)
> Hi,
> 1. what do you mean by message from both cases ? Correct if I am wrong..
> master's node will print : Master process rank#0 sending message ~Hello,
> world
> worker's node will print : Worker with rank#1 receives message ~Hello,
> world
> from master
> ok now, when I did this(as follows) on master's node which is
> 192.168.33.69:
> the output on master is printing master part only:
>       Master process rank#0 sending message ~Hello, world
> but if I typed this:
> -hosts 2 192.168.33.69 192.168.33.68 hellocluster.exe
> the output will be as follows
>    Worker with rank#1 receives message ~Hello, world from master
> (where the master also prints the worker part on the master node(which is
> supposed to be printed by worker's node):
> the mf.txt which my machine file content are:
> # XP node
> 192.168.33.69:1
> #vista node
> 192.168.33.68:1
> 2. issue related with setup
> -both machine (xp 32 bit &. vista home premium 32bit) installed with
> mpich2-1.3-win-ia32, with default passphrase
> -both machine had administrator user account with same password(already
> tried with new mpiuser with administrator privileges..resulted the same)
> -both can  execute the mpi stand alone program (multithreading),
> -firewall wall is totally off.
> - the confoguration ( wmpiconfig) is  as attached.
> - everything goes fine but the both machine error when doing command >>
> mpiexec -validate, the error is
>    Error during CryptEncrypt: Unknown failure 234
>    unable to encrypt the password for the validate command.
>   it hang until I close the command prompt window and restart.
> - when I run
> mpiexec -machinefile mf.txt -n 2 hostname
> the output :
> hpxp
> ummuRifqi
> --> hpxp is XP machine while ummuRifqi is Vista machine
> Thanks.
> On Mon, Nov 22, 2010 at 1:35 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
> wrote:
> > Hi,
> > >> In fact, the worker should print something to show ...
> >  In the output below I can see the message from worker for both cases 2 &
> 3
> > . Can you explain in detail the issue that you see with your setup ?
> >  You might also want to run "mpiexec -machinefile mf.txt -n 2 hostname"
> to
> > see the hosts where the processes get launched.
> > Regards,
> > Jayesh
> > Sent: Sat, 20 Nov 2010 23:14:56 -0600 (CST)
> > sorry some correction..
> > On Sun, Nov 21, 2010 at 1:09 PM, UmmuRifqi <ummurifqi09 at gmail.com>
> wrote:
> > > Hello again, sorry for late reply (being involved with some other
> > > not-related things)
> > > here is my output:
> > > 1. ====== with machinefile, if I dont specify the no of processors
> > > C:\~\~\~\myPar>mpiexec -machinefile mf.txt <http://mf.pg>
> > hellocluster.exe
> > > 2. ======= if I specify no of processors
> > > C:\~\~\~\myPar>mpiexec -machinefile mf.txt <http://mf.pg> -np 2
> > > hellocluster.exe
> > > 3. ======= without mentioning processor a.k.a multithreading.
> > > C:\~\~\~\myPar>mpiexec -np 2 hellocluster.exe
> > > as we can see, the output 2 is arguable because I don't see whether the
> > > node machine is working or not.
> > > because as output 3, the command may ignore the machine file(assumed by
> > me
> > > regarding to non reaction of worker's node).
> >   In fact, the worker should print something to show the message received
> > by it (as in the program code)
> > > how can I verify that the worker's node is executing the processes
> > assigned
> > > by master.
> > > Can we see it on the worker's node monitor? or it only can be seen on
> > > master's node?
> > > the right-click " run as administrator" I regard to when I want to open
> > DOS
> > > command prompt, there will always 2 optional as previous image I sent
> > you.
> > > so I choose administrator and once again enter the password. is that
> what
> > > you mean?
> > > thanks.
> > > On Tue, Nov 16, 2010 at 11:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov
> > >wrote:
> > >> Hi,
> > >> >> mpiexec -machinefile mf.txt helloCluster.exe
> > >>  If you do not specify the number of MPI processes only 1 MPI process
> is
> > >> launched. Use the "-n" option to specify the number of MPI processes
> > >> required for the job (mpiexec -n 2 -machinefile mf.txt
> > helloCluster.exe).
> > >> >> ...when I right-click to choose "run as administrator" ...
> > >>  Which program are you referring ? Are you running all the commands
> from
> > >> an administrator command prompt (In Vista even a user with admin
> > privileges
> > >> opens a command prompt it is not an elevated command prompt. In Vista
> to
> > >> open an administrator/elevated command prompt right-click on the
> command
> > >> prompt icon and select "run as administrator". Run all the commands on
> > Vista
> > >> from an administrator command prompt and see if it works)?
> > >> Regards,
> > >> Jayesh
> > >> Sent: Tue, 16 Nov 2010 02:24:35 -0600 (CST)
> > >> Hello and thank for your suppot..
> > >> yes. I tried create new user (mpiuser) with administrator privilege,
> the
> > >> other are other windows user with limited privilege.
> > >> then I registered mpiuser using mpiexec with password. but the
> validate
> > >> part
> > >> fail as following error.
> > >> but it can lauch mpi locally but only run on master node (which is in
> > this
> > >> case xp machine) if >>mpiexec -machinefile mf.txt helloCluster.exe
> > >> fyi, when I right-click to choose "run as administrator" there are two
> > >> option user provided.
> > >>  either to choose (domain\username) or administrator. (see the
> > >> image on run as administrator option). This is also happen to my vista
> > >> machine.
> > >> i am using xp sp2, and vista home premiun sp2
> > >> additionally, I also have read your comment in mpich-discuss but
>  cannot
> > >> refer the documentation (usually suggested by you on the installation
> > >> guide)
> > >> at
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
> > >> it is not available.
> > >> On Tue, Nov 16, 2010 at 4:50 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
> > >> wrote:
> > >> > Hi,
> > >> > >> so, i am using the second administrator on both machine (they
> have
> > >> the
> > >> > same passwd) to register...
> > >> >  As I mentioned before try registering a username different from the
> > >> > "Administrator".
> > >> >  Please follow the steps below,
> > >> > 1) On the XP machine & the Vista machine create a user, "mpiuser",
> > with
> > >> the
> > >> > same password (As I mentioned before do not register "Administrator"
> > >> with
> > >> > mpiexec).
> > >> > 2) Register & Validate "mpiuser" on each machine.
> > >> > 3) Test whether the user, "mpiuser" can launch MPI processes locally
> > on
> > >> > each machine.
> > >> > 4) Run your job across the XP & Vista machines and see if it works.
> > >> > Regards,
> > >> > Jayesh
> > >> > Sent: Mon, 15 Nov 2010 14:43:00 -0600 (CST)
> > >> > Hello again,
> > >> > Yeah,  At the first place I've done that (the same windows user/same
> > >> > password with administrator privileges both on XP and Vista).
> > >> > As I emailed to you,
> > >> >  in XP, there are 2 windows user 1) hpxp (user with administrator
> > >> > privileges)  2) Administrator (administrator privileges)
> > >> >  in Vista, There are also 2 windows user 1) user (administrator
> > >> > so, i am using the second administrator on both machine (they have
> the
> > >> same
> > >> > passwd) to register username/password with mpiexec which as follows:
> > >> > > the error after >>mpiexec -validate  // done on XP
> > >> > > Microsoft Windows XP [Version 5.1.2600]
> > >> > > (C) Copyright 1985-2001 Microsoft Corp.
> > >> > > C:\Documents and Settings\Administrator>mpiexec -remove
> > >> > > Account and password removed from the Registry.
> > >> > > C:\Documents and Settings\Administrator>mpiexec -register
> > >> > > account (domain\user) [HPXP\Administrator]: Administrator
> > >> > > password: **
> > >> > > confirm password: **
> > >> > > Password encrypted into the Registry.
> > >> > > C:\Documents and Settings\Administrator>mpiexec -validate
> > >> > > the error after >>mpiexec -validate Administrator/** //done on
> Vista
> > >> > > Microsoft Windows XP [Version 6.0.6002]
> > >> > > Copyright (C) 2006 Microsoft Corp. All right reserved.
> > >> > > C:\Users\Administrator>mpiexec -remove
> > >> > > C:\Users\Administrator>mpiexec -register
> > >> > > password:
> > >> > > confirm password:
> > >> > > C:\Users\Administrator>mpiexec -validate
> > >> > Eventhough I cannot validate, but I can run the MPI program from 1
> > node
> > >> or
> > >> > multithreading.
> > >> > result :
> > >> > in both machine.
> > >> > The firewalls are all off.
> > >> > Currently, I tried to change the administrator privileges on user
> hpxp
> > >> on
> > >> > XP, but it disables me to change the role to user privilege, so that
> I
> > >> only
> > >> > have 1 administrator privileges. in vista, it can be done easily,
> will
> > >> let
> > >> > you know later.
> > >> > before that,  do you have any suggestions please?
> > >> > thanks Mr Jayesh.
> > >> > On Mon, Nov 15, 2010 at 11:20 PM, Jayesh Krishna <
> > >> > wrote:
> > >> > > Hi,
> > >> > >  Is "myuser" a valid Windows user ? You need to register an
> existing
> > >> > > Windows username/password with mpiexec.
> > >> > >  Please create a windows user (The same username/password on XP &
> > >> Vista
> > >> > > machines) with administrator privileges and try registering that
> > >> > > username/password with mpiexec. Let us know the results.
> > >> > > Regards,
> > >> > > Jayesh
> > >> > > Sent: Sun, 14 Nov 2010 20:41:00 -0600 (CST)
> > >> > > Hello again Mr Jayesh.
> > >> > > I've removed and created new account other than Administrator as
> > below
> > >> > > myuser), (by mpiexec -register)
> > >> > > then it resulted the same one, I can register but could'nt
> validate
> > >> them.
> > >> > > FYI, in my XP machine, there are 2 accounts of administrator
> > role..1)
> > >> > > Administrator 2) hpxp  (we can see it on window welcome screen)
> > >> > > also in my vista machine, there are also 2 accounts of
> > administrator.
> > >> > > I installed the mPICH2  'everyone' not 'just me' features.
> > >> > > the output on my XP machine:
> > >> > > -register
> > >> > > account (domain\user) [HPXP\Administrator]: myuser
> > >> > > password:
> > >> > > confirm password:
> > >> > > -validate
> > >> > > help me please. Thanks.
> > >> > > On Thu, Nov 11, 2010 at 10:49 PM, Jayesh Krishna <
> > >> > > wrote:
> > >> > > > Hi,
> > >> > > >  Can you try registering/validating a username (an admin user)
> > other
> > >> > than
> > >> > > > "Administrator" ?
> > >> > > > Regards,
> > >> > > > Jayesh
> > >> > > > Sent: Wed, 10 Nov 2010 22:25:46 -0600 (CST)
> > >> > > > Hello again,
> > >> > > > step 1-2 done successfully.
> > >> > > > step 3 unsuccessful because when to validate the
> > username/password,
> > >> > there
> > >> > > > is
> > >> > > > an error..it hang and never return the command prompt until I
> > press
> > >> > > ctrl-C
> > >> > > > after several minutes waiting.
> > >> > > > password:
> > >> > > > confirm password:
> > Vista
> > >> > > > password:
> > >> > > > confirm password:
> > >> > > > how it can be solved , attached is my smpd.log
> > >> > > > thanks Mr. Jayesh.
> > >> > > > On Thu, Nov 11, 2010 at 9:20 AM, UmmuRifqi <
> > >> > > wrote:
> > >> > > > > Thanks for the feedback & suggestion.
> > >> > > > > Just arrived the lab, I'll try it out and will let you know
> the
> > >> > result.
> > >> > > > > On Wed, Nov 10, 2010 at 11:15 PM, Jayesh Krishna <
> > >> > > > >wrote:
> > >> > > > >> Hi,
> > >> > > > >>  Please try the following,
> > >> > > > >> 1) Create a machinefile, mf.txt, with the following contents,
> > >> > > > >> # XP node
> > >> > > > >> 192.168.33.69:1
> > >> > > > >> # Vista node
> > >> > > > >> 192.168.33.68:1
> > >> > > > >> 2) Make sure helloCluster.exe is available in C:\temp on both
> > the
> > >> > > > >> machines.
> > >> > > > >> 3) Remove any usernames registered on the machines using the
> > >> > "-remove"
> > >> > > > >> option of mpiexec ("mpiexec -remove" on both the machines)
> and
> > >> > > > re-register a
> > >> > > > >> username/password available on both the machines (same user -
> > >> with
> > >> > the
> > >> > > > same
> > >> > > > >> password - should be available on both the machines) using
> the
> > >> > > > "-register"
> > >> > > > >> option of mpiexec ("mpiexec -register" on both the machines).
> > >> > > > >>   Validate the username/password registered using the
> > "-validate"
> > >> > > option
> > >> > > > >> of mpiexec ("mpiexec -validate" on both the machines).
> > >> > > > >> 4) Try running helloCluster.exe on both machines (XP & Vista)
> > >> > locally
> > >> > > > >> (mpiexec -n 2 helloCluster.exe)
> > >> > > > >> 5) Try running a non-MPI program like hostname on both the
> > >> machines
> > >> > > > >> (mpiexec -n 2 -machinefile mf.txt hostname)
> > >> > > > >> 6) Now try running helloCluster.exe on the cluster (mpiexec
> -n
> > 2
> > >> > > > >> -machinefile mf.txt c:\temp\helloCluster.exe)
> > >> > > > >> (PS: If you get an error message please copy-paste it in your
> > >> email)
> > >> > > > >> Regards,
> > >> > > > >> Jayesh
> > >> > > > >> To: jayesh at mcs.anl.gov
> > >> > > > >> Sent: Wed, 10 Nov 2010 02:43:14 -0600 (CST)
> > >> > > > >> Subject: seek help on mpi- mpich
> > >> > > > >> Hello,
> > >> > > > >> I am new to mpich/mpi and I learn this by myself from the
> > >> Internet
> > >> > to
> > >> > > do
> > >> > > > >> my
> > >> > > > >> research.
> > >> > > > >> I've review the discussion mpich-discuss (
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html)
> > >> > > > >> been following the thread after thread and decided to email
> you
> > >> if
> > >> > you
> > >> > > > >> could
> > >> > > > >> help me on windows clustering using mpich2.
> > >> > > > >> I'm doing on XP and Vista machine, 32 bit, mpich2 version
> > >> > > > >> mpich2-1.2.1p1-win-ia32, it works on hello world program  for
> > >> single
> > >> > > > node
> > >> > > > >> (stand alone), but it does not run on multinode ( the nest
> > >> machine).
> > >> > > it
> > >> > > > >> says
> > >> > > > >> -machinefile mf.pg helloCluster.exe
> > >> > > > >> the firewall already off. the machine file contains
> > >> > > > >> 192.168.33.69 0 /Documents and Settings/Administrator/My
> > >> > > > Documents/myPar/
> > >> > > > >> this is XP machine
> > >> > > > >> 192.168.33.68 1
> > >> > > > >> /Users/Administrator/Documents/myPar/
> > >> > > > >> #this
> > >> > > > >> is Vista machine
> > >> > > > >> please help me. what else considering i have to take to
> enable
> > >> the
> > >> > > > >> interaction between the nodes because after this i need to do
> > it
> > >> on
> > >> > > 3,5,
> > >> > > > 8
> > >> > > > >> machines.
> > >> > > > >> thank you.
