[mpich-discuss] Question
Darius Buntinas buntinas at mcs.anl.gov
Wed Nov 24 11:46:13 CST 2010
I'm not familiar with Rocks or the GUI you're using, so I can't be sure what's going on.  One possibility is that a process other than rank 0 is expecting to be able to read stdin.  The MPI standard only requires stdin to be available on rank 0.  By "stdin" I mean being able to read input from the keyboard.
If this is the case, you'll have to modify your program to only read stdin on rank 0, then if the other processes need that data you can broadcast it from rank 0.
-d
On Nov 24, 2010, at 10:57 AM, Talla wrote:
> Hello Sir:
> Now, I can submit the job and the job is completed without any error message BUT ONLY when I am using one CPU, when I use more than one CPU, I got the error message : " forrtl: severe (24): end-of-file during read, unit 5, file stdin ". I got this error line repeated as many as the number of cpu's I am putting
> I would like to mention that I am using a visual program and all the commands are hidden (I can not see them).
> Which mean that the other nodes is not doing any job here. So if you can help me to link the other nodes so I can take advantage of all the nodes.
> I have 8 PC and each one has 2 CPU (in total I have 16 CPU).
> I am attaching a snapshot of the software I am using and the setting if this helps.
> Thank you very much.
> <Snapshot1.TIF>_______________________________________________
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
