[mpich-discuss] Urgent help needed for Mpich2 installation
Shaandar Nyamtulga nyam100 at hotmail.com
Tue Nov 23 02:37:11 CST 2010
Hi
I have just installed mpich2 using apt-get. But how I can run example programs to test my beywolf cluster? I did not point directory for the installation.Is there any example programs that comes with installation?
> From: buntinas at mcs.anl.gov
> Date: Mon, 22 Nov 2010 11:44:05 -0600
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Urgent help needed for Mpich1.2.7p1 installation
> You should be able to install the mpich packages using apt-get:
>    sudo apt-get install mpich2
> -d
> On Nov 21, 2010, at 8:59 PM, Shaandar Nyamtulga wrote:
> > Hi
> > I am trying to create Beywolf cluster for 2 computers.(One is desktop, one is laptop, Both has Ubuntu OS)
> > I am following one guy's instructions in the following link.The guy stated that he could not do it for mpich2, that is why I am sticking with mpich1.
> > http://www.ceglug.org/index.php/cluster/3-createcluster?start=1
> > But I receive the following error from make.Actually it is end of the message.
> > ** Testing if C application can use both automatic and manual logging together
> > /home/mpiuser/mpich-1.2.7p1/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES  -I/home/mpiuser/mpich-1.2.7p1/include   -c cpilog.c
> > /home/mpiuser/mpich-1.2.7p1/bin/mpicc  -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES   -o cpilog cpilog.o -L/home/mpiuser/mpich-1.2.7p1/lib -llmpe -lmpe   -lm
> > ** C application can use both automatic and manual logging together
> > ./sbin/mpeinstall: 493: ./sbin/install-package: not found
> > Installed MPE in /home/mpiuser/mpich-1.2.7p1
> > /home/mpiuser/mpich-1.2.7p1/sbin/mpeuninstall may be used to remove the installation
> > Finished making MPE Profiling Libraries
> > make --no-print-directory mpi-utils
> > gcc  -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -c /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c -I./ -o serv_p4.o
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:204: error: conflicting types for ‘getline’
> > /usr/include/stdio.h:671: note: previous declaration of ‘getline’ was here
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: In function ‘sendline’:
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1295: warning: format not a string literal and no format arguments
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: At top level:
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1306: error: conflicting types for ‘getline’
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: In function ‘getline’:
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1309: error: argument ‘str’ doesn’t match prototype
> > /usr/include/stdio.h:671: error: prototype declaration
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1309: error: argument ‘len’ doesn’t match prototype
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1309: error: number of arguments doesn’t match prototype
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: In function ‘failure’:
> > /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1348: warning: format not a string literal and no format arguments
> > make[2]: *** [serv_p4.o] Error 1
> > bin/mpicc -o /home/mpiuser/mpich-1.2.7p1/bin/mpichversion /home/mpiuser/mpich-1.2.7p1/util/mpichversion.c
> > /home/mpiuser/mpich-1.2.7p1/util/mpichversion.c: In function ‘main’:
> > /home/mpiuser/mpich-1.2.7p1/util/mpichversion.c:67: warning: incompatible implicit declaration of built-in function ‘exit’
> > rm -f /home/mpiuser/mpich-1.2.7p1/bin/mpireconfig.dat
> > creating util/mympiinstall
> > Completed build of MPI.  Check the output for errors Also try executing 'make
> > testing' in examples/test (This relies on mpirun, which currently works for
> > many but not all systems.  For workstation networks, mpirun requires that you
> > first setup a "machines" file listing the machines available; this is covered
> > in the installation manual.)
> > Send bugs and comments to mpi-bugs at mcs.anl.gov
> > Bugs and comments in the C++ support should be sent to mpi2cpp-devel at osl.iu.edu
> > Bugs and comments in the MPI-IO support should be sent to
> > romio-maint at mcs.anl.gov
> > With any bug report, please send
> >         The version of MPICH (e.g., 1.2.7)
> > The output of running your program with the -mpiversion argument
> > (e.g., mpirun -np 1 a.out -mpiversion)
> > The output of
> >         uname -a
> > for your system.  If you are on an SGI system, also
> >         hinv
> > If the problem is with a script like configure or mpirun, run the script with
> > the -echo argument (e.g., mpirun -echo -np 4 a.out )
> > If you are using a network of workstations, also send the output of
> > bin/tstmachines.
> > Please help me.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101123/a89ab6be/attachment.htm>
