[mpich-discuss] seek help on mpi- mpich
Jayesh Krishna jayesh at mcs.anl.gov
Sun Nov 21 11:35:58 CST 2010
>> In fact, the worker should print something to show ...
 In the output below I can see the message from worker for both cases 2 & 3 . Can you explain in detail the issue that you see with your setup ?
 You might also want to run "mpiexec -machinefile mf.txt -n 2 hostname" to see the hosts where the processes get launched.
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Sat, 20 Nov 2010 23:14:56 -0600 (CST)
Subject: Re: seek help on mpi- mpich
sorry some correction..
On Sun, Nov 21, 2010 at 1:09 PM, UmmuRifqi <ummurifqi09 at gmail.com> wrote:
> Hello again, sorry for late reply (being involved with some other
> not-related things)
> here is my output:
> 1. ====== with machinefile, if I dont specify the no of processors
> C:\~\~\~\myPar>mpiexec -machinefile mf.txt <http://mf.pg> hellocluster.exe
> Master process rank#0 sending message ~Hello, world
> 2. ======= if I specify no of processors
> C:\~\~\~\myPar>mpiexec -machinefile mf.txt <http://mf.pg> -np 2
> hellocluster.exe
> Worker with rank#1 receives message ~Hello, world from master
> 3. ======= without mentioning processor a.k.a multithreading.
> C:\~\~\~\myPar>mpiexec -np 2 hellocluster.exe
> as we can see, the output 2 is arguable because I don't see whether the
> node machine is working or not.
> because as output 3, the command may ignore the machine file(assumed by me
> regarding to non reaction of worker's node).
   In fact, the worker should print something to show the message received
by it (as in the program code)
> how can I verify that the worker's node is executing the processes assigned
> by master.
> Can we see it on the worker's node monitor? or it only can be seen on
> master's node?
> the right-click " run as administrator" I regard to when I want to open DOS
> command prompt, there will always 2 optional as previous image I sent you.
> so I choose administrator and once again enter the password. is that what
> you mean?
> thanks.
> On Tue, Nov 16, 2010 at 11:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>> Hi,
>> >> mpiexec -machinefile mf.txt helloCluster.exe
>>  If you do not specify the number of MPI processes only 1 MPI process is
>> launched. Use the "-n" option to specify the number of MPI processes
>> required for the job (mpiexec -n 2 -machinefile mf.txt helloCluster.exe).
>> >> ...when I right-click to choose "run as administrator" ...
>>  Which program are you referring ? Are you running all the commands from
>> an administrator command prompt (In Vista even a user with admin privileges
>> opens a command prompt it is not an elevated command prompt. In Vista to
>> open an administrator/elevated command prompt right-click on the command
>> prompt icon and select "run as administrator". Run all the commands on Vista
>> from an administrator command prompt and see if it works)?
>> Regards,
>> Jayesh
>> From: UmmuRifqi <ummurifqi09 at gmail.com>
>> Sent: Tue, 16 Nov 2010 02:24:35 -0600 (CST)
>> Hello and thank for your suppot..
>> yes. I tried create new user (mpiuser) with administrator privilege, the
>> other are other windows user with limited privilege.
>> then I registered mpiuser using mpiexec with password. but the validate
>> part
>> fail as following error.
>> >Error during CryptEncrypt: Unknown failure 234
>> > unable to encrypt the password for the validate command.
>> but it can lauch mpi locally but only run on master node (which is in this
>> case xp machine) if >>mpiexec -machinefile mf.txt helloCluster.exe
>> fyi, when I right-click to choose "run as administrator" there are two
>> option user provided.
>>  either to choose (domain\username) or administrator. (see the attachment:
>> image on run as administrator option). This is also happen to my vista
>> machine.
>> i am using xp sp2, and vista home premiun sp2
>> additionally, I also have read your comment in mpich-discuss but  cannot
>> refer the documentation (usually suggested by you on the installation
>> guide)
>> at
>> http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
>> it is not available.
>> On Tue, Nov 16, 2010 at 4:50 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
>> wrote:
>> > Hi,
>> > >> so, i am using the second administrator on both machine (they have
>> the
>> > same passwd) to register...
>> >  As I mentioned before try registering a username different from the
>> > "Administrator".
>> >  Please follow the steps below,
>> > 1) On the XP machine & the Vista machine create a user, "mpiuser", with
>> the
>> > same password (As I mentioned before do not register "Administrator"
>> with
>> > mpiexec).
>> > 2) Register & Validate "mpiuser" on each machine.
>> > 3) Test whether the user, "mpiuser" can launch MPI processes locally on
>> > each machine.
>> > 4) Run your job across the XP & Vista machines and see if it works.
>> > Regards,
>> > Jayesh
>> > Sent: Mon, 15 Nov 2010 14:43:00 -0600 (CST)
>> > Hello again,
>> > Yeah,  At the first place I've done that (the same windows user/same
>> > password with administrator privileges both on XP and Vista).
>> > As I emailed to you,
>> >  in XP, there are 2 windows user 1) hpxp (user with administrator
>> > privileges)  2) Administrator (administrator privileges)
>> >  in Vista, There are also 2 windows user 1) user (administrator
>> > so, i am using the second administrator on both machine (they have the
>> same
>> > passwd) to register username/password with mpiexec which as follows:
>> > > the error after >>mpiexec -validate  // done on XP
>> > > Microsoft Windows XP [Version 5.1.2600]
>> > > (C) Copyright 1985-2001 Microsoft Corp.
>> > > C:\Documents and Settings\Administrator>mpiexec -remove
>> > > Account and password removed from the Registry.
>> > > C:\Documents and Settings\Administrator>mpiexec -register
>> > > account (domain\user) [HPXP\Administrator]: Administrator
>> > > password: **
>> > > confirm password: **
>> > > Password encrypted into the Registry.
>> > > C:\Documents and Settings\Administrator>mpiexec -validate
>> > > the error after >>mpiexec -validate Administrator/** //done on Vista
>> > > Microsoft Windows XP [Version 6.0.6002]
>> > > Copyright (C) 2006 Microsoft Corp. All right reserved.
>> > > C:\Users\Administrator>mpiexec -remove
>> > > C:\Users\Administrator>mpiexec -register
>> > > password:
>> > > confirm password:
>> > > C:\Users\Administrator>mpiexec -validate
>> > Eventhough I cannot validate, but I can run the MPI program from 1 node
>> or
>> > multithreading.
>> > result :
>> > C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec
>> > in both machine.
>> > The firewalls are all off.
>> > Currently, I tried to change the administrator privileges on user hpxp
>> on
>> > XP, but it disables me to change the role to user privilege, so that I
>> only
>> > have 1 administrator privileges. in vista, it can be done easily, will
>> let
>> > you know later.
>> > before that,  do you have any suggestions please?
>> > thanks Mr Jayesh.
>> > On Mon, Nov 15, 2010 at 11:20 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
>> > wrote:
>> > > Hi,
>> > >  Is "myuser" a valid Windows user ? You need to register an existing
>> > > Windows username/password with mpiexec.
>> > >  Please create a windows user (The same username/password on XP &
>> Vista
>> > > machines) with administrator privileges and try registering that
>> > > username/password with mpiexec. Let us know the results.
>> > > Regards,
>> > > Jayesh
>> > > Sent: Sun, 14 Nov 2010 20:41:00 -0600 (CST)
>> > > Hello again Mr Jayesh.
>> > > I've removed and created new account other than Administrator as below
>> > > myuser), (by mpiexec -register)
>> > > then it resulted the same one, I can register but could'nt validate
>> them.
>> > > FYI, in my XP machine, there are 2 accounts of administrator role..1)
>> > > Administrator 2) hpxp  (we can see it on window welcome screen)
>> > > also in my vista machine, there are also 2 accounts of administrator.
>> > > I installed the mPICH2  'everyone' not 'just me' features.
>> > > the output on my XP machine:
>> > > -register
>> > > account (domain\user) [HPXP\Administrator]: myuser
>> > > password:
>> > > confirm password:
>> > > -validate
>> > > help me please. Thanks.
>> > > On Thu, Nov 11, 2010 at 10:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
>> > > wrote:
>> > > > Hi,
>> > > >  Can you try registering/validating a username (an admin user) other
>> > than
>> > > > "Administrator" ?
>> > > > Regards,
>> > > > Jayesh
>> > > > Sent: Wed, 10 Nov 2010 22:25:46 -0600 (CST)
>> > > > Hello again,
>> > > > step 1-2 done successfully.
>> > > > step 3 unsuccessful because when to validate the username/password,
>> > there
>> > > > is
>> > > > an error..it hang and never return the command prompt until I press
>> > > ctrl-C
>> > > > after several minutes waiting.
>> > > > password:
>> > > > confirm password:
>> > > > password:
>> > > > confirm password:
>> > > > how it can be solved , attached is my smpd.log
>> > > > thanks Mr. Jayesh.
>> > > > On Thu, Nov 11, 2010 at 9:20 AM, UmmuRifqi <ummurifqi09 at gmail.com>
>> > > wrote:
>> > > > > Thanks for the feedback & suggestion.
>> > > > > Just arrived the lab, I'll try it out and will let you know the
>> > result.
>> > > > > On Wed, Nov 10, 2010 at 11:15 PM, Jayesh Krishna <
>> > > > >wrote:
>> > > > >> Hi,
>> > > > >>  Please try the following,
>> > > > >> 1) Create a machinefile, mf.txt, with the following contents,
>> > > > >> # XP node
>> > > > >> 192.168.33.69:1
>> > > > >> # Vista node
>> > > > >> 192.168.33.68:1
>> > > > >> 2) Make sure helloCluster.exe is available in C:\temp on both the
>> > > > >> machines.
>> > > > >> 3) Remove any usernames registered on the machines using the
>> > "-remove"
>> > > > >> option of mpiexec ("mpiexec -remove" on both the machines) and
>> > > > re-register a
>> > > > >> username/password available on both the machines (same user -
>> with
>> > the
>> > > > same
>> > > > >> password - should be available on both the machines) using the
>> > > > "-register"
>> > > > >> option of mpiexec ("mpiexec -register" on both the machines).
>> > > > >>   Validate the username/password registered using the "-validate"
>> > > option
>> > > > >> of mpiexec ("mpiexec -validate" on both the machines).
>> > > > >> 4) Try running helloCluster.exe on both machines (XP & Vista)
>> > locally
>> > > > >> (mpiexec -n 2 helloCluster.exe)
>> > > > >> 5) Try running a non-MPI program like hostname on both the
>> machines
>> > > > >> (mpiexec -n 2 -machinefile mf.txt hostname)
>> > > > >> 6) Now try running helloCluster.exe on the cluster (mpiexec -n 2
>> > > > >> -machinefile mf.txt c:\temp\helloCluster.exe)
>> > > > >> (PS: If you get an error message please copy-paste it in your
>> email)
>> > > > >> Regards,
>> > > > >> Jayesh
>> > > > >> To: jayesh at mcs.anl.gov
>> > > > >> Sent: Wed, 10 Nov 2010 02:43:14 -0600 (CST)
>> > > > >> Subject: seek help on mpi- mpich
>> > > > >> Hello,
>> > > > >> I am new to mpich/mpi and I learn this by myself from the
>> Internet
>> > to
>> > > do
>> > > > >> my
>> > > > >> research.
>> > > > >> I've review the discussion mpich-discuss (
>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html)
>> > > > >> been following the thread after thread and decided to email you
>> if
>> > you
>> > > > >> could
>> > > > >> help me on windows clustering using mpich2.
>> > > > >> I'm doing on XP and Vista machine, 32 bit, mpich2 version
>> > > > >> mpich2-1.2.1p1-win-ia32, it works on hello world program  for
>> single
>> > > > node
>> > > > >> (stand alone), but it does not run on multinode ( the nest
>> machine).
>> > > it
>> > > > >> says
>> > > > >> -machinefile mf.pg helloCluster.exe
>> > > > >> the firewall already off. the machine file contains
>> > > > >> 192.168.33.69 0 /Documents and Settings/Administrator/My
>> > > > Documents/myPar/
>> > > > >> this is XP machine
>> > > > >> 192.168.33.68 1
>> > > > >> /Users/Administrator/Documents/myPar/
>> > > > >> #this
>> > > > >> is Vista machine
>> > > > >> please help me. what else considering i have to take to enable
>> the
>> > > > >> interaction between the nodes because after this i need to do it
>> on
>> > > 3,5,
>> > > > 8
>> > > > >> machines.
>> > > > >> thank you.
