[mpich-discuss] Fw: install issue
Pavan Balaji balaji at mcs.anl.gov
Sat Nov 20 15:25:54 CST 2010
Did you try this?
> If you want to install from source, you'll need to use:
> % ./configure --enable-shared
> % make
> % make install
Pavan Balaji @ iPhone
(Big fingers. Small email.)
On Nov 20, 2010, at 10:48 AM, hamed amini <hamedamini_84 at yahoo.com> wrote:
> ----- Forwarded Message ----
> From: hamed amini <hamedamini_84 at yahoo.com>
> To: Pavan Balaji <balaji at mcs.anl.gov>
> Sent: Saturday, November 20, 2010 20:04:18
> Subject: Re: [mpich-discuss] install issue
> Version is
> /*hamed at hamed:~$ mpich2version
> MPICH2 Version:        1.3
> MPICH2 Release date:    Fri Oct 22 14:50:07 CDT 2010
> MPICH2 Device:        ch3:nemesis
> MPICH2 configure:     --enable-sharedlib=gcc
> MPICH2 CC:     gcc    -O2
> MPICH2 CXX:     c++   -O2
> MPICH2 F77:     gfortran   -O2
> MPICH2 FC:     f95   -O2*/
> But in usr/local/lib no libmpich.so(shared dynamic library) created.
> Tanks
> ----- Original Message ----
> From: Pavan Balaji <balaji at mcs.anl.gov>
> To: mpich-discuss at mcs.anl.gov
> Cc: hamed amini <hamedamini_84 at yahoo.com>
> Sent: Saturday, November 20, 2010 19:31:03
> Which version of MPICH2 are you using? The easiest method is:
> % sudo apt-get install mpich2
> % make
> % make install
>  -- Pavan
> On 11/20/2010 03:36 AM, hamed amini wrote:
>> Dear all,
>> I want to install mpoich2 in on ubuntu machine (x86_64) with a shared library
>> is
>> one that is dynamically loadable.
>> I installed mpich2 by this way:
>> ./configure --enable-sharedlib=gcc
>> make
>> make install
>> But in usr/local/lib no libmpich.so(shared dynamic library) created (
> libmich.a
>> create).
>> Do you have any suggestion?
>> Best regards,
>> Hamed
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101120/accaab7d/attachment.htm>
