[mpich-discuss] working mpi, now launch failure
Jayesh Krishna jayesh at mcs.anl.gov
Fri Nov 19 10:33:56 CST 2010
 Can you copy-paste (don't re-type) the mpiexec command (mpiexec -n 2 hostname) and the output in your email?
 Also try re-registering your username/password with mpiexec by following the steps below,
# Remove any registered username/password using the "-remove" option of mpiexec (Type "mpiexec -remove" at the command prompt)
# Register your username/password using the "-register" option of mpiexec (Type "mpiexec -register" and provide your username/password when prompted)
# Validate that the registered username/password is valid/correct using the "-validate" option of mpiexec (Type "mpiexec -validate" at the command prompt)
 Please copy-paste (don't re-type) the commands and the outputs of the commands listed above. Let us know the results.
(PS: It is important that we see the exact command line and the complete output for debugging your problem. So copy-paste the commands and the outputs in your email)
jayesh
----- Original Message -----
To: 'Jayesh Krishna' <jayesh at mcs.anl.gov>
Sent: Fri, 19 Nov 2010 10:24:30 -0600 (CST)
Subject: RE: [mpich-discuss] working mpi, now launch failure
Jayesh,
That is the only line of output (it repeats itself once).  I can't run any other programs.
-Emil
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, November 17, 2010 3:15 PM
To: Emil Sandoz-Rosado
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] working mpi, now launch failure
 Is that the only output message from mpiexec (Just a line "launch failed: FAIL" ?)?
 Can you run a non-MPI program with mpiexec (mpiexec -n 2 hostname)? Can you run cpi.exe in the MPICH2 examples directory (mpiexec -n 2 "c:\Program Files\MPICH2\examples\cpi.exe")?
Jayesh
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Wed, 17 Nov 2010 14:11:28 -0600 (CST)
Jayesh,
This is what I put in and I get the same error.
command:
> mpiexec -n 2 C:\Users\Emil\Documents\LAAMPS\lmp_win_mpi.exe -in in.graphene
error:
launch failed: FAIL
-Emil
Quoting Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
>  Try providing the complete path to the executable (lmp_win_mpi.exe)
>  and let us know if it works.
>  If you still have problems copy-paste the command and the error
> message in your email.
> Regards,
> Jayesh
> From: Emil Sandoz-Rosado <ejs2166 at columbia.edu>
> To: mpich-discuss at mcs.anl.gov
> Sent: Tue, 16 Nov 2010 16:15:16 -0600 (CST)
> Subject: [mpich-discuss] working mpi, now launch failure
> Jayesh,
> I was able to get simulations running based on your suggestions.  I shut the
> machine down and then rebooted to run new simulations.  Now when I attempt
> to run mpiexec -n 2 lmp_win_mpi -in in.graphene, I get "launch failed: FAIL"
> Smpd -status indicates smpd is running fine on the machine.
> Any suggestions?
> -Emil
> mpich-discuss mailing list
