[mpich-discuss] seek help on mpi- mpich
Jayesh Krishna jayesh at mcs.anl.gov
Tue Nov 16 09:49:38 CST 2010
>> mpiexec -machinefile mf.txt helloCluster.exe
 If you do not specify the number of MPI processes only 1 MPI process is launched. Use the "-n" option to specify the number of MPI processes required for the job (mpiexec -n 2 -machinefile mf.txt helloCluster.exe).
>> ...when I right-click to choose "run as administrator" ...
 Which program are you referring ? Are you running all the commands from an administrator command prompt (In Vista even a user with admin privileges opens a command prompt it is not an elevated command prompt. In Vista to open an administrator/elevated command prompt right-click on the command prompt icon and select "run as administrator". Run all the commands on Vista from an administrator command prompt and see if it works)?
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Tue, 16 Nov 2010 02:24:35 -0600 (CST)
Subject: Re: seek help on mpi- mpich
Hello and thank for your suppot..
yes. I tried create new user (mpiuser) with administrator privilege, the
other are other windows user with limited privilege.
then I registered mpiuser using mpiexec with password. but the validate part
fail as following error.
>Error during CryptEncrypt: Unknown failure 234
> unable to encrypt the password for the validate command.
but it can lauch mpi locally but only run on master node (which is in this
case xp machine) if >>mpiexec -machinefile mf.txt helloCluster.exe
fyi, when I right-click to choose "run as administrator" there are two
option user provided.
 either to choose (domain\username) or administrator. (see the attachment:
image on run as administrator option). This is also happen to my vista
machine.
i am using xp sp2, and vista home premiun sp2
additionally, I also have read your comment in mpich-discuss but  cannot
refer the documentation (usually suggested by you on the installation guide)
at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
it is not available.
On Tue, Nov 16, 2010 at 4:50 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
> >> so, i am using the second administrator on both machine (they have the
> same passwd) to register...
>  As I mentioned before try registering a username different from the
> "Administrator".
>  Please follow the steps below,
> 1) On the XP machine & the Vista machine create a user, "mpiuser", with the
> same password (As I mentioned before do not register "Administrator" with
> mpiexec).
> 2) Register & Validate "mpiuser" on each machine.
> 3) Test whether the user, "mpiuser" can launch MPI processes locally on
> each machine.
> 4) Run your job across the XP & Vista machines and see if it works.
> Regards,
> Jayesh
> From: UmmuRifqi <ummurifqi09 at gmail.com>
> Sent: Mon, 15 Nov 2010 14:43:00 -0600 (CST)
> Hello again,
> Yeah,  At the first place I've done that (the same windows user/same
> password with administrator privileges both on XP and Vista).
> As I emailed to you,
>  in XP, there are 2 windows user 1) hpxp (user with administrator
> privileges)  2) Administrator (administrator privileges)
>  in Vista, There are also 2 windows user 1) user (administrator
> so, i am using the second administrator on both machine (they have the same
> passwd) to register username/password with mpiexec which as follows:
> > the error after >>mpiexec -validate  // done on XP
> > Microsoft Windows XP [Version 5.1.2600]
> > (C) Copyright 1985-2001 Microsoft Corp.
> > C:\Documents and Settings\Administrator>mpiexec -remove
> > Account and password removed from the Registry.
> > C:\Documents and Settings\Administrator>mpiexec -register
> > account (domain\user) [HPXP\Administrator]: Administrator
> > password: **
> > confirm password: **
> > Password encrypted into the Registry.
> > C:\Documents and Settings\Administrator>mpiexec -validate
> > the error after >>mpiexec -validate Administrator/** //done on Vista
> > Microsoft Windows XP [Version 6.0.6002]
> > Copyright (C) 2006 Microsoft Corp. All right reserved.
> > C:\Users\Administrator>mpiexec -remove
> > C:\Users\Administrator>mpiexec -register
> > password:
> > confirm password:
> > C:\Users\Administrator>mpiexec -validate
> Eventhough I cannot validate, but I can run the MPI program from 1 node or
> multithreading.
> result :
> C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec
> > >> Master process rank#0 sending message ~Hello, world
> in both machine.
> The firewalls are all off.
> Currently, I tried to change the administrator privileges on user hpxp on
> XP, but it disables me to change the role to user privilege, so that I only
> have 1 administrator privileges. in vista, it can be done easily, will let
> you know later.
> before that,  do you have any suggestions please?
> thanks Mr Jayesh.
> On Mon, Nov 15, 2010 at 11:20 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
> wrote:
> > Hi,
> >  Is "myuser" a valid Windows user ? You need to register an existing
> > Windows username/password with mpiexec.
> >  Please create a windows user (The same username/password on XP & Vista
> > machines) with administrator privileges and try registering that
> > username/password with mpiexec. Let us know the results.
> > Regards,
> > Jayesh
> > Sent: Sun, 14 Nov 2010 20:41:00 -0600 (CST)
> > Hello again Mr Jayesh.
> > I've removed and created new account other than Administrator as below (
> > myuser), (by mpiexec -register)
> > then it resulted the same one, I can register but could'nt validate them.
> > FYI, in my XP machine, there are 2 accounts of administrator role..1)
> > Administrator 2) hpxp  (we can see it on window welcome screen)
> > also in my vista machine, there are also 2 accounts of administrator.
> > I installed the mPICH2  'everyone' not 'just me' features.
> > the output on my XP machine:
> > -register
> > account (domain\user) [HPXP\Administrator]: myuser
> > password:
> > confirm password:
> > -validate
> > help me please. Thanks.
> > On Thu, Nov 11, 2010 at 10:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
> > wrote:
> > > Hi,
> > >  Can you try registering/validating a username (an admin user) other
> than
> > > "Administrator" ?
> > > Regards,
> > > Jayesh
> > > Sent: Wed, 10 Nov 2010 22:25:46 -0600 (CST)
> > > Hello again,
> > > step 1-2 done successfully.
> > > step 3 unsuccessful because when to validate the username/password,
> there
> > > is
> > > an error..it hang and never return the command prompt until I press
> > ctrl-C
> > > after several minutes waiting.
> > > password:
> > > confirm password:
> > > password:
> > > confirm password:
> > > how it can be solved , attached is my smpd.log
> > > thanks Mr. Jayesh.
> > > On Thu, Nov 11, 2010 at 9:20 AM, UmmuRifqi <ummurifqi09 at gmail.com>
> > wrote:
> > > > Thanks for the feedback & suggestion.
> > > > Just arrived the lab, I'll try it out and will let you know the
> result.
> > > > On Wed, Nov 10, 2010 at 11:15 PM, Jayesh Krishna <jayesh at mcs.anl.gov
> > > >wrote:
> > > >> Hi,
> > > >>  Please try the following,
> > > >> 1) Create a machinefile, mf.txt, with the following contents,
> > > >> # XP node
> > > >> 192.168.33.69:1
> > > >> # Vista node
> > > >> 192.168.33.68:1
> > > >> 2) Make sure helloCluster.exe is available in C:\temp on both the
> > > >> machines.
> > > >> 3) Remove any usernames registered on the machines using the
> "-remove"
> > > >> option of mpiexec ("mpiexec -remove" on both the machines) and
> > > re-register a
> > > >> username/password available on both the machines (same user - with
> the
> > > same
> > > >> password - should be available on both the machines) using the
> > > "-register"
> > > >> option of mpiexec ("mpiexec -register" on both the machines).
> > > >>   Validate the username/password registered using the "-validate"
> > option
> > > >> of mpiexec ("mpiexec -validate" on both the machines).
> > > >> 4) Try running helloCluster.exe on both machines (XP & Vista)
> locally
> > > >> (mpiexec -n 2 helloCluster.exe)
> > > >> 5) Try running a non-MPI program like hostname on both the machines
> > > >> (mpiexec -n 2 -machinefile mf.txt hostname)
> > > >> 6) Now try running helloCluster.exe on the cluster (mpiexec -n 2
> > > >> -machinefile mf.txt c:\temp\helloCluster.exe)
> > > >> (PS: If you get an error message please copy-paste it in your email)
> > > >> Regards,
> > > >> Jayesh
> > > >> To: jayesh at mcs.anl.gov
> > > >> Sent: Wed, 10 Nov 2010 02:43:14 -0600 (CST)
> > > >> Subject: seek help on mpi- mpich
> > > >> Hello,
> > > >> I am new to mpich/mpi and I learn this by myself from the Internet
> to
> > do
> > > >> my
> > > >> research.
> > > >> I've review the discussion mpich-discuss (
> > http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html)
> > > >> been following the thread after thread and decided to email you if
> you
> > > >> could
> > > >> help me on windows clustering using mpich2.
> > > >> I'm doing on XP and Vista machine, 32 bit, mpich2 version
> > > >> mpich2-1.2.1p1-win-ia32, it works on hello world program  for single
> > > node
> > > >> (stand alone), but it does not run on multinode ( the nest machine).
> > it
> > > >> says
> > > >> -machinefile mf.pg helloCluster.exe
> > > >> the firewall already off. the machine file contains
> > > >> 192.168.33.69 0 /Documents and Settings/Administrator/My
> > > Documents/myPar/
> > > >> this is XP machine
> > > >> 192.168.33.68 1
> > > >> /Users/Administrator/Documents/myPar/
> > > >> #this
> > > >> is Vista machine
> > > >> please help me. what else considering i have to take to enable the
> > > >> interaction between the nodes because after this i need to do it on
> > 3,5,
> > > 8
> > > >> machines.
> > > >> thank you.
