[mpich-discuss] i m trying it in a MinGW VM gcc
Jayesh Krishna jayesh at mcs.anl.gov
Mon Nov 15 08:47:21 CST 2010
 Or you can install Cygwin (Cygwin provides the POSIX runtime environment that MinGW does not) and use gcc from Cygwin to compile/install MPICH2.
-Jayesh
----- Original Message -----
Sent: Sun, 14 Nov 2010 16:19:21 -0600 (CST)
Subject: Re: [mpich-discuss] i m trying it in a MinGW VM gcc
Your c.txt indicates that Fortran and C++ binding are actually configued OK.
The problem is that Nemesis failed to configure because of missing features
configure: error: cannot support shared memory:  need either sysv shared memory functions or mmap in order to support shared memory
configure: error: channels/nemesis configure failed
configure: error: src/mpid/ch3 configure failed
You can either try configuring mpich2 with --with-device=ch3:sock (not sure if
it will work or not) which does not have shared memory support or install window
binary and use it with mingw gcc.
A.Chan
> i m trying it in a MinGW VM gcc. it worked perfectly on ubuntu 9 with
> gcc but failed with fortran c++.
> thank ye
> mpich-discuss mailing list
