[mpich-discuss] Trouble with PARPACK
Jayesh Krishna jayesh at mcs.anl.gov
Fri Nov 12 15:39:41 CST 2010
 It is difficult to guess from the error message below. It looks to me that one of the MPI processes (rank 0) crashed (eg: segfault).
 It might be useful to attach gdb to process with rank=0 (Let program wait till you externally attach gdb to the process and continue).
Jayesh
----- Original Message -----
From: Christopher R Boucher <chrisboucher at WPI.EDU>
To: Jayesh Krishna <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Fri, 12 Nov 2010 14:52:00 -0600 (CST)
Subject: RE: [mpich-discuss] Trouble with PARPACK
The complete error message is as shown below:
Fatal error in MPI_Bcast: Other MPI error, error stack:
MPI_Bcast(786)............................: MPI_Bcast(buf=011F9260, count=2, MPI_DOUBLE, root=0, MPI_COMM_WORLD) failed
MPIR_Bcast(198)...........................:
MPIC_Recv(81).............................:
MPIC_Wait(270)............................:
MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Sock_wait(2603).....................: The specified network name is no longer available. (errno 64)Fatal error in MPI_Bcast: Other MPI error, error stack:
MPI_Bcast(786)............................: MPI_Bcast(buf=01339260, count=2, MPI_DOUBLE, root=0, MPI_COMM_WORLD) failed
MPI_Bcast(786)............................: MPI_Bcast(buf=012D9260, count=2, MPI_DOUBLE, root=0, MPI_COMM_WORLD) failed
job aborted:
rank: node: exit code[: error message]
0: Chris-PC: 1: process 0 exited without calling finalize
1: Chris-PC: 1: Fatal error in MPI_Bcast: Other MPI error, error stack:
2: Chris-PC: 1: Fatal error in MPI_Bcast: Other MPI error, error stack:
3: Chris-PC: 1: Fatal error in MPI_Bcast: Other MPI error, error stack:
Sent: Friday, November 12, 2010 3:51 PM
Cc: Boucher, Christopher R
Subject: Re: [mpich-discuss] Trouble with PARPACK
 Can you copy-paste the complete error message in your email ?
Jayesh
Sent: Fri, 12 Nov 2010 14:30:14 -0600 (CST)
Subject: [mpich-discuss] Trouble with PARPACK
 Hello, I've been trying to build PARPACK using MPICH2 and MinGW. Currently my program, which uses several PARPACK routines, compiles and executes properly; however, when I try to run with four or more processes I get the following error:
(Using 4 processes)
This error involving MPI_Bcast repeats itself three more times. The error appears to occur when my program calls the PARPACK routine "pznaupd".
If anyone has experience with PARPACK, or has an idea of what may be causing this error, please let me know. Thank you!
Sincerely,
Christopher Boucher
mpich-discuss mailing list
