[mpich-discuss] networking problems with mpich2-1.3
Saurav Pathak saurav at sas.upenn.edu
Thu Nov 11 10:45:49 CST 2010
Manhui,
Thank you the solution, which partially solved my problem.  From comp2,
I could run cpi cleanly. But from comp1, I get this message:
[proxy:0:1 at comp2] HYDU_sock_connect
(/home/saurav/local/src/mpich2-1.3/src/pm/hydra/utils/sock/sock.c:151):
connect error (Connection timed out)
[proxy:0:1 at comp2] main
(/home/saurav/local/src/mpich2-1.3/src/pm/hydra/pm/pmiserv/pmip.c:204):
unable to connect to server comp1 at port 56740 (check for firewalls!)
I have looked at iptables -L, and hosts.deny on comp1, but I can't seem
to find the problem.
When on comp2 I try "nmap comp1" I get an error message:
Note: Host seems down. If it is really up, but blocking our ping probes,
try -PN
When I do use the -PN option, I get exactly the same analogous result I
get running  "nmap comp2" on comp1.  So I am guessing there is some
network configuration on comp1 that I haven't been able to place my
finger on.
Saurav
Manhui Wang wrote:
> Saurav,
> I met the the similar problem before, but it was resolved by changing
> /etc/hosts. See previous discussion:
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html
> Best wishes,
> Manhui
> Saurav Pathak wrote:
>> Hi,
>> I am trying to set up two computers for running MPI.  I have compiled
>> mpich2-1.3 from source, and have run the following without any incident
>> on both machines (Ubuntu 9.04):
>> mpiexec -n 2 ./cpi
>> But when I try to run it on two computers (comp1 and comp2), then I run
>> into the following problems.
>> On comp1 when I run "mpiexec -f hosts -n 2 ./cpi", I get the following
>> error.
>> unable to connect to server comp1 at port 38203 (check for firewalls!)
>> I have checked for firewalls via "sudo  /sbin/iptables -L" on both
>> computers, and there are no firewalls.
>> When I execute "mpiexec -f hosts -n 2 ./cpi" on comp2, I get the
>> following output:
>> Process 1 of 2 is on comp2
>> Process 0 of 2 is on comp1
>> Fatal error in PMPI_Bcast: Other MPI error, error stack:
>> PMPI_Bcast(1306)..................: MPI_Bcast(buf=0x7ffff6b7465c,
>> count=1, MPI_INT, root=0, MPI_COMM_WORLD) failed
>> MPIR_Bcast_impl(1150).............:
>> MPIR_Bcast_intra(1021)............:
>> MPIR_Bcast_binomial(187)..........:
>> MPIC_Send(66).....................:
>> MPIC_Wait(528)....................:
>> MPIDI_CH3I_Progress(333)..........:
>> MPID_nem_mpich2_blocking_recv(906):
>> MPID_nem_tcp_connpoll(1861).......: Communication error with rank 1:
>> APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
>> It looks like a networking issue, but I can't figure out what it is.  I
>> can ssh and rsh from one machine to the other without the need for a
>> password and run commands (e.g, I can run "ssh comp2 hostname" on comp1
>> and vice versa).
>> I seem to be at a dead end.  Any help on this issue will be greatlt
>> appreciated.
>> Saurav
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
