[mpich-discuss] issue setting process-core mapping with hydra
sreeram potluri potluri at cse.ohio-state.edu
Wed Nov 10 20:09:18 CST 2010
Thanks Pavan.
Sreeram Potluri
On Wed, Nov 10, 2010 at 8:37 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> On 11/10/2010 12:14 PM, sreeram potluri wrote:
>> The error output I had observed was because debug mode was enabled
>> inside hwloc. It appears that the hwloc debug mode is enabled by default
>> when we do an svn checkout. This does not happen if we do an export
>> instead. I believe you did an export and hence did not see the debug
>> output.
> Ugh. That's gross. I don't know why hwloc does that. I've fixed it in the
> copy within MPICH2:
> https://trac.mcs.anl.gov/projects/mpich2/changeset/7435
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101110/be04072f/attachment.htm>
