[mpich-discuss] *** glibc detected *** mpiexec: munmap_chunk(): invalid pointer: 0x00007fff1d578184 ***
Jeff Hammond jhammond at mcs.anl.gov
Sat Nov 6 09:31:32 CDT 2010
MPICH2 trunk updated yesterday and compiled with GCC 4.5 works fine
for both MPI tests that failed before so it seems that the error was
fixed after the 1.3 release.
Jeff
On Sat, Nov 6, 2010 at 9:11 AM, Jeff Hammond <jhammond at mcs.anl.gov> wrote:
> Sorry for not including this last time, but valgrind seems to indicate
> the problem is in Hydra.
> Jeff
> ==1525== Invalid free() / delete / delete[]
> ==1525==    at 0x4C243AF: free (in
> /usr/lib64/valgrind/amd64-linux/vgpreload_memcheck.so)
> ==1525==    by 0x421983: HYDT_bsci_finalize (bsci_finalize.c:21)
> ==1525==    by 0x40A07E: HYD_pmci_finalize (pmiserv_pmci.c:371)
> ==1525==    by 0x40537E: main (mpiexec.c:327)
> ==1525==  Address 0x7ff000149 is on thread 1's stack
> ==1525==
> ==1525== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 2 from 1)
> ==1525== malloc/free: in use at exit: 16,396 bytes in 3 blocks.
> ==1525== malloc/free: 1,698 allocs, 1,696 frees, 118,394 bytes allocated.
> ==1525== For counts of detected errors, rerun with: -v
> ==1525== searching for pointers to 3 not-freed blocks.
> ==1525== checked 184,080 bytes.
> ==1525==
> ==1525==
> ==1525== 6 bytes in 1 blocks are still reachable in loss record 1 of 3
> ==1525==    at 0x4C256AE: malloc (in
> ==1525==    by 0x5EB1261: strdup (in /lib64/libc-2.9.so)
> ==1525==    by 0x41EA50: HYDT_bind_init (bind.c:44)
> ==1525==    by 0x4096BE: HYD_pmci_launch_procs (pmiserv_pmci.c:293)
> ==1525==    by 0x4050B0: main (mpiexec.c:289)
> ==1525==
> ==1525==
> ==1525== 6 bytes in 1 blocks are definitely lost in loss record 2 of 3
> ==1525==    by 0x41EFFB: HYDT_bind_init (bind.c:40)
> ==1525==
> ==1525==
> ==1525== 16,384 bytes in 1 blocks are still reachable in loss record 3 of 3
> ==1525==    by 0x41EB08: HYDT_bind_init (bind.c:53)
> ==1525==
> ==1525== LEAK SUMMARY:
> ==1525==    definitely lost: 6 bytes in 1 blocks.
> ==1525==      possibly lost: 0 bytes in 0 blocks.
> ==1525==    still reachable: 16,390 bytes in 2 blocks.
> ==1525==         suppressed: 0 bytes in 0 blocks.
> On Sat, Nov 6, 2010 at 9:08 AM, Jeff Hammond <jhammond at mcs.anl.gov> wrote:
>> Yep, still happening when I use MPICH2-1.3 pulled via SVN yesterday
>> and compiled with GCC 4.6.  The test that fails is extremely simple.
>> Jeff
>> jeff at localhost:~/eclipse/a1/trunk/benchmarks/mpi> cat MPI_simple.c
>> #include <stdio.h>
>> #include <mpi.h>
>> int main(int argc, char **argv)
>>    int provided;
>>    int rank, size;
>>    MPI_Init_thread(&argc, &argv, MPI_THREAD_SINGLE, &provided);
>>    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>>    MPI_Comm_size(MPI_COMM_WORLD, &size);
>>    MPI_Barrier(MPI_COMM_WORLD);
>>    printf("before MPI_Finalize\n"); fflush(stdout);
>>    MPI_Finalize();
>>    printf("after MPI_Finalize\n"); fflush(stdout);
>>    return(0);
>> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec -n 2 MPI_simple.x
>> before MPI_Finalize
>> after MPI_Finalize
>> before MPI_Finalize
>> after MPI_Finalize
>> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec: munmap_chunk():
>> invalid pointer: 0x00007fffd654016b ***
>> ======= Backtrace: =========
>> /lib64/libc.so.6[0x7f1cca7040c8]
>> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x421984]
>> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x40a07f]
>> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x40537f]
>> /lib64/libc.so.6(__libc_start_main+0xe6)[0x7f1cca6ae586]
>> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x404359]
>> ======= Memory map: ========
>> 00400000-00449000 r-xp 00000000 08:03 312441
>>  /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec.hydra
>> 00648000-00649000 r--p 00048000 08:03 312441
>> 00649000-0064b000 rw-p 00049000 08:03 312441
>> 0064b000-00672000 rw-p 0064b000 00:00 0                                  [heap]
>> 7f1cca479000-7f1cca48e000 r-xp 00000000 08:02 1417264
>>  /lib64/libgcc_s.so.1
>> 7f1cca48e000-7f1cca68e000 ---p 00015000 08:02 1417264
>> 7f1cca68e000-7f1cca68f000 r--p 00015000 08:02 1417264
>> 7f1cca68f000-7f1cca690000 rw-p 00016000 08:02 1417264
>> 7f1cca690000-7f1cca7df000 r-xp 00000000 08:02 1417222
>>  /lib64/libc-2.9.so
>> 7f1cca7df000-7f1cca9df000 ---p 0014f000 08:02 1417222
>>  /lib64/libc-2.9.so
>> 7f1cca9df000-7f1cca9e3000 r--p 0014f000 08:02 1417222
>>  /lib64/libc-2.9.so
>> 7f1cca9e3000-7f1cca9e4000 rw-p 00153000 08:02 1417222
>>  /lib64/libc-2.9.so
>> 7f1cca9e4000-7f1cca9e9000 rw-p 7f1cca9e4000 00:00 0
>> 7f1cca9e9000-7f1cca9ff000 r-xp 00000000 08:02 1417248
>>  /lib64/libpthread-2.9.so
>> 7f1cca9ff000-7f1ccabff000 ---p 00016000 08:02 1417248
>> 7f1ccabff000-7f1ccac00000 r--p 00016000 08:02 1417248
>> 7f1ccac00000-7f1ccac01000 rw-p 00017000 08:02 1417248
>> 7f1ccac01000-7f1ccac05000 rw-p 7f1ccac01000 00:00 0
>> 7f1ccac05000-7f1ccac0d000 r-xp 00000000 08:02 1417496
>>  /lib64/librt-2.9.so
>> 7f1ccac0d000-7f1ccae0c000 ---p 00008000 08:02 1417496
>>  /lib64/librt-2.9.so
>> 7f1ccae0c000-7f1ccae0d000 r--p 00007000 08:02 1417496
>>  /lib64/librt-2.9.so
>> 7f1ccae0d000-7f1ccae0e000 rw-p 00008000 08:02 1417496
>>  /lib64/librt-2.9.so
>> 7f1ccae0e000-7f1ccae23000 r-xp 00000000 08:02 1417457
>>  /lib64/libnsl-2.9.so
>> 7f1ccae23000-7f1ccb022000 ---p 00015000 08:02 1417457
>> 7f1ccb022000-7f1ccb023000 r--p 00014000 08:02 1417457
>> 7f1ccb023000-7f1ccb024000 rw-p 00015000 08:02 1417457
>> 7f1ccb024000-7f1ccb026000 rw-p 7f1ccb024000 00:00 0
>> 7f1ccb026000-7f1ccb07b000 r-xp 00000000 08:02 1417485
>>  /lib64/libm-2.9.so
>> 7f1ccb07b000-7f1ccb27a000 ---p 00055000 08:02 1417485
>>  /lib64/libm-2.9.so
>> 7f1ccb27a000-7f1ccb27b000 r--p 00054000 08:02 1417485
>>  /lib64/libm-2.9.so
>> 7f1ccb27b000-7f1ccb27c000 rw-p 00055000 08:02 1417485
>>  /lib64/libm-2.9.so
>> 7f1ccb27c000-7f1ccb291000 r-xp 00000000 08:02 1417270
>>  /lib64/libz.so.1.2.3
>> 7f1ccb291000-7f1ccb490000 ---p 00015000 08:02 1417270
>> 7f1ccb490000-7f1ccb491000 r--p 00014000 08:02 1417270
>> 7f1ccb491000-7f1ccb492000 rw-p 00015000 08:02 1417270
>> 7f1ccb492000-7f1ccb494000 r-xp 00000000 08:02 1417482
>>  /lib64/libdl-2.9.so
>> 7f1ccb494000-7f1ccb694000 ---p 00002000 08:02 1417482
>>  /lib64/libdl-2.9.so
>> 7f1ccb694000-7f1ccb695000 r--p 00002000 08:02 1417482
>>  /lib64/libdl-2.9.so
>> 7f1ccb695000-7f1ccb696000 rw-p 00003000 08:02 1417482
>>  /lib64/libdl-2.9.so
>> 7f1ccb696000-7f1ccb7ea000 r-xp 00000000 08:02 521675
>>  /usr/lib64/libxml2.so.2.7.1
>> 7f1ccb7ea000-7f1ccb9e9000 ---p 00154000 08:02 521675
>> 7f1ccb9e9000-7f1ccb9f1000 r--p 00153000 08:02 521675
>> 7f1ccb9f1000-7f1ccb9f3000 rw-p 0015b000 08:02 521675
>> 7f1ccb9f3000-7f1ccb9f4000 rw-p 7f1ccb9f3000 00:00 0
>> 7f1ccb9f4000-7f1ccba12000 r-xp 00000000 08:02 1420584
>>  /lib64/ld-2.9.so
>> 7f1ccbbd3000-7f1ccbbd8000 rw-p 7f1ccbbd3000 00:00 0
>> 7f1ccbc0f000-7f1ccbc11000 rw-p 7f1ccbc0f000 00:00 0
>> 7f1ccbc11000-7f1ccbc12000 r--p 0001d000 08:02 1420584
>>  /lib64/ld-2.9.so
>> 7f1ccbc12000-7f1ccbc13000 rw-p 0001e000 08:02 1420584
>>  /lib64/ld-2.9.so
>> 7fffd651e000-7fffd6541000 rw-p 7ffffffdc000 00:00 0                      [stack]
>> 7fffd65ff000-7fffd6600000 r-xp 7fffd65ff000 00:00 0                      [vdso]
>> ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
>>  [vsyscall]
>> Aborted
>> On Fri, Nov 5, 2010 at 12:15 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>>> Did you try 1.3? The attached program works fine with trunk.
>>>  -- Pavan
>>> On 11/05/2010 11:21 AM, Jeff Hammond wrote:
>>>> I'm seeing an error when parallel jobs run with MPICH2 1.3a1 terminate.
>>>> I see the problem with NWChem (attached) but also with the trivial code
>>>> below.
>>>> Jeff
>>>> stdout and stderr
>>>> jeff at localhost:~/eclipse/a1/trunk/benchmarks/mpi>  mpiexec -np 2
>>>> MPI_Allreduce_tests.x
>>>> Test 0: sum 1 out-of-place
>>>>    0: in=1 out=1 ans=1 PASSED
>>>> Test 1: sum 1 in-place
>>>> Test 2: sum 2 out-of-place
>>>>    0: in=1 out=2 ans=2 PASSED
>>>> Test 3: sum 2 in-place
>>>> Test 4: prod 1 out-of-place
>>>>    0: in=1 out=0 ans=0 PASSED
>>>> Test 5: prod 1 in-place
>>>> Test 6: prod 2 out-of-place
>>>> Test 7: prod 2 in-place
>>>>    1: in=0 out=1 ans=1 PASSED
>>>>    1: in=1 out=2 ans=2 PASSED
>>>>    1: in=0 out=0 ans=0 PASSED
>>>>    1: in=1 out=1 ans=1 PASSED
>>>> 0x00007fffcb3ce169 ***
>>>> /lib64/libc.so.6[0x7f5415e5b0c8]
>>>> mpiexec[0x41908b]
>>>> mpiexec[0x403a97]
>>>> /lib64/libc.so.6(__libc_start_main+0xe6)[0x7f5415e05586]
>>>> mpiexec[0x402f29]
>>>> 00400000-00426000 r-xp 00000000 08:03 2426704
>>>>   /software/mpich/mpich2-1.3a1-gnu-build/bin/mpiexec
>>>> 00625000-00626000 r--p 00025000 08:03 2426704
>>>> 00626000-00627000 rw-p 00026000 08:03 2426704
>>>> 00627000-0064a000 rw-p 00627000 00:00 0
>>>>  [heap]
>>>> 7f5415bd0000-7f5415be5000 r-xp 00000000 08:02 1417264
>>>> 7f5415be5000-7f5415de5000 ---p 00015000 08:02 1417264
>>>> 7f5415de5000-7f5415de6000 r--p 00015000 08:02 1417264
>>>> 7f5415de6000-7f5415de7000 rw-p 00016000 08:02 1417264
>>>> 7f5415de7000-7f5415f36000 r-xp 00000000 08:02 1417222
>>>>   /lib64/libc-2.9.so
>>>> 7f5415f36000-7f5416136000 ---p 0014f000 08:02 1417222
>>>>   /lib64/libc-2.9.so
>>>> 7f5416136000-7f541613a000 r--p 0014f000 08:02 1417222
>>>>   /lib64/libc-2.9.so
>>>> 7f541613a000-7f541613b000 rw-p 00153000 08:02 1417222
>>>>   /lib64/libc-2.9.so
>>>> 7f541613b000-7f5416140000 rw-p 7f541613b000 00:00 0
>>>> 7f5416140000-7f5416155000 r-xp 00000000 08:02 1417457
>>>> 7f5416155000-7f5416354000 ---p 00015000 08:02 1417457
>>>> 7f5416354000-7f5416355000 r--p 00014000 08:02 1417457
>>>> 7f5416355000-7f5416356000 rw-p 00015000 08:02 1417457
>>>> 7f5416356000-7f5416358000 rw-p 7f5416356000 00:00 0
>>>> 7f5416358000-7f5416376000 r-xp 00000000 08:02 1420584
>>>>   /lib64/ld-2.9.so
>>>> 7f541653a000-7f541653c000 rw-p 7f541653a000 00:00 0
>>>> 7f5416573000-7f5416575000 rw-p 7f5416573000 00:00 0
>>>> 7f5416575000-7f5416576000 r--p 0001d000 08:02 1420584
>>>>   /lib64/ld-2.9.so
>>>> 7f5416576000-7f5416577000 rw-p 0001e000 08:02 1420584
>>>>   /lib64/ld-2.9.so
>>>> 7fffcb3b9000-7fffcb3cf000 rw-p 7ffffffe9000 00:00 0
>>>>  [stack]
>>>> 7fffcb3ff000-7fffcb400000 r-xp 7fffcb3ff000 00:00 0
>>>>  [vdso]
>>>>   [vsyscall]
>>>> Aborted
>>>> source
>>>>  * The following is a notice of limited availability of the code, and
>>>> disclaimer
>>>>  * which must be included in the prologue of the code and in all source
>>>> listings
>>>>  * of the code.
>>>>  * Copyright (c) 2010  Argonne Leadership Computing Facility, Argonne
>>>> National
>>>>  * Laboratory
>>>>  * Permission is hereby granted to use, reproduce, prepare derivative
>>>> works, and
>>>>  * to redistribute to others.
>>>>  *                          LICENSE
>>>>  * Redistribution and use in source and binary forms, with or without
>>>>  * modification, are permitted provided that the following conditions are
>>>>  * met:
>>>>  * - Redistributions of source code must retain the above copyright
>>>>  *   notice, this list of conditions and the following disclaimer.
>>>>  * - Redistributions in binary form must reproduce the above copyright
>>>>  *   notice, this list of conditions and the following disclaimer listed
>>>>  *   in this license in the documentation and/or other materials
>>>>  *   provided with the distribution.
>>>>  * - Neither the name of the copyright holders nor the names of its
>>>>  *   contributors may be used to endorse or promote products derived from
>>>>  *   this software without specific prior written permission.
>>>>  * The copyright holders provide no reassurances that the source code
>>>>  * provided does not infringe any patent, copyright, or any other
>>>>  * intellectual property rights of third parties.  The copyright holders
>>>>  * disclaim any liability to any recipient for claims brought against
>>>>  * recipient by any third party for infringement of that parties
>>>>  * intellectual property rights.
>>>>  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>>  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
>>>>  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
>>>>  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
>>>>  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>>>>  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>>>>  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>>>>  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>>>>  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
>>>>  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>>>> #include<stdio.h>
>>>> #include<stdlib.h>
>>>> #include<mpi.h>
>>>>     int provided;
>>>>     int rank, size;
>>>>     int count;
>>>>     int in, out, ans;
>>>>     MPI_Init_thread(&argc,&argv, MPI_THREAD_MULTIPLE,&provided);
>>>>     MPI_Comm_rank(MPI_COMM_WORLD,&rank);
>>>>     MPI_Comm_size(MPI_COMM_WORLD,&size);
>>>>     /* TESTING SUM OPERATOR */
>>>>     if (rank==0) printf("Test %d: sum 1 out-of-place\n",count++);
>>>>     in  = ( rank==0 ? 1 : 0 );
>>>>     out = 0;
>>>>     ans = 1;
>>>>     MPI_Allreduce(&in,&out,1,MPI_INT,MPI_SUM,MPI_COMM_WORLD);
>>>>     if (out==ans) printf("%4d: in=%d out=%d ans=%d PASSED
>>>> \n",rank,in,out,ans);
>>>>     else          printf("%4d: in=%d out=%d ans=%d FAILED
>>>>     fflush(stdout);
>>>>     if (rank==0) printf("Test %d: sum 1 in-place\n",count++);
>>>>     out = in;
>>>>     ans = 1;
>>>>     MPI_Allreduce(MPI_IN_PLACE,&out,1,MPI_INT,MPI_SUM,MPI_COMM_WORLD);
>>>>     fflush(stdout);
>>>>     if (rank==0) printf("Test %d: sum 2 out-of-place\n",count++);
>>>>     in  = 1;
>>>>     out = 0;
>>>>     ans = size;
>>>>     fflush(stdout);
>>>>     if (rank==0) printf("Test %d: sum 2 in-place\n",count++);
>>>>     in  = 1;
>>>>     out = in;
>>>>     ans = size;
>>>>     fflush(stdout);
>>>>     /* TESTING PROD OPERATOR */
>>>>     if (rank==0) printf("Test %d: prod 1 out-of-place\n",count++);
>>>>     out = 0;
>>>>     ans = 0;
>>>>     MPI_Allreduce(&in,&out,1,MPI_INT,MPI_PROD,MPI_COMM_WORLD);
>>>>     fflush(stdout);
>>>>     if (rank==0) printf("Test %d: prod 1 in-place\n",count++);
>>>>     out = in;
>>>>     ans = 0;
>>>>     MPI_Allreduce(MPI_IN_PLACE,&out,1,MPI_INT,MPI_PROD,MPI_COMM_WORLD);
>>>> \n",rank,in,out,ans);;
>>>>     fflush(stdout);
>>>>     if (rank==0) printf("Test %d: prod 2 out-of-place\n",count++);
>>>>     in  = 1;
>>>>     out = 0;
>>>>     ans = 1;
>>>>     fflush(stdout);
>>>>     if (rank==0) printf("Test %d: prod 2 in-place\n",count++);
>>>>     in  = 1;
>>>>     out = in;
>>>>     ans = 1;
>>>>     fflush(stdout);
>>>>     /* END OF TESTS */
>>>>     MPI_Finalize();
>>>>     return 0;
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
>> Jeff Hammond
>> jhammond at alcf.anl.gov / (630) 252-5381
>> http://www.linkedin.com/in/jeffhammond
> Jeff Hammond
Jeff Hammond
