[mpich-discuss] make fails with undefined reference VALGRIND_CHECK_MEM_IS_ADDRESSABLE
Wei-keng Liao wkliao at ece.northwestern.edu
Tue May 18 11:18:50 CDT 2010
I checked valgrind.h on my system, but do not know how to tell the
valgrind version. Let me know if you have an idea.
Wei-keng
On May 18, 2010, at 10:51 AM, Dave Goodell wrote:
> What version of valgrind do you have installed?
> I suspect that your version of valgrind is older than anything that
> we've tested with and is slipping between the gap of "is valgrind.h
> available" and "does valgrind.h work".  I can strengthen the
> configure test if I have an idea of what version of valgrind you have.
> In the interim, the best workaround for you is probably to either
> remove "meminit" from your "--enable-g" arg, hack up the configure
> tests for valgrind so that they always fail, or delete lines 25-35
> of "src/include/mpiu_valgrind.h".
> -Dave
> On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
>> When running make of mpich2-1.2.1p1, I got an error complaining
>> undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please
>> see the attached standard outputs from configure and make.
>> The configure command and environment variables used are also given
>> in out.configure file.
>> I am using GNU compilers, gcc and gfortran, to build MPICH2.
>> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
>> % rpm -q glibc
>> glibc-2.3.6-3
>> % uname -a
>> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006 i686
>> athlon i386 GNU/Linux
>> Wei-keng
>> <out.configure><out.make>
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
