[mpich-discuss] A runtime environment variable tocontroleager/rendezvous protocol?
Rajeev Thakur thakur at mcs.anl.gov
Mon Mar 8 23:54:29 CST 2010
If you are using the default nemesis channel in MPICH 1.2.1, I believe
the eager/rendezvous threshold is set by the value
MPIDI_CH3_EAGER_MAX_MSG_SIZE in
src/mpid/ch3/channels/nemesis/include/mpidi_ch3_post.h. You can change
it there and then run make clean, make, make install in the top-level
directory. Not sure if it can be changed via an env variable.
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Bin Bao
Sent: Monday, March 08, 2010 7:05 PM
Subject: Re: [mpich-discuss] A runtime environment variable
I am actually using MPICH2 1.2.1, and don't have MPICH installed yet. I
was looking for the environment variable that gives me the control to
the eager/rendezvous protocol, but only found "MPICH_LONGVLONGTHRESH" in
the MPICH document, "Installation and User's Guide to MPICH, version
1.2.7".
Bin
On Mon, Mar 8, 2010 at 6:03 PM, Rajeev Thakur <thakur at mcs.anl.gov>
wrote:
Which version of MPICH are you using and what device?
Rajeev
  _____
Sent: Monday, March 08, 2010 2:41 PM
Subject: [mpich-discuss] A runtime environment variable to
Is there a runtime environment variable in MPICH2 that can be used to
control when to switch from eager protocol to rendezvous protocol? It
seems that "MPICH LONGVLONGTHRESH" in MPICH can do this.
Bin
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100308/98cfe860/attachment.htm>
