[mpich-discuss] MPE tracing
Georges Markomanolis george at markomanolis.com
Wed Jun 23 12:51:42 CDT 2010
Thank you all for your answers,
I used clog2print because I wanted to see only the traces, not the
visualization as I need to convert the MPE traces into another format
that I need. Moreover I changed the output of the tracing library in
order to have the format that I mentioned and it seems to work very
nice. One more question. Is it possible to have a selective
instrumentation with the tracing library? I think something similar with
the customized logging but for tracing, I just need to know which MPI
calls are executed by a block of code.
Thanks a lot,
Best regards,
Georges
chan at mcs.anl.gov wrote:
> ----- "Georges Markomanolis" <georges.markomanolis at ens-lyon.fr> wrote:
>> Dear all,
>> I want to ask you about the MPE's libraries. While I use the logging
>> library for an application, I dump the clog file with the command
>> clog2print (is the right way to see the content of the files?).
> No, you should use the command jumpshot to "view" clog2 file.
>> Although
>> my application executes MPI_Bcast commands I can't see them. From the
>> manual I read that nested calls are not taken into account, like
>> MPI_Bcast. Is this why I can't see any MPI_Bcast?
> No. nested call probably is irrelevant here.
>> Moreover when I link
>> with the tracing library I can see the MPI_Bcast commands. So in the
>> case that I want to know about all the MPI commands I should use
>> tracing
>> not logging? I don't need the timestamps and the visualization.
> If you have access to the source code and you don't care about the order
> of MPI calls being executed, you can simply use "grep" of string that
> is prefixed with MPI_, e.g.
> grep "MPI_[A-Za-z_]*(" *.c
> If you still need to do logging, you can send me how you linked/compiled
> to enable MPE logging (I suspect something wrong there).
> A.Chan
>> Thanks a lot,
>> Best regards,
>> Georges
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
