[mpich-discuss] MPICH2 Between Linux/Windows
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Aug 23 16:26:21 CDT 2010
From the results it looks like the linux machine is unable to communicate using the sock channel (connect via tcp) with the windows machine.
# Did you compile the same test case on both the machines (There is icpi.c ==> interactive version and cpi.c ==> non-interactive version) ?
# Did you specify the ipaddresses of the machines in the machinefile (If you are specifying the hostnames in the machinefile try specifying ipaddresses instead)?
Jayesh
----- Original Message -----
From: "Stephan Hackstedt" <stephan.hackstedt at googlemail.com>
To: jayesh at mcs.anl.gov
Sent: Monday, August 23, 2010 4:11:17 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] MPICH2 Between Linux/Windows
thanks for your advises.
# Turn off any firewalls (windows firewall, linux firewall) running on the machines
->done
# Configure MPICH2 on linux with the sock channel (./configure ... --with-pm=smpd --with-device=ch3:sock ...) & SMPD process manager & install it.
->done -> ./configure --prefix=.../project/mpich2_121 --with-pm=smpd --with-device=ch3:sock
# Install the same version of MPICH2 (Same architecture & MPICH2 version) on the windows system.
->done i used mpich2-1.2.1p1-win-ia32.msi installer
# Make sure that you have the same user on both the machines (Either the same username/password or Use a domain user). Register that user on the windows machine (mpiexec -register).
->done
# Try running MPI jobs locally on the windows machine and the linux machine
->works!
# Try pinging each machine from the other machine
->works!
# Now try running a non-MPI job from the windows machine (mpiexec -n 2 -machinefile mf.txt -channel sock hostname; where mf.txt contains the ipaddresses of both the machines in separate lines)
->works, output both processes is plotted in windows terminal, programms successful end.
# If the above step is successful, try running cpi ( https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/icpi.c ) on both the machines. eg: If you have icpi.exe in c:\test on the windows machine and icpi.exe (unix executable) on /home/stephan/test , you should specify the paths as below,
->the job hangs directly after the input of the number interval, even if I choose 0 for quit, I also did not get the error message.
>Enter the number of intervals: (0 quits) 1
>_
>Enter the number of intervals: (0 quits) 0
>_
I also tried to use the cpi example from the source, cpi.c. I debugged, and it as far as I can say, the error occurs exactly when calling MPI_Bcast, the programm blocks and waits until I cancel it manually. Maybe the Data transmission does not work correctly in my case? i don't know what can cause this.
The output is:
>Process 0 of 2 is on stephanxp <- WinXP Machine
>Process 1 of 2 is on stephan-desktop <- Linux Machine
>_
regards,
stephan
2010/8/23 < jayesh at mcs.anl.gov >
Did you try explicitly specifying the channel on windows (mpiexec -n 2 -channel sock -machinefile mf.txt hostname) ?
Please try the following steps (Even if you have tried it before, pls try the steps as specified below - this helps us in debugging your problem) and let us know the results,
mpiexec -n 2 -machinefile mf.txt -channel sock -path "c:\test;/home/stephan/test" icpi.exe
Let us know the results (Pls provide as much details as possible - including commands typed and the stdout/err outputs).
Jayesh
From: "Stephan Hackstedt" < stephan.hackstedt at googlemail.com >
Sent: Monday, August 23, 2010 1:19:24 PM GMT -06:00 US/Canada Central
i also observed, that when i use the ch3:sock build, the MPI_comm_open always repeats the internal ip adress like:
tag=0 port=46264 description=stephan-desktop ifname=127.0.1.1
regards,
stephan
2010/8/23 Stephan Hackstedt < stephan.hackstedt at googlemail.com >
I'm trying to establish a connection between a process on linux (ububtu 10 04) and a process on a WinXp machine. MPICH 1.2.1 on both machines. The WinXP with installer, ubuntu from sources.
I configured the linux side with
./configure --with-pm=smpd --with-device=ch3:nemesis
and another build with
./configure --with-pm=smpd --with-device=ch3:sock ,
none of them work. I also disabled all firewalls, wonder because when i start a virtual machine on the winxo machine i can esatblish a connection to the linux machine. Had anybody dealt with such problems before?
One other question is, do i have to rebuild a MPI Application when using another MPICH2 build with another processmanager like above?
regards,
stephan
mpich-discuss mailing list
