[mpich-discuss] mpich2 Parallel job real time.
mohamed makhyoun makhyoun2 at yahoo.com
Fri Aug 20 19:50:00 CDT 2010
Dear users and developers:
Recently I compiled successfully a parallel binary (cfour software from www.cfour.de)
using pgf90 version 9.0 /mpich2 . The main program is a driver that initiate the parallel job internally
without the common command: mpiexec -np  4 cfourbinary (for four nodes ).
The steps taking in running the program is as follows under linux:
mpd &
cfourbinary input > output
The problem is that  the
 real time for running the parallel job is nearly the same as the serial job.  Is something missing ? Also the ps command during the run indicates no communication either with ssh or rsh.
Best Regard
Mohamed Makhyoun
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100820/f7252633/attachment.htm>
