[mpich-discuss] Assertion failed in file helper_fns.c
Rui Mei meir02ster at gmail.com
Thu Aug 12 15:44:48 CDT 2010
Hi, all,
I was trying to run my research model with MPICH and got the following error
message. I was trying to locate this file helper_fns.c. And I found this
file name appeared in libmpich.a under MPI lib folder. This is the only clue
I have found. But I do not know what is wrong with it. I hope to get some
advice here. Thank you very much.
Rui
Assertion failed in file helper_fns.c at line 337: 0
memcpy argument memory ranges overlap, dst_=0x600000000570def0
src_=0x600000000570def0 len_=4
internal ABORT - process 0
memcpy argument memory ranges overlap, dst_=0x6000000005712088
src_=0x6000000005712088 len_=4
internal ABORT - process 2
memcpy argument memory ranges overlap, dst_=0x6000000005770fa4
src_=0x6000000005770fa4 len_=4
internal ABORT - process 1
memcpy argument memory ranges overlap, dst_=0x600000000571209c
src_=0x600000000571209c len_=4
internal ABORT - process 3
memcpy argument memory ranges overlap, dst_=0x60000000057427e4
src_=0x60000000057427e4 len_=4
internal ABORT - process 5
memcpy argument memory ranges overlap, dst_=0x6000000005714180
src_=0x6000000005714180 len_=4
internal ABORT - process 4
memcpy argument memory ranges overlap, dst_=0x600000000570f07c
src_=0x600000000570f07c len_=4
internal ABORT - process 7
memcpy argument memory ranges overlap, dst_=0x60000000057120a8
src_=0x60000000057120a8 len_=4
internal ABORT - process 6
rank 7 in job 1 linuxAltix_6629 caused collective abort of all ranks
exit status of rank 7: return code 1
rank 4 in job 1 linuxAltix_6629 caused collective abort of all ranks
exit status of rank 4: return code 1
rank 3 in job 1 linuxAltix_6629 caused collective abort of all ranks
exit status of rank 3: return code 1
rank 2 in job 1 linuxAltix_6629 caused collective abort of all ranks
exit status of rank 2: killed by signal 9
(seq_mct_drv) : Initialize lnd component
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100812/c08cfaee/attachment.htm>
