[mpich-discuss] R: installation problem
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Thu Oct 29 09:49:22 CDT 2009
 Aha... In one of your (/gavron) emails you mentioned you have Win XP installed...
 This should be fixed in the next patch/minor release (However if you have Win 2K installed you should not have problems installing 1.0.7 for example. Are you able to install a previous version of MPICH2 ? ).
Jayesh
----- Original Message -----
From: "Bottazzi Francesca" <Francesca.Bottazzi at eni.it>
To: mpich-discuss at mcs.anl.gov, "Victor Gavron" <gavron at lanl.gov>
Sent: Thursday, October 29, 2009 9:35:18 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] R:  installation problem
I'm sorry, I didn't specify that I have Windows 2000 installed...
Francesca Bottazzi
Geomechanical Engineer
Geomechanics & EOR Technologies dept. (TEOR)
Eni S.p.A. - E&P Division
Phone: +39 02 520 62360
Fax: +39 02 520 61883
e-mail: francesca.bottazzi at eni.it
_________________________________________________________________________________________
Eni S.p.A. - Sede legale in Roma, Piazzale Enrico Mattei 1, 00144 Roma - Cap.sociale EUR 4.005.358.876 i.v.
Registro Imprese di Roma - Codice Fisc. 00484960588 - P.IVA 00905811006 - R.E.A. Roma n.756453
This e-mail and any attached documents are intended only for the addressee(s) named above.
As this e-mail may contain confidential or legally privileged information, please notify us immediately if you
are not the named addressee and delete the message permanently. This e-mail and any attached documents
should not be disclosed to any other person nor copies taken without the prior consent of the sender.
-----Messaggio originale-----
Da: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] Per conto di jayesh at mcs.anl.gov
Inviato: giovedì 29 ottobre 2009 15.30
A: Victor Gavron
Cc: mpich-discuss at mcs.anl.gov
Oggetto: Re: [mpich-discuss] installation problem
 Are you sure you have Win XP SP3 installed ? You should not get this error message after installing XP SP3. Type "winver" at the command prompt to get the version of windows installed in your machine.
(PS: We are removing this dependency for SP3 in our next release - See ticket http://trac.mcs.anl.gov/projects/mpich2/ticket/776. I have already added you in this ticket.)
Jayesh
To: jayesh at mcs.anl.gov
Sent: Thursday, October 29, 2009 8:21:41 AM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] installation problem
Responded with error message "The procedure entry point GetLogicalPProcessorInformation could not be located in the dynamic link library KERNEL32.DLL"
-----Original Message-----
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, October 28, 2009 4:23 PM
To: Gavron, Victor
Subject: [mpich-discuss] installation problem
 Please find attached a zip file at the downloads page (http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/temp/MPICH2.zip) containing the MPICH2 1.2 libs/exes/dlls (32-bit). Please follow the instructions below to install MPICH2 manually using the zip file,
# Unzip the contents of zip file into "c:\program files\mpich2" folder.
# Copy the dll files in the lib folder to your system32 folder (copy c:\progra~1\mpich2\lib\*.dll c:\windows\system32).
# Install the process manager manually (smpd -install).
 Let us know the results.
Jayesh
mpich-discuss mailing list
Message for the recipient only, if received in error, please notify the sender and read http://www.eni.it/disclaimer/
