[mpich-discuss] Errors while install MPICH on a 64bit cluster
Anthony Chan chan at mcs.anl.gov
Mon Oct 12 10:16:35 CDT 2009
You c.txt indicates that you were using MPICH-1 not MPICH2.
MPICH-1 is no longer supported officially.  Could you try
MPICH2, currently at release 1.2 ?
A.Chan
----- "Lei Yang" <lei.miren.yang at gmail.com> wrote:
> Hello,
> This is Lei Yang (at Guang Zhou, China)
> I am trying to install MPICH or MPICH2 on our cluster, but many errors
> came
> up, please help me!!
> attached c.txt, m.txt, mi.txt are for configuration, make and make
> install
> results.
> (i has been trying to install this for days, please do help!!~)
> I think the main issue is that it didn't pass configure test, and
> showed
> 'can't find -lfmpich'
> I use intel fortran compiler.
> my .bashrc file is like this
> export F90=/opt/intel/fc/10.0.023/bin/ifort
> export FC=F90
> export CC=gcc
> export F77=F90
> and my cluster information is:
> Processor    : 0
> vendor_id    : GenuineIntel
> cpu family    : 6
> model        : 23
> model name    : Intel(R) Xeon(R) CPU           E5430  @ 2.66GHz
> stepping    : 10
> cpu MHz        : 2660.002
> cache size    : 6144 KB
> physical id    : 0
> siblings    : 4
> core id        : 0
> cpu cores    : 4
> fpu        : yes
> fpu_exception    : yes
> cpuid level    : 13
> wp        : yes
> flags        : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge
> mca cmov
> pat pse36 clflush d
> ts acpi mmx fxsr sse sse2 ss ht tm syscall nx lm constant_tsc pni
> monitor
> ds_cpl vmx est tm2 cx16 x
> tpr lahf_lm
> bogomips    : 5323.69
> clflush size    : 64
> cache_alignment    : 64
> address sizes    : 38 bits physical, 48 bits virtual
> power management:
> processor    : 1
> cpu family    : 6
> model        : 23
> stepping    : 10
> cpu MHz        : 2660.002
> physical id    : 0
> siblings    : 4
> core id        : 2
> cpu cores    : 4
> fpu        : yes
> fpu_exception    : yes
> cpuid level    : 13
> wp        : yes
> mca cmov
> pat pse36 clflush d
> monitor
> tpr lahf_lm
> bogomips    : 5320.00
> clflush size    : 64
> power management:
> processor    : 2
> cpu family    : 6
> model        : 23
> stepping    : 10
> cpu MHz        : 2660.002
> physical id    : 0
> siblings    : 4
> core id        : 1
> cpu cores    : 4
> fpu        : yes
> fpu_exception    : yes
> cpuid level    : 13
> wp        : yes
> mca cmov
> pat pse36 clflush d
> monitor
> tpr lahf_lm
> bogomips    : 5320.06
> clflush size    : 64
> power management:
> processor    : 3
> cpu family    : 6
> model        : 23
> stepping    : 10
> cpu MHz        : 2660.002
> physical id    : 0
> siblings    : 4
> core id        : 3
> cpu cores    : 4
> fpu        : yes
> fpu_exception    : yes
> cpuid level    : 13
> wp        : yes
> mca cmov
> pat pse36 clflush d
> monitor
> tpr lahf_lm
> bogomips    : 5320.01
> clflush size    : 64
> power management:
> Thanks very much!!!
> LED
> The South China Sea Institute of Oceanology, CAS
> Guangzhou, China, 510301
> Tel:86-20-89023199
