[mpich-discuss] use ssh with hydra
Pavan Balaji balaji at mcs.anl.gov
Mon Nov 9 18:04:53 CST 2009
FWIW, ssh is the default bootstrap server and Hydra searches for "ssh"
in your path. So, you don't actually need to specify -bootstrap ssh and
-bootstrap-exec /usr/bin/ssh to your mpiexec. The following should work:
% mpiexec -f machines -n 4 ./time_bcast_nochk
 -- Pavan
On 11/09/2009 06:01 PM, jason wrote:
> Hi, Pavan
> That is problem.
> Thanks
> -jason
> Pavan Balaji wrote:
>> Is /common/mpich3/bin/pmi_proxy available on all nodes?
>>  -- Pavan
>> On 11/09/2009 05:51 PM, jason wrote:
>>> Hi, all
>>> I am trying to use hydra+ssh as process manager.
>>> I compiled my mpich2 like this
>>> ./configure --prefix=/common/mpich3 --with-pm=hydra
>>> make
>>> make install
>>> After that, I try to run a test command like this:
>>>> mpiexec -bootstrap ssh -bootstrap-exec /usr/bin/ssh -f machines -n 4
>>> ./time_bcast_nochk
>>> I got this message
>>> bash: /common/mpich3/bin/pmi_proxy: No such file or
>>> directory
>>> Then it hung there forever.
>>> I checked, I have pmi_proxy under /common/mpich3/bin:
>>>> file /common/mpich3/bin/pmi_proxy
>>> /common/mpich3/bin/pmi_proxy: ELF 32-bit LSB executable, Intel 80386,
>>> version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux
>>> 2.6.9, not stripped
>>> Any help is appreciated.
>>> thanks
>>> -jason
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
