[mpich-discuss] multiple mpd rings as one user
Rajeev Thakur thakur at mcs.anl.gov
Tue Jan 27 10:59:44 CST 2009
Do you really need multiple MPD rings? You can run multiple jobs with one
ring.
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
oliver.wissdorf at boehringer-ingelheim.com
Sent: Tuesday, January 27, 2009 10:04 AM
Subject: [mpich-discuss] multiple mpd rings as one user
Hello,
I want to start multipel rings as one user on a linux cluster to submit more
than one job at a time. Therefore I use mpdboot and mpdexec:
/usr/mpi/gcc/mvapich2-1.0.2/bin/mpdboot  -n 17 -f $PWD/mpd.txt --verbose
--ifhn=172.17.30.101
/usr/mpi/gcc/mvapich2-1.0.2/bin/mpiexec -machinefile $WORKDIR/mpd.txt -n $np
<jobscript>
I tried to set MPD_CON_EXT before starting the mpdboot and this allows me to
start multiple mpds on the host where the ring starts, but not on the other
hosts of the ring.
I also tried to use -1 option with mpdboot, but this did not work either.
Is there a way to solve this issue? Did I make any mistakes?
Oliver
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090127/114e80fe/attachment.htm>
