[mpich-discuss] question regarding compiling/linking under MingW (MPICH2 1.08)
ting lei leitingl at hotmail.com
Sun Jan 4 12:56:57 CST 2009
Hi, Dorian
Thanks a lot for your prompt reply.
Your command line
> gcc -I /c/MPICH2/include/ test.c -L/c/MPICH2/lib/ -lmpi
solves the first problem perfectly on win32.
On Win64, I see the following from line 333 onwards about MPI_Aint
/* Definitions that are determined by configure. */
typedef __int64 MPI_Aint;
typedef int MPI_Fint;
#define MPI_AINT_FMT_DEC_SPEC "%I64d"
#define MPI_AINT_FMT_HEX_SPEC "%I64x"
It seems that configure made a choice of __int64 for the Win64 package instead of long under linux. Any idea how this might be solved?
I have also attached the output with the -E option in the attachment err.txt for your reference.
BTW, I tried to manually change
to
typedef long MPI_Aint;
and then, I got:
gcc -I /c/MPICH2/include/ test.c -L /c/MPICH2/lib/ -lmpi
test.c: In function 'main':
test.c:15: warning: incompatible implicit declaration of built-in function 'printf'
C:/Users/ting/AppData/Local/Temp/ccsAr9gj.o:test.c:(.text+0x22): undefined reference to `_MPI_Init'
C:/Users/ting/AppData/Local/Temp/ccsAr9gj.o:test.c:(.text+0x36): undefined reference to `_MPI_Comm_rank'
collect2: ld returned 1 exit status
or the following for using g++:
$ g++ -I /c/MPICH2/include/ test.c -L /c/MPICH2/lib/ -lmpi
C:/Users/ting/AppData/Local/Temp/ccPO9opx.o:test.c:(.text+0x22): undefined reference to `_MPI_Init'
C:/Users/ting/AppData/Local/Temp/ccPO9opx.o:test.c:(.text+0x36): undefined reference to `_MPI_Comm_rank'
Thanks again.
T.
> Date: Sun, 4 Jan 2009 18:29:23 +0100
> From: ddkrause at uni-bonn.de
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] question regarding compiling/linking under MingW (MPICH2 1.08)
> Hi
> ting lei wrote:
> > Hi,
> > Sorry to bother all. I have some questions regarding using MPICH2 1.08
> > with MingW
> > I tried compile MPICH2 1.08 on two different machines, and have met
> > different problems. I was wondering if someone with a lot experience
> > could help me out here. thanks in advance.
> > 1) The most successful attempt was on a win32 platform, XPSP3 with
> > MingW+gcc3.4.5
> > The command line I used was:
> > gcc -I /c/MPICH2/include/ -lmpi -L/c/MPICH2/lib/ test.c
> > and I get the following error:
> > C:/DOCUME~1/ting/LOCALS~1/Temp/cc40AD3K.o:test.c:(.text+0x38):
> > undefined reference to `MPI_Init'
> > C:/DOCUME~1/ting/LOCALS~1/Temp/cc40AD3K.o:test.c:(.text+0x4b):
> > undefined reference to `MPI_Comm_rank'
> Could you try
> Since your testprogram depends on the mpi library you need to specify
> the library after your program because the linker goes from left to right.
> > It seems that the library file libmpi.a is corrected specified,
> > because if I change it to -lmpi1 it will report
> > c:\mingw\bin\..\lib\gcc\mingw32\3.4.5\..\..\..\..\mingw32\bin\ld.exe:
> > cannot find -lmpi1
> > 2) My less successful attempt was on a Win64 (Vista64) platform with
> > MingW + gcc4.3:
> > I tried installing the mpich2-1.0.8-win-x86-64.msi. but
> > a) after the installation, I couldn't find libmpi.a in MPICH2\lib
> > folder as I was able to in case 1).b) when I am compiling the toy test
> > program, I get many errors like this:
> > In file included from test.c:1:
> > c:/MPICH2/include/mpi.h:334: error: expected '=', ',', ';', 'asm' or
> > '__attribute__' before 'MPI_Aint'
> > Is this a gcc4.x problem?
> Did you take a look at mpi.h line 334? On Linux I can see typedef long
> MPI_Aint; . Could you compile with the -E flag to see the preprocessor
> output? Maybe something is overwriting long?
> > Best
> > T
> > From: jayesh at mcs.anl.gov
> > To: leitingl at hotmail.com
> > CC: mpich-discuss at mcs.anl.gov
> > Subject: RE: [mpich-discuss] (no subject) - mingw
> > Date: Tue, 2 Dec 2008 13:34:18 -0600
> > Hi,
> >  You could try installing MPICH2 on windows (from the installer
> > available at
> > http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)
> > and compile your code and link with the gcc libs (*.a) provided with
> > the installation (MPICH2\lib directory).
> > Regards,
> > Jayesh
> > *From:* mpich-discuss-bounces at mcs.anl.gov
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *ting lei
> > *Sent:* Tuesday, December 02, 2008 1:31 PM
> > *To:* mpich-discuss at mcs.anl.gov
> > *Subject:* [mpich-discuss] (no subject)
> > Hi,
> > This might be a newbie question.
> > I see in this thread that people can compile MPICH2 with MingW. I tried that with MingW (gcc 4.3 and 3.4x) several times but
> > I was never able to get past the ./configure step.
> > /"I have compiled a C executable using the MPICH2 Windows libraries and //MinGW./"
> > Could someone please give me some pointers how to compile such an executable?
> > More specifically, do I have to compile MPICH2 itself from source using MinGW then use some program such as mpicc??
> > or should I just compile a regular c program and run it with mpiexec.exe ?
> > If I were to compile MPICH2 itself with MingW, what other packages do I need except the latest version of MingW?
> > Many thanks for your help
> > <http://clk.atdmt.com/MRT/go/127032869/direct/01/>
> > It’s the same Hotmail®. If by “same” you mean up to 70% faster. Get
> > your account now.
> > <http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broad1_122008>
_________________________________________________________________
Send e-mail faster without improving your typing skills.
http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed_122008
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090104/d149ee25/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090104/d149ee25/attachment.txt>
