[mpich-discuss] make installtest failures
Charles Embry csembry at ualr.edu
Tue Dec 15 13:39:15 CST 2009
You mean as root? We are going to be running CONODR under root and thus mpich2 will have to be run under root? Or am i misunderstanding you?
----- Original Message -----
Date: Tuesday, December 15, 2009 1:16 am
Subject: Re: [mpich-discuss] make installtest failures
> "make installcheck" uses mpich2's mpiexec which is default to use
> mpd.  So you need to do "mpd &" before "make
> installcheck".  Also,
> run installcheck as regular user first.
> A.Chan
> ----- "Charles Embry" <csembry at ualr.edu> wrote:
> > Hello trying to install mpich2 on our machines in our
> department so we
> > can use CONDOR to its fullest. I am getting along fine, I
> think, until
> > I get to make installcheck.and get some errors just like what
> I have
> > listed below on the last eight test. I have included all the
> output of
> > the command in the attached file. Should I worry about these
> before I
> > continue?
> > *** Test F77 program with the MPI collective/datatype checking
> library> ... No.
> > The failed command is :
> > /usr/local/bin/mpich2-install/bin/mpiexec -n 4 wrong_reals
> > /usr/local/bin/mpich2-install/bin/mpdroot: open failed for
> root's mpd
> > conf filempiexec_cluster1.bioinformatics.ualr.edu (__init__ 1208):
> > forked process failed; status=255
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091215/f19aa2f0/attachment.htm>
