[mpich-discuss] MPI_GET_COUNT behaviour unclear
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Dec 15 10:30:09 CST 2009
The "the number of entries received" is returned in the argument
"count".
So, if you check the value of "count", it should be 2 in your case.
As for the return value of function MPI_Get_count(), it is the status
of the call, such as MPI_SUCCESS, which may be defined as constant 1.
Wei-keng
On Dec 15, 2009, at 6:18 AM, Tamás Faragó wrote:
> I have a question about MPI_GET_COUNT and MPI_GET_ELEMENTS. What do
> these functions exactly return?
> As I have read from the documentation (3.2.5) MPI_GET_COUNT returns
> the count of 'entries' of type 'datatype' received. According to me
> in example 4.12 (line 13) MPI_GET_COUNT should return 2 as we have
> sent two MPI_REAL types. The example however shows 1. Is this
> because as at when you send 2 types MPI transparently creates a new
> custom datatype (4.1.11) consisting of these two elements and thus
> the top-entry is 1?
> This, however should suggest that MPI_GET_COUNT always returns 1, or
> MPI_UNDEFINED on an error (eg unmached receive count or type). Is
> this correct?
> MPI_GET_ELEMENTS than receives what?
> How is the example (4.12) even working correctly when a custom
> datatype Type2 consists of two MPI_REALs and you want to receive two
> of those, eg 4 MPI_REALs?
> I am using the MPI 2.1 documentation (http://www.mpi-forum.org/docs/docs.html
>  in hardcover)
> Regards, Thomas
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
