[mpich-discuss] one more error while running
Pavan Balaji balaji at mcs.anl.gov
Sat Dec 5 21:22:32 CST 2009
Hmm.. That should not be the case. I'm running out of ideas on what you
can check. A few things you can try:
1. Delete your installation and install mpich2 from scratch at the same
location on both nodes. If you are using one of the UNIX distributions
that package mpich2 (Ubuntu, Fedora, Debian, FreeBSD, Gentoo), you can
just binary install it (using apt-get, yum, etc.).
2. Please run a non-MPI application first (such as "hostname" or "uname
-a") to make sure the process manager is setup correctly.
Btw, do both machines have identical OS stacks? That is, I hope you are
not mixing one 32-bit and one 64-bit installation.
Please let us know if either of these work for you.
 -- Pavan
On 12/05/2009 02:21 PM, Anuj Patel wrote:
> yes i did but it give no output..
> On Sun, Dec 6, 2009 at 1:47 AM, Pavan Balaji <balaji at mcs.anl.gov
> <mailto:balaji at mcs.anl.gov>> wrote:
>     Did you try mpdcheck as suggested in the previous email?
>      -- Pavan
>     On 12/05/2009 02:16 PM, Anuj Patel wrote:
>     > Assertion failed in file ch3_progress.c at line 489: pkt->type >= 0 &&
>     > pkt->type < MPIDI_NEM_PKT_END
>     > this is the main error i am getting no matter what code i try to run.
>     > and this is the output of non mpi job
>     > [root at indyaah runs]# mpiexec -n 4 ./a.out
>     > 13    12    -1    1
>     > 12    11    0    -1
>     > 1    1    1    1
>     > 2    0    1    0
>     > Run time was 62.
>     > 13    12    -1    1
>     > 12    11    0    -1
>     > 1    1    1    1
>     > 2    0    1    0
>     > Run time was 62.
>     > problem with execution of ./a.out  on  pratik.agrawal:  [Errno 8] Exec
>     > format error
>     > format error
>     > _______________________________________________
>     > mpich-discuss mailing list
>     > mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>     > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>     Pavan Balaji
>     http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
Pavan Balaji
