[mpich-discuss] one more error while running
Anuj Patel indyaah at gmail.com
Sat Dec 5 13:41:09 CST 2009
ok
i used mpiexec as i am not much used  to hydra.
i installed MPICH2 on both nodes.
the things is we are implementing the cluster on laptop..
now we configured two laptops initially..
it worked fine..
now when i changed second node (by configuring in same manner) it gives
following error..
the executables are available on both nodes in same dir path that is
/root/mpi/runs
On Sun, Dec 6, 2009 at 1:07 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Did you follow the previous suggestions? Are you using mpd or hydra? Do
> you have mpich2 installed on all the nodes and is the executable
> available on all the nodes?
>  -- Pavan
> On 12/05/2009 01:31 PM, Anuj Patel wrote:
> > it also gives sometimes error like this
> > problem with execution of ./a.out  on  pratik.agrawal:  [Errno 8] Exec
> > format error
> > format error
> > the pratik.agrawal is second node of cluster... we hae simple 2 node
> > cluster right now..
> > indyaah.destiny is the first node from where i am trying to run the code.
> > any help..??
> > On Sun, Dec 6, 2009 at 12:51 AM, Anuj Patel <indyaah at gmail.com
> > <mailto:indyaah at gmail.com>> wrote:
> >     Any idea about this error???
> >     [root at indyaah runs]# mpiexec -n 4 ./mm8
> >     Assertion failed in file ch3_progress.c at line 489: pkt->type >= 0
> >     && pkt->type < MPIDI_NEM_PKT_END
> >     internal ABORT - process 1
> >     rank 1 in job 8  indyaah.destiny_37866   caused collective abort of
> >     all ranks
> >       exit status of rank 1: killed by signal 9
> >     Anuj Patel
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091206/e871a68c/attachment-0001.htm>
