[mpich-discuss] mpdboot hangs, but ...
Dave Goodell goodell at mcs.anl.gov
Fri Dec 4 14:37:30 CST 2009
This has been fixed in the trunk.  Anyone who needs a fix in the short
term should be able to download the following copy of mpd.py and drop
it into src/pm/mpd/ in their MPICH2 source tree (and then re-install
MPICH2):
https://trac.mcs.anl.gov/projects/mpich2/export/5923/mpich2/trunk/src/pm/mpd/mpd.py
-Dave
On Dec 4, 2009, at 9:28 AM, Dave Goodell wrote:
> Hi Ben,
> This looks very similar to ticket #963: https://trac.mcs.anl.gov/projects/mpich2/ticket/963
> Please feel free to add yourself to the CC list if you would like to
> receive progress updates.  Thanks for letting us know that you are
> having trouble.
> Thinking about it this morning, I just had an idea of what might be
> going on. I'll spend some time on it today and see if I can
> reproduce it and work up a fix.
> In the mean time, you can either use the hydra process manager
> (built by default as "mpiexec.hydra") or copy the mpd.py script from
> 1.1.1p1 as a workaround.
> -Dave
> On Dec 4, 2009, at 5:38 AM, Benjamin Svetitsky wrote:
>> Hello everybody,
>> I just upgraded from mpich2-1.0.8 to mpich2-1.2.1.  When I run
>> 	mpdboot -n 4 -f /root/mpd.hosts
>> as root, the command just hangs until I hit ^C.  Nonetheless, it
>> starts the daemons successfully and I can run MPI jobs as usual (so
>> far).  A subsequent mpdallexit kills the saemons without complaint
>> Details:
>> I am running four Intel quad-cores under CentOS:
>> Linux version 2.6.18-164.6.1.el5.centos.plus
>> The file /root/mpd.hosts contains:
>> nodeA
>> nodeB
>> nodeC
>> nodeD
>> and I executed mpdboot on nodeC.
>> I compiled the MPICH2 source without any config options.
>> After mpdboot hangs for several minutes and I hit ^C, it responds:
>> Traceback (most recent call last):
>> File "/usr/local/bin/mpdboot", line 476, in ?
>>   mpdboot()
>> File "/usr/local/bin/mpdboot", line 347, in mpdboot
>>   handle_mpd_output(fd,fd2idx,hostsAndInfo)
>> File "/usr/local/bin/mpdboot", line 385, in handle_mpd_output
>>   for line in fd.readlines():    # handle output from shells that
>> echo stuff
>> KeyboardInterrupt
>> which may be irrelevant.
>> Thanks,
>> 	Ben
>> Prof. Benjamin Svetitsky         Phone:            +972-3-640 8870
>> School of Physics and Astronomy  Fax:              +972-3-640 7932
>> Tel Aviv University              E-mail:      bqs at julian.tau.ac.il
>> 69978 Tel Aviv, Israel           WWW: http://julian.tau.ac.il/~bqs
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
