[mpich-discuss] Race condition when accessing ~/.smpd during startup
Reuti reuti at staff.uni-marburg.de
Tue Nov 25 06:38:07 CST 2008
to implement  a daemon based smpd startup method for MPICH2 (1.0.8) I
use a loop across all elected machines which a chosen port. The
shutdown takes the same list in reverse order. I.e. the daemon on the
master node of the parallel job is shutdown of last, so that for a
shutdown no ssh or alike is necessary as I use "smpd -port $port -
shutdown $host".
This works fine, but from time to time I see a message in the logfile
of the script: "Please specify an authentication passphrase for this
smpd: Would you like to save this passphrase in '/home/
reuti/.smpd'?", either during startup or shutdown of the daemons.
Well, there is of course a passphrase in ~/.smpd.
I put now a "sleep 1" in the loops and this seems to avoid the problem.
As the dynamic_hosts="node001 node002" are also memorized in ~/.smpd:
can it be a race condition, when the daemons are started/shutdown too
fast? Can the modification of this file be switched off?
-- Reuti
