[mpich-discuss] mpdboot failure
Rajeev Thakur thakur at mcs.anl.gov
Tue Nov 18 16:37:52 CST 2008
Try the "mpdcheck -s" and "mpdcheck -c" commands as described on pg 30 on
i32-6 and i32-4 in both directions; i.e, with one as server and the other as
client, and vice versa.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Cesar
> Covarrubias
> Sent: Tuesday, November 18, 2008 4:33 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpdboot failure
> Rajeev,
> Thanks for your reply.
> If you look at the bottom of my first email, I provided the
> output of mpdcheck -f mpd.hosts -ssh -v. Running mpdcheck -l
> on each node doesn't return any errors.
> Very Respectfully,
> Cesar Covarrubias
> On Tue, 2008-11-18 at 16:22 -0600, Rajeev Thakur wrote:
> > Try running all steps of mpdcheck between i32-6 and i32-4 in both
> > directions as described in Appendex A.2 of the installation guide.
> > Rajeev
> > > Covarrubias
> > > Sent: Tuesday, November 18, 2008 4:10 PM
> > > As a follow up, here is an example of the error message in
> > > /var/log/messages:
> > > Nov 18 14:08:53 bduc-i32-6 mpd: mpd starting; no mpdid yet Nov 18
> > > 14:08:53 bduc-i32-6 mpd: mpd has mpdid=bduc-i32-6_37197
> > > (port=37197)
> > > Nov 18 14:08:53 bduc-i32-6 mpd: bduc-i32-6_37197
> (connect_lhs 900):
> > > failed to connect to lhs at bduc-i32-4 41311 Nov 18 14:08:53
> > > bduc-i32-6 mpd: bduc-i32-6_37197 (enter_ring 855): lhs connect
> > > failed Nov 18 14:08:53 bduc-i32-6 mpd:
> > > bduc-i32-6_37197 (run 252): failed to enter ring Nov 18
> > > 14:08:53 bduc-i32-6 mpd: mpd ending
> mpdid=bduc-i32-6_37197 (inside
> > > cleanup)
> > > Very Respectfully,
> > > Cesar Covarrubias
> > > On Tue, 2008-11-18 at 11:14 -0800, Cesar Covarrubias wrote:
> > > > Hello,
> > > > We are still having trouble getting mpd running on a large
> > > number of
> > > > our nodes. The error we get is mpdboot_bduc-sched.nacs.uci.edu
> > > > (handle_mpd_output 392): failed to handshake with mpd on
> > > bduc-i32-6;
> > > > recvd output={}. The problem is that it the node it chooses
> > > to fail on
> > > > is random. It is not always the same node. All nodes have the
> > > > /etc/mpd.conf file chmod'ed to 600. mpd is not running on
> > > any of the
> > > > nodes. The mpdcheck returns no errors (as you can see by the
> > > > output below). All the nodes are on a private subnet.
> > > > Ideas as to why this is failing?
> > > > Very Respectfully,
> > > > Cesar Covarrubias
> > > > -bash-3.2# mpdcheck -f mpd.hosts -ssh -v obtaining hostname via
> > > > gethostname and getfqdn gethostname gives
> > > > getfqdn gives  bduc-sched.nacs.uci.edu checking out unqualified
> > > > hostname; make sure is not "localhost", etc.
> > > > checking out qualified hostname; make sure is not
> "localhost", etc.
> > > > obtain IP addrs via qualified and unqualified hostnames;  make
> > > > sure other than 127.0.0.1
> > > > gethostbyname_ex:  ('bduc-sched.nacs.uci.edu', ['bduc-sched'],
> > > > ['128.200.15.19'])
> > > > ['128.200.15.19'])
> > > > checking that IP addrs resolve to same host now do some
> > > gethostbyaddr
> > > > and gethostbyname_ex for machines in hosts filechecking
> > > gethostbyXXX
> > > > for unqualified bduc-i32-1
> > > > gethostbyname_ex:  ('bduc-i32-1', [], ['192.168.0.10'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-1
> checking
> > > > gethostbyXXX for unqualified bduc-i32-3
> > > > gethostbyname_ex:  ('bduc-i32-3', [], ['192.168.0.12'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-3
> checking
> > > > gethostbyXXX for unqualified bduc-i32-4
> > > > gethostbyname_ex:  ('bduc-i32-4', [], ['192.168.0.13'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-4
> checking
> > > > gethostbyXXX for unqualified bduc-i32-5
> > > > gethostbyname_ex:  ('bduc-i32-5', [], ['192.168.0.14'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-5
> checking
> > > > gethostbyXXX for unqualified bduc-i32-6
> > > > gethostbyname_ex:  ('bduc-i32-6', [], ['192.168.0.15'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-6
> checking
> > > > gethostbyXXX for unqualified bduc-i32-7
> > > > gethostbyname_ex:  ('bduc-i32-7', [], ['192.168.0.16'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-7
> checking
> > > > gethostbyXXX for unqualified bduc-i32-8
> > > > gethostbyname_ex:  ('bduc-i32-8', [], ['192.168.0.17'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-8
> checking
> > > > gethostbyXXX for unqualified bduc-i32-9
> > > > gethostbyname_ex:  ('bduc-i32-9', [], ['192.168.0.18'])
> checking
> > > > gethostbyXXX for qualified bduc-i32-9
> checking
> > > > gethostbyXXX for unqualified bduc-i32-10
> > > > gethostbyname_ex:  ('bduc-i32-10', [],
> ['192.168.0.19']) checking
> > > > gethostbyXXX for qualified bduc-i32-10
> > > > gethostbyXXX for unqualified bduc-i32-11
> > > > gethostbyname_ex:  ('bduc-i32-11', [],
> ['192.168.0.20']) checking
> > > > gethostbyXXX for qualified bduc-i32-11
> > > > gethostbyXXX for unqualified bduc-i32-12
> > > > gethostbyname_ex:  ('bduc-i32-12', [],
> ['192.168.0.21']) checking
> > > > gethostbyXXX for qualified bduc-i32-12
> > > > gethostbyXXX for unqualified bduc-i32-13
> > > > gethostbyname_ex:  ('bduc-i32-13', [],
> ['192.168.0.22']) checking
> > > > gethostbyXXX for qualified bduc-i32-13
> > > > gethostbyXXX for unqualified bduc-i32-14
> > > > gethostbyname_ex:  ('bduc-i32-14', [],
> ['192.168.0.23']) checking
> > > > gethostbyXXX for qualified bduc-i32-14
> > > > gethostbyXXX for unqualified bduc-i32-15
> > > > gethostbyname_ex:  ('bduc-i32-15', [],
> ['192.168.0.24']) checking
> > > > gethostbyXXX for qualified bduc-i32-15
> > > > gethostbyXXX for unqualified bduc-i32-16
> > > > gethostbyname_ex:  ('bduc-i32-16', [],
> ['192.168.0.25']) checking
> > > > gethostbyXXX for qualified bduc-i32-16
> > > > gethostbyXXX for unqualified bduc-i32-17
> > > > gethostbyname_ex:  ('bduc-i32-17', [],
> ['192.168.0.26']) checking
> > > > gethostbyXXX for qualified bduc-i32-17
> > > > gethostbyXXX for unqualified bduc-i32-18
> > > > gethostbyname_ex:  ('bduc-i32-18', [],
> ['192.168.0.27']) checking
> > > > gethostbyXXX for qualified bduc-i32-18
> > > > gethostbyXXX for unqualified bduc-i32-19
> > > > gethostbyname_ex:  ('bduc-i32-19', [],
> ['192.168.0.28']) checking
> > > > gethostbyXXX for qualified bduc-i32-19
> > > > gethostbyXXX for unqualified bduc-i32-20
> > > > gethostbyname_ex:  ('bduc-i32-20', [],
> ['192.168.0.29']) checking
> > > > gethostbyXXX for qualified bduc-i32-20
> > > > gethostbyXXX for unqualified bduc-i32-21
> > > > gethostbyname_ex:  ('bduc-i32-21', [],
> ['192.168.0.30']) checking
> > > > gethostbyXXX for qualified bduc-i32-21
> > > > gethostbyXXX for unqualified bduc-i32-22
> > > > gethostbyname_ex:  ('bduc-i32-22', [],
> ['192.168.0.31']) checking
> > > > gethostbyXXX for qualified bduc-i32-22
> > > > gethostbyXXX for unqualified bduc-i32-24
> > > > gethostbyname_ex:  ('bduc-i32-24', [],
> ['192.168.0.33']) checking
> > > > gethostbyXXX for qualified bduc-i32-24
> > > > gethostbyXXX for unqualified bduc-i32-25
> > > > gethostbyname_ex:  ('bduc-i32-25', [],
> ['192.168.0.34']) checking
> > > > gethostbyXXX for qualified bduc-i32-25
> > > > gethostbyXXX for unqualified bduc-i32-27
> > > > gethostbyname_ex:  ('bduc-i32-27', [],
> ['192.168.0.36']) checking
> > > > gethostbyXXX for qualified bduc-i32-27
> > > > gethostbyXXX for unqualified bduc-i32-28
> > > > gethostbyname_ex:  ('bduc-i32-28', [],
> ['192.168.0.37']) checking
> > > > gethostbyXXX for qualified bduc-i32-28
> > > > gethostbyXXX for unqualified bduc-i32-29
> > > > gethostbyname_ex:  ('bduc-i32-29', [],
> ['192.168.0.38']) checking
> > > > gethostbyXXX for qualified bduc-i32-29
> > > > gethostbyXXX for unqualified bduc-i32-30
> > > > gethostbyname_ex:  ('bduc-i32-30', [],
> ['192.168.0.39']) checking
> > > > gethostbyXXX for qualified bduc-i32-30
> > > > gethostbyXXX for unqualified bduc-i32-31
> > > > gethostbyname_ex:  ('bduc-i32-31', [],
> ['192.168.0.40']) checking
> > > > gethostbyXXX for qualified bduc-i32-31
> > > > gethostbyXXX for unqualified bduc-i32-32
> > > > gethostbyname_ex:  ('bduc-i32-32', [],
> ['192.168.0.41']) checking
> > > > gethostbyXXX for qualified bduc-i32-32
> > > > gethostbyXXX for unqualified bduc-i32-33
> > > > gethostbyname_ex:  ('bduc-i32-33', [],
> ['192.168.0.42']) checking
> > > > gethostbyXXX for qualified bduc-i32-33
> > > > gethostbyXXX for unqualified bduc-i32-34
> > > > gethostbyname_ex:  ('bduc-i32-34', [],
> ['192.168.0.43']) checking
> > > > gethostbyXXX for qualified bduc-i32-34
> > > > gethostbyXXX for unqualified bduc-i32-35
> > > > gethostbyname_ex:  ('bduc-i32-35', [],
> ['192.168.0.44']) checking
> > > > gethostbyXXX for qualified bduc-i32-35
> > > > gethostbyXXX for unqualified bduc-i32-36
> > > > gethostbyname_ex:  ('bduc-i32-36', [],
> ['192.168.0.45']) checking
> > > > gethostbyXXX for qualified bduc-i32-36
> > > > gethostbyXXX for unqualified bduc-i32-37
> > > > gethostbyname_ex:  ('bduc-i32-37', [],
> ['192.168.0.46']) checking
> > > > gethostbyXXX for qualified bduc-i32-37
> > > > gethostbyXXX for unqualified bduc-i32-38
> > > > gethostbyname_ex:  ('bduc-i32-38', [],
> ['192.168.0.47']) checking
> > > > gethostbyXXX for qualified bduc-i32-38
> > > > gethostbyXXX for unqualified bduc-i32-39
> > > > gethostbyname_ex:  ('bduc-i32-39', [],
> ['192.168.0.48']) checking
> > > > gethostbyXXX for qualified bduc-i32-39
> > > > gethostbyXXX for unqualified bduc-i32-40
> > > > gethostbyname_ex:  ('bduc-i32-40', [],
> ['192.168.0.49']) checking
> > > > gethostbyXXX for qualified bduc-i32-40
> > > > gethostbyname_ex:  ('bduc-i32-40', [], ['192.168.0.49'])
> > > > trying: ssh bduc-i32-1 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-3 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-4 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-5 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-6 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-7 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-8 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-9 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-10 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-11 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-12 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-13 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-14 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-15 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-16 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-17 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-18 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-19 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-20 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-21 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-22 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-24 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-25 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-27 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-28 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-29 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-30 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-31 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-32 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-33 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-34 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-35 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-36 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-37 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-38 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-39 -x -n /bin/echo hello
> > > > trying: ssh bduc-i32-40 -x -n /bin/echo hello starting server:
> > > > /sge62/mpich2/bin/mpdcheck.py -s starting client: ssh
> > > bduc-i32-1 -x -n
> > > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 43076
> > > > starting server: /sge62/mpich2/bin/mpdcheck.py -s starting
> > > client: ssh
> > > > bduc-i32-3 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 38649 starting server:
> > > bduc-i32-4 -x -n
> > > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 40831
> > > client: ssh
> > > > bduc-i32-5 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 57153 starting server:
> > > bduc-i32-6 -x -n
> > > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 60407
> > > client: ssh
> > > > bduc-i32-7 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 52646 starting server:
> > > bduc-i32-8 -x -n
> > > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47523
> > > client: ssh
> > > > bduc-i32-9 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 50172 starting server:
> > > bduc-i32-10 -x
> bduc-sched.nacs.uci.edu 51821
> > > client: ssh
> > > > bduc-i32-11 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 36082 starting server:
> > > bduc-i32-12 -x
> bduc-sched.nacs.uci.edu 57250
> > > client: ssh
> > > > bduc-i32-13 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 47474 starting server:
> > > bduc-i32-14 -x
> bduc-sched.nacs.uci.edu 51971
> > > client: ssh
> > > > bduc-i32-15 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 54481 starting server:
> > > bduc-i32-16 -x
> bduc-sched.nacs.uci.edu 49851
> > > client: ssh
> > > > bduc-i32-17 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 33898 starting server:
> > > bduc-i32-18 -x
> bduc-sched.nacs.uci.edu 56621
> > > client: ssh
> > > > bduc-i32-19 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 37119 starting server:
> > > bduc-i32-20 -x
> bduc-sched.nacs.uci.edu 38601
> > > client: ssh
> > > > bduc-i32-21 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 43570 starting server:
> > > bduc-i32-22 -x
> bduc-sched.nacs.uci.edu 42130
> > > client: ssh
> > > > bduc-i32-24 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 41582 starting server:
> > > bduc-i32-25 -x
> bduc-sched.nacs.uci.edu 50515
> > > client: ssh
> > > > bduc-i32-27 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 48864 starting server:
> > > bduc-i32-28 -x
> bduc-sched.nacs.uci.edu 47361
> > > client: ssh
> > > > bduc-i32-29 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 44604 starting server:
> > > bduc-i32-30 -x
> bduc-sched.nacs.uci.edu 41417
> > > client: ssh
> > > > bduc-i32-31 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 48330 starting server:
> > > bduc-i32-32 -x
> bduc-sched.nacs.uci.edu 47243
> > > client: ssh
> > > > bduc-i32-33 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 35428 starting server:
> > > bduc-i32-34 -x
> bduc-sched.nacs.uci.edu 59147
> > > client: ssh
> > > > bduc-i32-35 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 54136 starting server:
> > > bduc-i32-36 -x
> bduc-sched.nacs.uci.edu 56116
> > > client: ssh
> > > > bduc-i32-37 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 59475 starting server:
> > > bduc-i32-38 -x
> bduc-sched.nacs.uci.edu 52834
> > > client: ssh
> > > > bduc-i32-39 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > > bduc-sched.nacs.uci.edu 58080 starting server:
> > > bduc-i32-40 -x
> bduc-sched.nacs.uci.edu 57115
