[mpich-discuss] mpiexec and working directory
Rajeev Thakur thakur at mcs.anl.gov
Fri Nov 7 12:20:33 CST 2008
Oh, you are using SMPD. Can you try with the default MPD process manager?
You have to build MPICH2 again for that.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Tiago Silva
> Sent: Friday, November 07, 2008 12:18 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpiexec and working directory
> Thanks Rajeev, this shows the problem nicely:
> [tsilva at admin1 work]$ /n1ge6/mpich2/smpd/bin/mpiexec -nopm
> -ssh -l -n 2 pwd
> /raid1/tsilva
> /raid1/tsilva
> -ssh -l -wdir
> /tmp/ -n 2 pwd
> /raid1/tsilva
> /raid1/tsilva
> [tsilva at admin1 work]$ ls runjob.err
> runjob.err
> -ssh -l -wdir
> /tmp/ -n 2 ls -l runjob.err
> ls: runjob.err: No such file or directory
> Could this have anything to do with running mpiexec
> deamonless (although
> mpich was compiled with smpd)?
> I noticed the same behavior with my regular setup of also deamonless
> mpirun and mpich1. Only after calling mpi_init in the code did the
> working dir change from being $home to the local dir.
> Cheers,
> Tiago
> Rajeev Thakur wrote:
> > Can you try these simple commands:
> > mpiexec -l -n 2 pwd
> >   ## shows if you execute in the dir you think you are in
> > mpiexec -l -wdir /tmp -n 2 pwd
> >   ## similar to above but shows you moved to /tmp
> > mpiexec -l -n 2 ls -l some_filename
> >   ## shows if some expected file really is in the working dir
> >> tsilva at coas.oregonstate.edu
> >> Sent: Friday, November 07, 2008 1:26 AM
> >> Quoting Rajeev Thakur <thakur at mcs.anl.gov>:
> >>> If you cd to the directory containing the executable, say
> >> a.out, and
> >>> do "mpiexec -n 2 a.out" does it expect to find input
> files in your
> >>> home directory? That's odd.
> >> That is correct. I have tried another simpler code and the
> >> same thing happens.
> Tiago Silva
> >>>> Sent: Thursday, November 06, 2008 6:02 PM
> >>>>> 1.0.3 is an ancient version of MPICH2. Try the latest
> >>>> version, 1.0.8.
> >>>> I will ask my systems administrator to do so.
> >>>>> The parameters to mpiexec are not identical between MPICH-1 and
> >>>>> MPICH2. Do mpiexec --help. Make sure you are calling
> >>>> MPICH2's mpiexec, not MPICH-1's.
> >>>> I am actually invoking mpiexec with its full path. Is there any
> >>>> incorrect parameter on my mpiexec call?
> >>>> I
> >>>>> If your input files are in the same directory as the
> >>>> executable, you
> >>>>> should not need to specify anything.
> >>>> But that is exactly the problem. The executable can't find
> >> the input
> >>>> files on the working directory.
