[mpich-discuss] [MPICH] Compiling a program (john-mpi MPICH2) under cygwin / WinXP - Correct formatting of sample makefile
madfran madfran at set-ezine.org
Mon Mar 3 16:24:16 CST 2008
Hi,...
I follow all your advice (I think), but without succes.
Any other idea?
>Hi,
>I am also providing you a sample makefile+source for an MPI helloworld
>program which will help you modify your makefile accordingly.
>As Darius mentioned in his previous mail the correct ordering of the
>object files is necessary for linking your program. In the example below
>main.c calls a function in hello.c (So main.o is specified before hello.o in
>$(OBJS)). Please notice that the libraries are provided in the linking stage
>($(CC) -o) and the order of $(OBJS) to make the program compile+link
>correctly. Also note the position of the LFLAGS containing the libs.
>########### makefile #############
>CC = gcc
>CFLAGS = -Wall -O3 -fomit-frame-pointer
>-I/cygdrive/c/Progra~1/MPICH2/include
>LFLAGS = -L/cygdrive/c/Progra~1/MPICH2/lib -lmpi
>OBJS = main.o hello.o
>helloworld: $(OBJS)
>$(CC) -o helloworld $(OBJS) $(LFLAGS)
>main.o: main.c
>$(CC) $(CFLAGS) -c main.c
>hello.o: hello.c
>$(CC) $(CFLAGS) -c hello.c
>clean:
>rm -f helloworld.exe $(OBJS)
>############ main.c ##############
>#include <stdio.h>
>#undef SEEK_SET
>#undef SEEK_CUR
>#undef SEEK_END
>#include <mpi.h>
>int main(int argc, char *argv[]){
>MPI_Init(&argc, &argv);
>helloworld();
>MPI_Finalize();
>############ hello.c ##############
>#include <stdio.h>
>#undef SEEK_SET
>#undef SEEK_CUR
>#undef SEEK_END
>#include <mpi.h>
>int helloworld(void ){
>int rank;
>MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>printf("[%d] hello world\n", rank);
>Type make in the command line to compile+link the program.
>Hope this helps...
>Regards,
>Jayesh
********************OUTPUT OF MAKE*************************************
$ make clean win32-cygwin-x86-sse2 2>&1 | tee output20.txt
rm -
f ../run/john ../run/unshadow ../run/unafs ../run/unique ../run/undrop ../run/
john.bin ../run/john.com ../run/unshadow.com ../run/unafs.com ../run/unique.co
m ../run/undrop.com ../run/john.exe ../run/unshadow.exe ../run/unafs.exe ../ru
n/unique.exe ../run/undrop.exe
rm -f ../run/john.exe *.o *.bak core
rm -f detect bench generic.h arch.h sparc.h tmp.s
rm -f DES_bs_s.c DES_bs_n.c DES_bs_a.c
cp /dev/null Makefile.dep
cp x86-sse.h arch.h
make ../run/john.exe ../run/unshadow.exe ../run/unafs.exe ../run/unique.exe ..
/run/undrop.exe \
		JOHN_OBJS="john.o misc.o options.o signals.o bench.o
DES_fmt.o DES_std.o DES_bs.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.o
AFS_fmt.o LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o
NSLDAP_fmt.o NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o IPB2_fmt.o NT_fmt.o
md4.o smbencrypt.o rawMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o hmacMD5_fmt.o
WPAPSK_fmt.o mscash_fmt.o oracle_fmt.o batch.o charset.o common.o compiler.o
config.o cracker.o crc32.o external.o formats.o getopt.o idle.o inc.o list.o
loader.o logger.o math.o memory.o params.o path.o recovery.o rpp.o rules.o
single.o status.o tty.o wordlist.o unshadow.o ryan.o unafs.o undrop.o
unique.o  DES_bs_b.o x86.o x86-sse.o md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-
mmx.o" \
		ASFLAGS="-c -DUNDERSCORES"
make[1]: Entering directory `/tmp/john-mpi/john-1.7.2-bp17-mpi7/src'
gcc -c -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include -
funroll-loops john.c
funroll-loops misc.c
funroll-loops options.c
funroll-loops signals.c
signals.c: In function `sig_handle_status':
signals.c:102: warning: unused variable `saved_errno'
signals.c: At top level:
signals.c:92: warning: 'sig_handle_update' defined but not used
funroll-loops bench.c
funroll-loops DES_fmt.c
funroll-loops DES_std.c
funroll-loops DES_bs.c
funroll-loops BSDI_fmt.c
funroll-loops MD5_fmt.c
funroll-loops MD5_std.c
MD5_std.c:27: warning: alignment of 'MD5_std_all' is greater than maximum
object file alignment.  Using 16
funroll-loops BF_fmt.c
funroll-loops BF_std.c
BF_std.c:53: warning: alignment of 'BF_exp_key' is greater than maximum
BF_std.c:57: warning: alignment of 'BF_init_key' is greater than maximum
funroll-loops AFS_fmt.c
funroll-loops LM_fmt.c
funroll-loops des.c
funroll-loops MD5_apache_fmt.c
funroll-loops BFEgg_fmt.c
funroll-loops lotus5_fmt.c
funroll-loops md5.c
funroll-loops NSLDAP_fmt.c
NSLDAP_fmt.c:63: warning: alignment of 'buffer' is greater than maximum
funroll-loops NSLDAPS_fmt.c
NSLDAPS_fmt.c: In function `crypt_all':
NSLDAPS_fmt.c:231: warning: suggest parentheses around + or - in operand of &
NSLDAPS_fmt.c: At top level:
NSLDAPS_fmt.c:62: warning: alignment of 'buffer' is greater than maximum
funroll-loops sha1.c
funroll-loops base64.c
funroll-loops MYSQL_fmt.c
funroll-loops IPB2_fmt.c
funroll-loops NT_fmt.c
funroll-loops md4.c
funroll-loops smbencrypt.c
funroll-loops rawMD5_fmt.c
funroll-loops rawSHA1_fmt.c
funroll-loops mssql_fmt.c
funroll-loops hmacMD5_fmt.c
funroll-loops WPAPSK_fmt.c
funroll-loops mscash_fmt.c
funroll-loops oracle_fmt.c
oracle_fmt.c:234: warning: initialization from incompatible pointer type
funroll-loops batch.c
funroll-loops charset.c
funroll-loops common.c
funroll-loops compiler.c
funroll-loops config.c
funroll-loops cracker.c
funroll-loops crc32.c
funroll-loops external.c
funroll-loops formats.c
funroll-loops getopt.c
funroll-loops idle.c
funroll-loops inc.c
funroll-loops list.c
funroll-loops loader.c
funroll-loops logger.c
funroll-loops math.c
funroll-loops memory.c
funroll-loops params.c
funroll-loops path.c
funroll-loops recovery.c
funroll-loops rpp.c
funroll-loops rules.c
funroll-loops single.c
funroll-loops status.c
funroll-loops tty.c
funroll-loops wordlist.c
funroll-loops unshadow.c
funroll-loops ryan.c
funroll-loops unafs.c
funroll-loops undrop.c
funroll-loops unique.c
sed "s/unsigned long/ARCH_WORD/" sboxes.c > DES_bs_s.c
sed "s/unsigned long/ARCH_WORD/" nonstd.c > DES_bs_n.c
finline-functions DES_bs_b.c
gcc -c -DUNDERSCORES x86.S
gcc -c -DUNDERSCORES x86-sse.S
gcc -c -DUNDERSCORES md4-sse2.S
funroll-loops NTmmx_fmt.c
NTmmx_fmt.c:63: warning: alignment of 'saved_plain' is greater than maximum
NTmmx_fmt.c:65: warning: alignment of 'output' is greater than maximum object
gcc -c -DUNDERSCORES md5-mmx.S
gcc -c -DUNDERSCORES sha1-mmx.S
gcc john.o misc.o options.o signals.o bench.o DES_fmt.o DES_std.o DES_bs.o
BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.o AFS_fmt.o LM_fmt.o des.o
MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o NSLDAP_fmt.o NSLDAPS_fmt.o
sha1.o base64.o MYSQL_fmt.o IPB2_fmt.o NT_fmt.o md4.o smbencrypt.o
rawMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o hmacMD5_fmt.o WPAPSK_fmt.o
mscash_fmt.o oracle_fmt.o batch.o charset.o common.o compiler.o config.o
cracker.o crc32.o external.o formats.o getopt.o idle.o inc.o list.o loader.o
logger.o math.o memory.o params.o path.o recovery.o rpp.o rules.o single.o
status.o tty.o wordlist.o unshadow.o ryan.o unafs.o undrop.o unique.o
DES_bs_b.o x86.o x86-sse.o md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-mmx.o -
lkernel32 -o ../run/john.exe
john.o:john.c:(.text+0x33): undefined reference to `_MPI_Init'
john.o:john.c:(.text+0x43): undefined reference to `_MPI_Comm_rank'
john.o:john.c:(.text+0x53): undefined reference to `_MPI_Comm_size'
john.o:john.c:(.text+0x713): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x751): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x771): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x921): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0xac2): undefined reference to `_MPI_Finalize'
misc.o:misc.c:(.text+0x38): more undefined references to `_MPI_Finalize'
follow
bench.o:bench.c:(.text+0x930): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x9a2): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0xa3c): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0xab4): undefined reference to `_MPI_Reduce'
collect2: ld returned 1 exit status
make[1]: *** [../run/john.exe] Error 1
make[1]: Leaving directory `/tmp/john-mpi/john-1.7.2-bp17-mpi7/src'
make: *** [win32-cygwin-x86-sse2] Error 2
************************MAKEFILE*************************************
# This file is part of John the Ripper password cracker,
# Copyright (c) 1996-2006 by Solar Designer
# 15.02.2008 Elli0t: enabled linking on cygwin; some cleanup
# 03.03.2008 Adapted to MPICH2 under WinXP
CPP = gcc
CC = gcc
AS = gcc
LD = gcc
CP = cp
LN = ln -sf
RM = rm -f
TR = tr
SED = sed
PERL = perl
NULL = /dev/null
CPPFLAGS = -E
CFLAGS = -c -Wall -O3 -fomit-frame-pointer -
ASFLAGS = -c
LDFLAGS = -s -lm -L/cygdrive/c/Progra~1/MPICH2/lib -lmpicxx -lfmpich2 -lmpi
OPT_NORMAL = -funroll-loops
OPT_INLINE = -finline-functions
JOHN_OBJS_MINIMAL = \
	john.o \
	misc.o \
	options.o \
	signals.o \
	bench.o \
	DES_fmt.o DES_std.o DES_bs.o \
	BSDI_fmt.o \
	MD5_fmt.o MD5_std.o \
	BF_fmt.o BF_std.o \
	AFS_fmt.o \
	LM_fmt.o \
	des.o \
	MD5_apache_fmt.o \
	BFEgg_fmt.o \
	lotus5_fmt.o \
	md5.o \
	NSLDAP_fmt.o NSLDAPS_fmt.o sha1.o base64.o \
	MYSQL_fmt.o \
	IPB2_fmt.o \
	NT_fmt.o \
	md4.o smbencrypt.o \
	rawMD5_fmt.o \
	rawSHA1_fmt.o \
	mssql_fmt.o \
	hmacMD5_fmt.o \
	WPAPSK_fmt.o \
	mscash_fmt.o \
	oracle_fmt.o \
	batch.o charset.o common.o compiler.o config.o cracker.o \
	crc32.o external.o formats.o getopt.o idle.o inc.o list.o \
	loader.o logger.o math.o memory.o params.o path.o \
	recovery.o rpp.o rules.o single.o status.o tty.o wordlist.o \
	unshadow.o ryan.o \
	unafs.o \
	undrop.o \
	unique.o
JOHN_OBJS_ORIG = \
	$(JOHN_OBJS_MINIMAL) DES_bs_b.o
JOHN_OBJS = \
	$(JOHN_OBJS_ORIG)
BENCH_DES_OBJS_ORIG = \
	DES_fmt.o DES_std.o
BENCH_DES_OBJS_DEPEND = \
	$(BENCH_DES_OBJS_ORIG)
BENCH_DES_BS_OBJS_DEPEND = \
	DES_bs_b.o
BENCH_MD5_OBJS_DEPEND = \
	MD5_fmt.o MD5_std.o
BENCH_BF_OBJS_DEPEND = \
	BF_std.o
BENCH_OBJS = \
	$(BENCH_DES_OBJS_DEPEND) \
	DES_bs.o $(BENCH_DES_BS_OBJS_DEPEND) \
	$(BENCH_MD5_OBJS_DEPEND) \
	BF_fmt.o $(BENCH_BF_OBJS_DEPEND) \
	bench.o best.o common.o config.o formats.o math.o memory.o miscnl.o \
	params.o path.o signals.o tty.o
PROJ = ../run/john ../run/unshadow ../run/unafs ../run/unique ../run/undrop
PROJ_DOS = ../run/john.bin ../run/john.com \
	../run/unshadow.com ../run/unafs.com ../run/unique.com ../run/undrop.c
om
PROJ_WIN32 = ../run/john.exe \
	../run/unshadow.exe ../run/unafs.exe ../run/unique.exe ../run/undrop.e
xe
default:
	@echo "To build John the Ripper, type:"
	@echo "	make clean SYSTEM"
	@echo "where SYSTEM can be one of the following:"
	@echo "linux-x86-mmx            Linux, x86 with MMX"
	@echo "linux-x86-sse2           Linux, x86 with SSE2 (best)"
	@echo "linux-x86-any            Linux, x86"
	@echo "linux-x86-64             Linux, AMD x86-64, 64-bit native
w/SSE2 (best)"
	@echo "linux-x86-64-mmx         Linux, AMD x86-64, 32-bit with MMX"
	@echo "linux-alpha              Linux, Alpha"
	@echo "linux-sparc              Linux, SPARC 32-bit"
	@echo "linux-ppc32-altivec      Linux, PowerPC w/AltiVec (best)"
	@echo "linux-ppc32              Linux, PowerPC 32-bit"
	@echo "linux-ppc64-altivec      Linux, PowerPC 64-bit w/AltiVec
(best)"
	@echo "linux-ppc64              Linux, PowerPC 64-bit"
	@echo "freebsd-x86-mmx          FreeBSD, x86 with MMX (best)"
	@echo "freebsd-x86-any          FreeBSD, x86"
	@echo "freebsd-alpha            FreeBSD, Alpha"
	@echo "openbsd-x86-mmx          OpenBSD, x86 with MMX (best)"
	@echo "openbsd-x86-any          OpenBSD, x86"
	@echo "openbsd-x86-64           OpenBSD, AMD x86-64"
	@echo "openbsd-alpha            OpenBSD, Alpha"
	@echo "openbsd-sparc64          OpenBSD, SPARC 64-bit (best)"
	@echo "openbsd-sparc            OpenBSD, SPARC 32-bit"
	@echo "openbsd-ppc32            OpenBSD, PowerPC 32-bit"
	@echo "openbsd-ppc64            OpenBSD, PowerPC 64-bit"
	@echo "openbsd-pa-risc          OpenBSD, PA-RISC"
	@echo "openbsd-vax              OpenBSD, VAX"
	@echo "netbsd-vax               NetBSD, VAX"
	@echo "solaris-sparc64-cc       Solaris, SPARC V9 64-bit, cc (best)"
	@echo "solaris-sparc64-mpicc      Solaris, SPARC V9 64-bit, mpicc"
	@echo "solaris-sparcv9-cc       Solaris, SPARC V9 32-bit, cc"
	@echo "solaris-sparcv8-cc       Solaris, SPARC V8 32-bit, cc"
	@echo "solaris-sparc-mpicc        Solaris, SPARC 32-bit, mpicc"
	@echo "solaris-x86-any          Solaris, x86, mpicc"
	@echo "sco-x86-any-mpicc          SCO, x86, mpicc"
	@echo "sco-x86-any-cc           SCO, x86, cc"
	@echo "tru64-alpha              Tru64 (Digital UNIX, OSF/1), Alpha"
	@echo "aix-ppc32                AIX, PowerPC 32-bit"
	@echo "macosx-ppc32-altivec     Mac OS X, PowerPC w/AltiVec (best)"
	@echo "macosx-ppc32             Mac OS X, PowerPC 32-bit"
	@echo "macosx-ppc64-altivec     Mac OS X 10.4+, PowerPC 64-bit
w/AltiVec"
	@echo "macosx-ppc64             Mac OS X 10.4+, PowerPC 64-bit"
	@echo "macosx-x86-sse2          Mac OS X, x86 with SSE2"
	@echo "hpux-pa-risc-mpicc         HP-UX, PA-RISC, mpicc"
	@echo "hpux-pa-risc-cc          HP-UX, PA-RISC, ANSI cc"
	@echo "irix-mips64-r10k         IRIX, MIPS 64-bit (R10K) (best)"
	@echo "irix-mips64              IRIX, MIPS 64-bit"
	@echo "irix-mips32              IRIX, MIPS 32-bit"
	@echo "dos-djgpp-x86-mmx        DOS, DJGPP 2.x, x86 with MMX (best)"
	@echo "dos-djgpp-x86-any        DOS, DJGPP 2.x, x86"
	@echo "win32-cygwin-x86-mmx     Win32, Cygwin, x86 with MMX (best)"
	@echo "win32-cygwin-x86-sse2    Win32, Cygwin, x86 with SSE2"
	@echo "win32-cygwin-x86-any     Win32, Cygwin, x86"
	@echo "beos-x86-mmx             BeOS, x86 with MMX"
	@echo "beos-x86-any             BeOS, x86"
	@echo "beos-x86-sse2            BeOS, x86 with SSE2 (best)"
	@echo "generic                  Any other Unix-like system with mpicc"
linux-x86-mmx:
	$(LN) x86-mmx.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-mmx.o md4-mmx.o
NTmmx_fmt.o md5-mmx.o sha1-mmx.o"
linux-x86-sse2:
	$(LN) x86-sse.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-sse.o md4-sse2.o
linux-x86-any:
	$(LN) x86-any.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) x86.o"
linux-x86-any-a.out:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) x86.o" \
		ASFLAGS="$(ASFLAGS) -DUNDERSCORES -DALIGN_LOG"
linux-x86-64:
	$(LN) x86-64.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86-64.o"
linux-x86-64-32-sse2:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-sse.o sha1-mmx.o" \
		CFLAGS="$(CFLAGS) -m32" \
		ASFLAGS="$(ASFLAGS) -m32" \
		LDFLAGS="$(LDFLAGS) -m32"
linux-x86-64-32-mmx:
	$(MAKE) $(PROJ) \
NTmmx_fmt.o" \
linux-alpha:
	$(LN) alpha.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) alpha.o"
# This target is currently "undocumented" as ccc generates much slower
# code for the large unrolled loops in John; let's hope it gets fixed.
linux-alpha-ccc:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) alpha.o" \
		CPP=ccc CC=ccc AS=ccc LD=ccc \
		CFLAGS="-c -Wf,-switch,noil_schedule" \
		OPT_NORMAL="-fast" \
		OPT_INLINE="-O2 -arch host"
linux-sparc:
	$(LN) sparc32.h arch.h
	$(MAKE) $(PROJ)
linux-ppc32-altivec:
	$(LN) ppc32alt.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) ppc-alti-linux.o" \
		OPT_INLINE="-finline-functions -finline-limit=4000"
linux-ppc32:
	$(LN) ppc32.h arch.h
	$(MAKE) $(PROJ)
# This is slightly slower than linux-ppc32-altivec for most hash types.
linux-ppc64-altivec:
	$(LN) ppc64alt.h arch.h
	$(MAKE) $(PROJ) \
		CFLAGS="$(CFLAGS) -m64" \
		LDFLAGS="$(LDFLAGS) -m64" \
linux-ppc64:
	$(LN) ppc64.h arch.h
	$(MAKE) $(PROJ) \
ppc-alti-linux.o: ppc-alti.c DES_bs_a.c
	$(CC) $(CFLAGS) $(OPT_INLINE) -maltivec ppc-alti.c -o $@
freebsd-x86-sse2:
	$(MAKE) $(PROJ) \
		ASFLAGS="$(ASFLAGS) -DBSD"
freebsd-x86-mmx:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-mmx.o sha1-mmx.o" \
freebsd-x86-any:
	$(MAKE) $(PROJ) \
freebsd-x86-any-a.out:
	$(MAKE) $(PROJ) \
		ASFLAGS="$(ASFLAGS) -DUNDERSCORES -DALIGN_LOG -DBSD"
freebsd-x86-64:
	$(MAKE) $(PROJ) \
freebsd-alpha:
	$(MAKE) $(PROJ) \
openbsd-x86-sse2:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-sse.o" \
openbsd-x86-mmx:
	$(MAKE) $(PROJ) \
NTmmx_fmt.o" \
openbsd-x86-any:
	$(MAKE) $(PROJ) \
openbsd-x86-any-a.out:
	$(MAKE) $(PROJ) \
openbsd-x86-64:
	$(MAKE) $(PROJ) \
openbsd-alpha:
	$(MAKE) $(PROJ) \
openbsd-sparc64:
	$(LN) sparc64.h arch.h
	$(MAKE) $(PROJ) \
		CFLAGS="$(CFLAGS) -m64 -mcpu=ultrasparc" \
openbsd-sparc:
	$(MAKE) use-openbsd-sparc HAMMER=use-openbsd-sparc NAIL=sparc.h
	$(LN) sparc.h arch.h
	$(MAKE) use-openbsd-sparc NAIL="$(PROJ)"
use-openbsd-sparc:
	$(MAKE) $(NAIL) \
		BENCH_DES_OBJS_DEPEND="$(BENCH_DES_OBJS_ORIG) sparc.o" \
		JOHN_OBJS="$(JOHN_OBJS_ORIG) sparc.o" \
		ASFLAGS="-c -DBSD"
openbsd-sparc-a.out:
	$(MAKE) use-openbsd-sparc-a.out \
		HAMMER=use-openbsd-sparc-a.out NAIL=sparc.h
	$(MAKE) use-openbsd-sparc-a.out NAIL="$(PROJ)"
use-openbsd-sparc-a.out:
	$(MAKE) $(NAIL) \
		ASFLAGS="-c -DUNDERSCORES -DBSD"
openbsd-ppc32:
	$(MAKE) $(PROJ)
openbsd-ppc64:
	$(MAKE) $(PROJ) \
openbsd-pa-risc:
	$(LN) pa-risc.h arch.h
	$(MAKE) $(PROJ) \
		CFLAGS="-c -Wall -O3 -fomit-frame-pointer"
openbsd-vax:
	$(LN) vax.h arch.h
	$(MAKE) $(PROJ)
netbsd-sparc64:
	$(MAKE) $(PROJ) \
netbsd-vax:
	$(LN) vax.h arch.h
	$(MAKE) $(PROJ)
solaris-sparc64-cc:
	$(MAKE) $(PROJ) \
		CPP=cc CC=cc AS=cc LD=cc \
		CFLAGS="-c -fast -xarch=native64" \
		LDFLAGS="-s -xarch=native64 -lc -lrt" \
		OPT_NORMAL="" \
		OPT_INLINE="-xinline=s1,s2,s3,s4,s5,s6,s7,s8"
solaris-sparc64-mpicc:
	$(MAKE) $(PROJ) \
		LDFLAGS="$(LDFLAGS) -m64 -lrt"
solaris-sparc-any:
	$(MAKE) $(HAMMER) NAIL=sparc.h
	$(RM) arch.h
	ln -s sparc.h arch.h
	$(MAKE) $(HAMMER) NAIL="$(PROJ)"
solaris-sparcv9-cc:
	$(MAKE) solaris-sparc-any HAMMER=use-solaris-sparcv9-cc
solaris-sparcv8-cc:
	$(MAKE) solaris-sparc-any HAMMER=use-solaris-sparcv8-cc
solaris-sparc-mpicc:
	$(MAKE) solaris-sparc-any HAMMER=use-solaris-sparc-mpicc
use-solaris-sparcv9-cc:
	$(MAKE) $(NAIL) \
		BENCH_DES_OBJS_DEPEND="$(BENCH_DES_OBJS_ORIG) spro-sparc.o" \
		JOHN_OBJS="$(JOHN_OBJS_ORIG) spro-sparc.o" \
		CFLAGS="-c -xO4 -xarch=v8plusa -xchip=ultra" \
		LDFLAGS="-s -lc -lrt" \
		OPT_NORMAL="" \
use-solaris-sparcv8-cc:
	$(MAKE) $(NAIL) \
		CFLAGS="-c -xO4 -xarch=v8" \
		OPT_NORMAL="" \
use-solaris-sparc-mpicc:
	$(MAKE) $(NAIL) \
		LDFLAGS="$(LDFLAGS) -lrt"
sparc.h:
	$(RM) arch.h
	$(CC) $(CFLAGS) -DOS_TIMER -DOS_FLOCK -DDES_ASM detect.c
	$(LD) $(LDFLAGS) detect.o -o detect
	./sparc.sh "$(MAKE)" "$(HAMMER)" "$(BENCH_DES_OBJS_DEPEND)"
# Older versions of spro cc didn't support .S files directly
spro-sparc.o: sparc.S
	$(CPP) $(CPPFLAGS) sparc.S | $(SED) 's/% /%/g' > tmp.s
	$(AS) $(ASFLAGS) tmp.s -o spro-sparc.o
	$(RM) tmp.s
solaris-x86-any:
	$(RM) arch.h
	ln -s x86-any.h arch.h
	$(MAKE) $(PROJ) \
		SHELL=/bin/sh \
		JOHN_OBJS="$(JOHN_OBJS) solaris-x86.o" \
		LDFLAGS="$(LDFLAGS) -lc -lrt"
# Solaris x86 got a broken assembler, with line length restriction (and some
# other problems, that are worked around in x86.S)
solaris-x86.o: x86.S
	$(CPP) $(CPPFLAGS) -P -DDUMBAS x86.S | $(TR) \; \\n > tmp.s
	$(AS) $(ASFLAGS) tmp.s -o solaris-x86.o
	$(RM) tmp.s
sco-x86-any-mpicc:
	$(RM) arch.h
	$(MAKE) $(PROJ) \
		SHELL=/bin/sh \
		JOHN_OBJS="$(JOHN_OBJS) sco-x86.o"
sco-x86-any-cc:
	$(RM) arch.h
	$(MAKE) $(PROJ) \
		SHELL=/bin/sh \
		JOHN_OBJS="$(JOHN_OBJS) sco-x86.o" \
		CFLAGS="-c -b elf -O3" \
		ASFLAGS="-c -b elf" \
		OPT_NORMAL="-K loop_unroll,no_inline" \
		OPT_INLINE="-K inline"
# SCO is even worse than Solaris x86
sco-x86.o: x86.S
	$(CPP) $(CPPFLAGS) -DDUMBAS x86.S | \
		$(TR) \; \\n | $(SED) 's/\([%.]\) /\1/g' > tmp.s
	$(AS) $(ASFLAGS) tmp.s -o sco-x86.o
	$(RM) tmp.s
tru64-alpha:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) digipaq-alpha.o" \
		CFLAGS="-c -O4 -arch host" \
		OPT_NORMAL="" \
		OPT_INLINE="-inline all"
# Digital/Compaq's cc and make use the .S suffix for a different purpose...
digipaq-alpha.o: alpha.S
	$(CPP) $(CPPFLAGS) alpha.S > tmp.s
	$(AS) $(ASFLAGS) tmp.s -o digipaq-alpha.o
	$(RM) tmp.s
aix-ppc32:
	$(MAKE) $(PROJ) \
		CFLAGS="-c -qunroll=2 -qarch=ppc -qchars=signed" \
		LDFLAGS="-s -lbsd" \
		OPT_NORMAL="-O2" \
		OPT_INLINE="-O3 -Q=99 -w"
macosx-ppc32-altivec:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) ppc-alti-macosx.o" \
		CFLAGS="-c -Wall -fomit-frame-pointer" \
		OPT_NORMAL="-fast -mcpu=7450" \
		OPT_INLINE="-fast -mcpu=7450 -finline-limit=4000"
macosx-ppc32:
	$(MAKE) $(PROJ) \
		CFLAGS="-c -traditional-cpp" \
		OPT_NORMAL="-O2" \
		OPT_INLINE="-O3"
# This is slightly slower than macosx-ppc32-altivec for most hash types.
macosx-ppc64-altivec:
	$(MAKE) $(PROJ) \
		CFLAGS="-c -m64 -Wall -fomit-frame-pointer" \
		LDFLAGS="-s -m64" \
		OPT_INLINE="-fast -finline-limit=4000"
macosx-ppc64:
	$(MAKE) $(PROJ) \
		CFLAGS="-c -Wall -fomit-frame-pointer -m64" \
		LDFLAGS="-s -m64" \
ppc-alti-macosx.o: ppc-alti.c DES_bs_a.c
	$(CC) $(CFLAGS) $(OPT_INLINE) -faltivec -maltivec ppc-alti.c -o $@
macosx-x86-sse2:
	$(LN) x86-sse-mac.h arch.h
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-sse.o" \
		ASFLAGS="$(ASFLAGS) -DUNDERSCORES -DBSD -DALIGN_LOG"
		OPT_NORMAL="-O2" \
		OPT_INLINE="-O3"
macosx-x86-mmx:
	$(MAKE) $(PROJ) \
		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-mmx.o sha1-mmx.o" \
		OPT_NORMAL="-O2" \
		OPT_INLINE="-O3"
hpux-pa-risc-mpicc:
	$(MAKE) $(PROJ) \
hpux-pa-risc-cc:
	$(MAKE) $(PROJ) \
		CFLAGS="-c -Aa -D_HPUX_SOURCE -DANSI_CPP" \
		LDFLAGS="-s" \
		OPT_NORMAL="+O2" \
		OPT_INLINE="+O3 +Oinline"
irix-mips64-r10k:
	$(LN) mips64.h arch.h
	$(MAKE) $(PROJ) \
		CFLAGS="-c -O2 -64 -mips4 -r10000 -signed" \
		LDFLAGS="-s -64 -mips4 -r10000" \
		OPT_NORMAL="-LNO:opt=1 -OPT:Olimit=2194" \
		OPT_INLINE="-INLINE:all"
irix-mips64:
	$(MAKE) $(PROJ) \
		CFLAGS="-c -O2 -64 -mips3 -signed" \
		LDFLAGS="-s -64 -mips3" \
irix-mips32:
	$(LN) mips32.h arch.h
	$(MAKE) $(PROJ) \
		CFLAGS="-c -O2 -32 -signed" \
		LDFLAGS="-s -32" \
dos-djgpp-x86-mmx:
	copy x86-mmx.h arch.h
	$(MAKE) $(PROJ_DOS) \
NTmmx_fmt.o" \
		CFLAGS="$(CFLAGS) -mpreferred-stack-boundary=2" \
dos-djgpp-x86-any:
	copy x86-any.h arch.h
win32-cygwin-x86-mmx:
	$(CP) x86-mmx.h arch.h
	$(MAKE) $(PROJ_WIN32) \
		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-mmx.o  md4-mmx.o
NTmmx_fmt.o md5-mmx.o sha1-mmx.o" \
		ASFLAGS="$(ASFLAGS) -DUNDERSCORES"
win32-cygwin-x86-sse2:
	$(CP) x86-sse.h arch.h
		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-sse.o md4-sse2.o
win32-cygwin-x86-any:
	$(CP) x86-any.h arch.h
beos-x86-sse2:
	$(MAKE) $(PROJ) \
beos-x86-mmx:
	$(MAKE) $(PROJ) \
NTmmx_fmt.o"
beos-x86-any:
	$(MAKE) $(PROJ) \
generic: generic.h
	$(RM) arch.h
	ln -s generic.h arch.h
	$(MAKE) $(PROJ)
generic.h:
	$(RM) arch.h
	$(CC) $(CFLAGS) detect.c
	./best.sh "$(MAKE)" \
		"$(BENCH_DES_OBJS_DEPEND)" \
		"$(BENCH_DES_BS_OBJS_DEPEND)" \
		"$(BENCH_MD5_OBJS_DEPEND)" \
		"$(BENCH_BF_OBJS_DEPEND)"
bench: $(BENCH_OBJS)
	$(LD) $(LDFLAGS) $(BENCH_OBJS) -o bench
../run/john: $(JOHN_OBJS)
	$(LD) $(JOHN_OBJS) $(LDFLAGS) -o ../run/john
../run/unshadow: ../run/john
	$(RM) ../run/unshadow
	ln -s john ../run/unshadow
../run/unafs: ../run/john
	$(RM) ../run/unafs
	ln -s john ../run/unafs
../run/undrop: ../run/john
	$(RM) ../run/undrop
	ln -s john ../run/undrop
../run/unique: ../run/john
	$(RM) ../run/unique
	ln -s john ../run/unique
../run/john.bin: $(JOHN_OBJS)
	$(LD) $(LDFLAGS) $(JOHN_OBJS) -o ../run/john.exe
	if exist ..\run\john.bin del ..\run\john.bin
	ren ..\run\john.exe john.bin
../run/john.com: john.com
	copy john.com ..\run\john.com
../run/unshadow.com: john.com
	copy john.com ..\run\unshadow.com
../run/unafs.com: john.com
	copy john.com ..\run\unafs.com
../run/undrop.com: john.com
	copy john.com ..\run\undrop.com
../run/unique.com: john.com
	copy john.com ..\run\unique.com
john.com: john.asm
	@echo Use Borland TASM/TLINK to make JOHN.COM
../run/john.exe: $(JOHN_OBJS)
	$(LD) $(JOHN_OBJS) -lkernel32 -o ../run/john.exe
	strip ../run/john.exe
../run/unshadow.exe: symlink.c
	$(CC) symlink.c -o ../run/unshadow.exe
	strip ../run/unshadow.exe
../run/unafs.exe: symlink.c
	$(CC) symlink.c -o ../run/unafs.exe
	strip ../run/unafs.exe
../run/undrop.exe: symlink.c
	$(CC) symlink.c -o ../run/undrop.exe
	strip ../run/undrop.exe
../run/unique.exe: symlink.c
	$(CC) symlink.c -o ../run/unique.exe
	strip ../run/unique.exe
# Inlining the S-boxes produces faster code, as long as they fit in the cache
# (that is, on RISC with at least 8 KB of L1 code cache).
DES_bs_b.o: DES_bs_b.c DES_bs_s.c DES_bs_n.c
	$(CC) $(CFLAGS) $(OPT_INLINE) DES_bs_b.c
# I prefer to distribute Matthew Kwan's S-box files unmodified...
DES_bs_s.c: sboxes.c
	$(SED) "s/unsigned long/ARCH_WORD/" sboxes.c > DES_bs_s.c
DES_bs_n.c: nonstd.c
	$(SED) "s/unsigned long/ARCH_WORD/" nonstd.c > DES_bs_n.c
DES_bs_a.c: nonstd.c ppc-alti.pl
	$(PERL) ppc-alti.pl nonstd.c > DES_bs_a.c
miscnl.o: misc.c
	$(CC) $(CFLAGS) $(OPT_NORMAL) -D_JOHN_MISC_NO_LOG misc.c -o miscnl.o
.c.o:
	$(CC) $(CFLAGS) $(OPT_NORMAL) $*.c
.S.o:
	$(AS) $(ASFLAGS) $*.S
# We don't have any files with .s suffix, this is for compiling in DOS only
.s.o:
depend:
	makedepend -fMakefile.dep -Y *.c 2>> /dev/null
clean:
	$(RM) $(PROJ) $(PROJ_DOS) $(PROJ_WIN32)
	$(RM) ../run/john.exe *.o *.bak core
	$(RM) detect bench generic.h arch.h sparc.h tmp.s
	$(RM) DES_bs_s.c DES_bs_n.c DES_bs_a.c
	$(CP) $(NULL) Makefile.dep
include Makefile.dep
