[mpich-discuss] mpich2 1.0.8: problems compiling (simplemake)
Rajeev Thakur thakur at mcs.anl.gov
Tue Dec 30 08:43:16 CST 2008
Try with a fresh untar of the tarball in a directory like /tmp -- something
that resides on the local disk, not remotely mounted home directories.
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Bellanca Gaetano
Sent: Tuesday, December 30, 2008 2:19 AM
Subject: Re: [mpich-discuss] mpich2 1.0.8: problems compiling (simplemake)
Hi Rajeev,
I'm sorry but I don't completely understand what did you mean.
I'm on a local disk of a remote machine (I'm at home, and the computer is at
the University). I rebooted the machine (to be sure that everything is O.K.
also after the last update). But I have the same error.
The mpich2 directory is a fresh untar. I only changed the name from
mpich2-1.0.8 to mpich2-1.0.8_gnu to distinguish between the gfortran and the
pgi compilations. But I also try with the original name .... without solving
the problem.
Gaetano
 At 05.17 30/12/2008, you wrote:
It is probably a problem
with time stamps being out of sync on the machine. Try starting with a
fresh untar of the tarball. Do it on a local disk
instead of an NFS file system.
Rajeev
  _____
<mailto:mpich-discuss-bounces at mcs.anl.gov>
Sent: Monday, December 29, 2008 5:49 PM
Subject: [mpich-discuss] mpich2 1.0.8: problems compiling (simplemake)
I'm having problems in compiling mpich2 1.0.8 with a pgi 8.0.1 fortran
compiler on an ubuntu 7.10 linux box (32 bit).
The same problems is reported also with a gnu compiler, whereas the code
compile correctly with Intel 10.1.
The error is:
make[2]: Entering directory
`/home/bellanca/software/mpich2/1.0.8/mpich2-1.0.8_pgi/src/mpid'
( cd . && /maint/simplemake \
        -rootdir=../../ \
        -configdir=. \
        -common=/maint/makedefs \
        -docnamedefs=/maint/docnotes \
        "-autoconf=-I ROOTDIR/confdb" \
        -libdir='${MPILIBNAME}=ROOTDIR/lib' \
        -smroot=/maint \
        -distcleanfiles="Makefile" \
        -smvar_doc_attop=0 \
                Makefile.sm )
/bin/bash: line 1: /maint/simplemake: No such file or directory
make[2]: *** [Makefile.in] Error 127
This is what I have configured before compiling mpich2:
./configure --prefix=/opt/mpich2/1.0.8/pgi --enable-cxx --enable-f90
--enable-fast --enable-traceback --with-mpe --enable-f90modules
--enable-cache --enable-romio --with-file-system=nfs+ufs+pvfs2
--with-device=ch3:nemesis --with-pvfs2=/usr/local
--with-java=/usr/lib/jvm/java-6-sun
Any idea?
Regards.
Gaetano
  _____
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
"L'istruzione costa? Stanno provando con l'ignoranza!"
  _____
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081230/4a44b9a2/attachment.htm>
