[mpich-discuss] mpich-discuss Digest, Vol 3, Issue 19
pisoir ondrej.sluciak at gmail.com
Mon Dec 15 16:18:26 CST 2008
Thank you, I will try it. It seems that it really has something to do
with the account name, which I don't understand why it is so relevant. I
believe, that according to so many people who have had such problems
with mpich on windows, it would be nice, if developers made some changes
in the code that would simplify all this setting on windows. Or at least
write some hints on the webpage about how to solve these problems.
Ondrej
Vivian wrote:
> Hi, Ondrej,
>      I met similar problems before. The problem is solved by:
>      (1) Install all service packs and .net framework 2.0;
>      (2) Update to the latest version of MPICH2;
>      (3) I realized that I changed the user name of my account before.
> The mpi only recognizes the initial account name. So I registered this
> account again.
>       Good luck!
> Vivian
> On Mon, Dec 15, 2008 at 1:00 PM, <mpich-discuss-request at mcs.anl.gov
> <mailto:mpich-discuss-request at mcs.anl.gov>> wrote:
>     Send mpich-discuss mailing list submissions to
>            mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>     To subscribe or unsubscribe via the World Wide Web, visit
>            https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>            mpich-discuss-owner at mcs.anl.gov
>     <mailto:mpich-discuss-owner at mcs.anl.gov>
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of mpich-discuss digest..."
>     Today's Topics:
>       1. Re:  Problem with MPICH2 v1.0.8 on WindowsXP (pisoir)
>       2. Re:  Problem with MPICH2 v1.0.8 on WindowsXP (bob ilgner)
>       3. Re:  Problem with MPICH2 v1.0.8 on WindowsXP (Jayesh Krishna)
>       4. Re:  MPICH2 1.0.6p1 & Windows HPC Server  2008(badperformance
>          (Jayesh Krishna)
>     Message: 1
>     Date: Mon, 15 Dec 2008 14:42:33 +0100
>     From: pisoir <ondrej.sluciak at gmail.com
>     <mailto:ondrej.sluciak at gmail.com>>
>     Subject: Re: [mpich-discuss] Problem with MPICH2 v1.0.8 on WindowsXP
>     To: mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>     Message-ID: <49465EC9.2030801 at gmail.com
>     <mailto:49465EC9.2030801 at gmail.com>>
>     Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>     Hi Bob,
>     Thanks for your advice. It seems that the 2nd solution would be my
>     last
>     chance. I just don't know if I want Vista running as the 2nd
>     computer. I
>     only have 1 router between the computers, so the 1st solution is not
>     applicable for me. I just don't understand why the setting of mpi
>     is so
>     different and more complicated than setting mpi on linux.
>     Ondrej
>     bob ilgner wrote:
>     > Hi Ondrej,
>     > I have had this behaviour on 2 occasions with XP and 1.0.8:
>     > 1) Router interference from a second  network router prevented
>     > validation or any other MPI comms. Switching 2nd router off and
>     using
>     > only 1 router solved problem.
>     > 2) Nothing but nothing helped and I fiddled my guts out and received
>     > some good advice. So installed Vista on 2nd partition and booted
>     into
>     > that for MPI work. Worked a charm.
>     > Regards, bob
>     > On Mon, Dec 15, 2008 at 12:11 AM, pisoir
>     <ondrej.sluciak at gmail.com <mailto:ondrej.sluciak at gmail.com>
>     <mailto:ondrej.sluciak at gmail.com>>> wrote:
>     >     Hello,
>     >     I have one problem on Windows XP SP3 and I'm starting to feel
>     >     really desperate now. Thanks to help of this:
>     http://lists.mcs.anl.gov/pipermail/mpich-discuss/2008-November/000037.html
>     >     I was able to get over the validation of mpiexec (mpiexec
>     >     -validate returned SUCCESS). Anyway, if I want to run even the
>     >     simplest program possible,i.e.  mpiexec -host second_host
>     >     hostname, I always get the error:
>     >     Credentials for Ondrej rejected connecting to shrek
>     >     Aborting: Unable to connect to shrek
>     >     (Ondrej is the name of first computer, shrek is the name of
>     >     second). If I do "smpd -status shrek" (from Ondrej
>     computer), I get:
>     >     smpd running on shrek
>     >     So it seems that everything is ok. I turned off the firewalls, I
>     >     can ping each other and also the shared folders are accessible
>     >     from both computers. Just the mpi is not running as it should. I
>     >     reinstalled mpich2 and rebooted computer so many times, that it
>     >     couldn't be reinstalled and rebooted any more. Does anyone have
>     >     some similar problems or at least have any clue how to solve
>     this?
>     >     Thanks.
>     >     Ondrej
>     Message: 2
>     Date: Mon, 15 Dec 2008 16:15:19 +0000
>     From: "bob ilgner" <bobilgner at gmail.com <mailto:bobilgner at gmail.com>>
>     Message-ID:
>      <b193b85d0812150815i4c2ce313gce3f43ec095f926d at mail.gmail.com
>     <mailto:b193b85d0812150815i4c2ce313gce3f43ec095f926d at mail.gmail.com>>
>     Content-Type: text/plain; charset="iso-8859-1"
>     Hi,
>     Don't forget the mission. You want to deploy MPI and not debug a
>     Windows
>     glitch however enticing that may be. I get caught out by digging
>     into the
>     Windows guts and spending hours on something I can never fix anyhow.
>     Regards, bob
>     On Mon, Dec 15, 2008 at 1:38 PM, pisoir <ondrej.sluciak at gmail.com
>     <mailto:ondrej.sluciak at gmail.com>> wrote:
>     > No I haven't because I don't have the MS Servers. I only wanted
>     to connect
>     > 2 computers, both running Win XP Professional. I had no problem
>     with MPI
>     > running two linux machines (using mpd).
>     > Marcus Vinicius Brand?o Soares wrote:
>     >> Hello Ondrej,
>     >> Have you tried to look at the number of licenses for
>     connections in sherk
>     >> ? I seems to me that, if everything is ok, Microsoft's license
>     manager can
>     >> be rejecting the (extra) connection. (or it may be a bug in
>     license manager
>     >> License manager is a program embedded in Microsft's Servers to
>     monitor the
>     >> maximum number of lawfull connections.
>     >> You can see it in the control panel of shrek.
>     >> I hope I helped you ;-))
>     >> Best regards,
>     >> Marcus Vinicius.
>     >> 2008/12/14 pisoir <ondrej.sluciak at gmail.com
>     <mailto:ondrej.sluciak at gmail.com> <mailto:
>     >> ondrej.sluciak at gmail.com <mailto:ondrej.sluciak at gmail.com>>>
>     >>    Hello,
>     computer), I get:
>     this?
>     >>    Thanks.
>     >>    Ondrej
>     >> Marcus Vinicius
>     >> "Havendo suficientes colaboradores,
>     >> Qualquer problema ? pass?vel de solu??o"
>     >> Eric S. Raymond
>     >> A Catedral e o Bazar
>     >> "O passado ? apenas um recurso para o presente"
>     >> Clave de Clau
>     >> "Ningu?m ? t?o pobre que n?o possa dar um abra?o; e
>     >> Ningu?m ? t?o rico que n?o necessite de um abra?o.
>     >> An?nimo
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081215/918facab/attachment-0001.htm>
>     Message: 3
>     Date: Mon, 15 Dec 2008 11:20:51 -0600 (CST)
>     From: "Jayesh Krishna" <jayesh at mcs.anl.gov
>     <mailto:jayesh at mcs.anl.gov>>
>     To: "'pisoir'" <ondrej.sluciak at gmail.com
>     Cc: mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>     Message-ID: <23EA78217CA54A8C8F2B36118824DDAE at mcs.anl.gov
>     <mailto:23EA78217CA54A8C8F2B36118824DDAE at mcs.anl.gov>>
>     Content-Type: text/plain; charset="us-ascii"
>      Hi,
>      Do you have a user Ondrej on the second machine (Do you have a
>     different
>     password for the user Ondrej on the second machine ?) ? Can you
>     run an MPI
>     program on the second machine (Login to the second host, shrek,
>     and run an
>     MPI program) ?
>     Regards,
>     Jayesh
>     -----Original Message-----
>     From: mpich-discuss-bounces at mcs.anl.gov
>     <mailto:mpich-discuss-bounces at mcs.anl.gov>
>     [mailto:mpich-discuss-bounces at mcs.anl.gov
>     <mailto:mpich-discuss-bounces at mcs.anl.gov>] On Behalf Of pisoir
>     Sent: Sunday, December 14, 2008 6:12 PM
>     Subject: [mpich-discuss] Problem with MPICH2 v1.0.8 on WindowsXP
>     Hello,
>     I have one problem on Windows XP SP3 and I'm starting to feel really
>     I was able to get over the validation of mpiexec (mpiexec -validate
>     returned SUCCESS). Anyway, if I want to run even the simplest program
>     possible,i.e.  mpiexec -host second_host hostname, I always get
>     the error:
>     second). If I
>     do "smpd -status shrek" (from Ondrej computer), I get:
>     can ping
>     each other and also the shared folders are accessible from both
>     computers.
>     Just the mpi is not running as it should. I reinstalled
>     mpich2 and rebooted computer so many times, that it couldn't be
>     reinstalled and rebooted any more. Does anyone have some similar
>     problems
>     or at least have any clue how to solve this? Thanks.
>     Ondrej
>     URL:
>     <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081215/4ca9fa2f/attachment-0001.htm>
>     Message: 4
>     Date: Mon, 15 Dec 2008 11:25:12 -0600 (CST)
>     Subject: Re: [mpich-discuss] MPICH2 1.0.6p1 & Windows HPC Server
>            2008(badperformance
>     To: "'Seifer Lin'" <seiferlin at gmail.com <mailto:seiferlin at gmail.com>>
>     Message-ID: <62AA470C78F1402AB9D7E0C43F5FC316 at mcs.anl.gov
>     <mailto:62AA470C78F1402AB9D7E0C43F5FC316 at mcs.anl.gov>>
>     Hi,
>      Great to know its working for you now. What was the value (The
>     value with
>     the bad perf) of TcpAckFrequency in your machine (Did you change the
>     default value before you ran your test cases ?)?
>     Regards,
>     Jayesh
>      _____
>     <mailto:mpich-discuss-bounces at mcs.anl.gov>] On Behalf Of Seifer Lin
>     Sent: Monday, December 15, 2008 2:05 AM
>     2008(badperformance
>     Hi Everyone:
>     Finally the problem is resolved by adding a registry value
>     HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Inte
>     rfaces\{NIC-id}\TcpAckFrequency
>     Set TcpAckFrequency to 1 resolves the problem.
>     regards,
>     Seifer Lin
>     2008/12/10 Hisham Adel <hosham2004 at yahoo.com
>     <mailto:hosham2004 at yahoo.com>>
>     Why are you use MPICH2 ?
>     The Cluster component on Windows server 2008 (HPC component) have
>     MSMPI it
>     is like MPICH2 but it is modified by Microsoft.
>     You can use it as MPICH2. There is no change in any thing the same
>     functions and everything is the same.
>     I have tried it on a cluster of 4 nodes and it works.
>     Hisham Adel Hassan Mohamed
>     Research Assistant
>     Bioinformatics Group
>     Nile University
>     Smart Village - km28
>     Cairo - Alexandria Desert Road
>     Giza , EGYPT
>     Mobile : +20106459663
>     Email:Hisham.mohamed at nileu.edu.eg
>     <mailto:Email%3AHisham.mohamed at nileu.edu.eg>
>     <mailto:Email%253AHisham.mohamed at nileu.edu.eg>>
>     --- On Mon, 12/8/08, Jayesh Krishna <jayesh at mcs.anl.gov
>     <mailto:jayesh at mcs.anl.gov>> wrote:
>     From: Jayesh Krishna <jayesh at mcs.anl.gov <mailto:jayesh at mcs.anl.gov>>
>     Subject: Re: [mpich-discuss] MPICH2 1.0.6p1 & Windows HPC Server 2008
>     (badperformance)
>     Date: Monday, December 8, 2008, 5:10 PM
>     Hi,
>      Can you try out the latest stable version (1.0.8) of MPICH2
>     (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=dow
>     nloads)?
>     Regards,
>     Jayesh
>      _____
>     Sent: Monday, December 08, 2008 12:47 AM
>     Subject: [mpich-discuss] MPICH2 1.0.6p1 & Windows HPC Server 2008
>     (badperformance)
>     Hi everyone:
>     I have a cluster of 4 nodes, all of them are with Windows HPC
>     server 2008
>     installed.
>     I make all of the 4 nodes in the same workgroup. I use MPICH2
>     1.0.6p1 from
>     Argonne Lab.
>     And then
>     1. firewall of all 4 nodes are turned off
>     2. UAC (User Account Control) of all 4 nodes are turned off
>     3. I start smpd.exe (1.0.6p1 x64) in all the 4 nodes
>     And I run a very simple MPI program (test_mpich2.exe)
>     #include "mpi.h"
>     #include <iostream>
>     int main(int argc, char **argv)
>        int cpuid, ncpu;
>        MPI_Init(&argc, &argv);
>        MPI_Comm_size(MPI_COMM_WORLD, &ncpu);
>        MPI_Comm_rank(MPI_COMM_WORLD, &cpuid);
>        printf("NCPU:%d, CPUID:%d\n", ncpu, cpuid);
>        fflush(stdout);
>        printf("start barrier\n"); fflush(stdout);
>        MPI_Barrier(MPI_COMM_WORLD);
>        printf("end barrier\n"); fflush(stdout);
>        MPI_Finalize();
>        return 0;
>     The command is
>     mpiexec -hosts 2 192.168.1.1 <http://192.168.1.1/>  192.168.1.2
>     <http://192.168.1.2/>  \\192.168.1.1\shared\test_mpich2.exe
>     And the MPI_Barrier(...) function costs 10 seconds to return !!!!!
>     If the same code is running on a Windows XP cluster, MPI_Barrier(...)
>     returns at once!
>     Does anyone know how to solve this problem on Windows HPC Server
>     2008 ?
>     (Windows Vista has the same problem, too)
>     regards,
>     Seifer Lin
>     URL:
>     <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081215/5abcf16e/attachment-0001.htm>
>     _______________________________________________
>     End of mpich-discuss Digest, Vol 3, Issue 19
