[mpich-discuss] Problem with MPICH2 v1.0.8 on WindowsXP
Marcus Vinicius Brandão Soares mvbsoares at gmail.com
Mon Dec 15 07:04:12 CST 2008
Hello Ondrej,
Have you tried to look at the number of licenses for connections in sherk ?
I seems to me that, if everything is ok, Microsoft's license manager can be
rejecting the (extra) connection. (or it may be a bug in license manager
License manager is a program embedded in Microsft's Servers to monitor the
maximum number of lawfull connections.
You can see it in the control panel of shrek.
I hope I helped you ;-))
Best regards,
Marcus Vinicius.
2008/12/14 pisoir <ondrej.sluciak at gmail.com>
> Hello,
> I have one problem on Windows XP SP3 and I'm starting to feel really
> desperate now. Thanks to help of this:
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2008-November/000037.html
> I was able to get over the validation of mpiexec (mpiexec -validate
> returned SUCCESS). Anyway, if I want to run even the simplest program
> possible,i.e.  mpiexec -host second_host hostname, I always get the error:
> Credentials for Ondrej rejected connecting to shrek
> Aborting: Unable to connect to shrek
> (Ondrej is the name of first computer, shrek is the name of second). If I
> do "smpd -status shrek" (from Ondrej computer), I get:
> smpd running on shrek
> So it seems that everything is ok. I turned off the firewalls, I can ping
> each other and also the shared folders are accessible from both computers.
> Just the mpi is not running as it should. I reinstalled mpich2 and rebooted
> computer so many times, that it couldn't be reinstalled and rebooted any
> more. Does anyone have some similar problems or at least have any clue how
> to solve this? Thanks.
> Ondrej
Marcus Vinicius
"Havendo suficientes colaboradores,
Qualquer problema é passível de solução"
Eric S. Raymond
A Catedral e o Bazar
"O passado é apenas um recurso para o presente"
Clave de Clau
"Ninguém é tão pobre que não possa dar um abraço; e
Ninguém é tão rico que não necessite de um abraço.
Anônimo
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081215/ad3fc8c3/attachment.htm>
