[mpich-discuss] modifying the round-robin
Rajeev Thakur thakur at mcs.anl.gov
Wed Dec 10 09:48:25 CST 2008
Since you are running from node C, MPD will place the first process on node
C by default. You can turn that feature off with the "-1" option to mpiexec.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Benjamin Svetitsky
> Sent: Wednesday, December 10, 2008 2:41 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] modifying the round-robin
> Greetings,
> I am running MPICH2 on a cluster of four quad-core machines
> under Linux.
>   If I run a job such as
> mpiexec -l -n 4 hostname
> then one process runs on each node, whereas I would prefer
> that all four run on the same node.  I tried modifying
> mpd.hosts to read:
> nodeA:4
> nodeB:4
> nodeC:4
> nodeD:4
> but the result is not what I expected:
> nodeC% mpiexec -l -n 4 hostname
> 0: nodeC
> 3: nodeB
> 2: nodeB
> 1: nodeB
> How can I get the mpd to fill the hosts one by one reliably?
> Incidentally, the :4 option is not documented in the
> Installation Guide.
>   I picked it up in the gutter.  If it doesn't do this, what
> DOES it do?
> Thanks,
> 	Ben
> Prof. Benjamin Svetitsky         Phone:            +972-3-640 8870
> School of Physics and Astronomy  Fax:              +972-3-640 7932
> Tel Aviv University              E-mail:      bqs at julian.tau.ac.il
> 69978 Tel Aviv, Israel           WWW: http://julian.tau.ac.il/~bqs
